Aktuálny čas je Štv 24. Sep 2026 14:06:04
 ID USB Lock Key 1.3
 Predmet príspevku: ID USB Lock Key 1.3
PoslaťNapísal: Pia 20. Nov 2009 8:12:22
ID USB Lock Key program is designed to lock your computer from unauthorized access attempts.
The blocking mechanism is simple when you start the program in a lock on the screen displays a message on the computer is locked and blocked all access to it, with the generated and stored on the usb-drive is a special key to disable the lock. Activating the screen lock is held in three steps. All you need to do to protect your PC - so submit your USB device to generate a security key and pull the USB device. Your computer will be blocked from any unauthorized access. You can choose to activate the blocking mode by simply pressing CTR + L. Key The program locks your computer through the device via USV Keystrokes CTR + ALT + DEL, has a convenient graphical user interface that is very simple to use, requires minimal space on your computer to work effectively.
ID USB Lock Key is a security program meant to protect your computer from unauthorized users. It denies access, by providing a security block-screen which can be unblocked with the USB stick where you have the key generated by the program.
ID USB Lock Key Main Features:
• Generates a protection-key for each USB stick
• Blocks PC by simply pressing CTR+ALT+L
• Activates a block-screen after locking the PC
• Denies access to unauthorized users
• Preserves block-status even after reboot
Detailed features:
• Activates the block screen by just three steps. All you have to do, in order to have your PC protected, is to introduce your USB stick, generate a security private key and unplug the USB. Your computer then blocks any unauthorized access.
• Locks your computer by itself when your status becomes IDLE. You can choose to activate the blocking-mode by simply pressing CTR+ALT+L.
• ID USB Lock Key protects thoroughly by not allowing access not even after a reboot of your computer. It makes sure that your PC doesn’t reboot to its original unblocked status.
• Generates a unique protection key for one or more USB sticks. In case you loose your USB stick, or you want to allow access to another user on his/her private USB stick, the program will generate another unique key.
• Displays a lock screen. ID USB Lock Key displays a protection screen whenever someone else touches your computer, disabling any key from having any influence upon it.
• ID USB Lock Key has a convenient graphic interface which is very simple to use. It requires minimal space on your computer to operate efficiently.
System Requirements:
• Windows 98, Windows NT, Windows 2000, Windows XP, Windows Vista, Windows 7
• 300 Mhz processor
• 3 MB hard drive space
• 128 MB RAM
• Supports Internet Explorer
ID USB Lock Key program je určen pro zamknutí počítače před neoprávněným přístupem pokusů.
Blokovací mechanismus je jednoduchý při spuštění programu v zámku na obrazovce zobrazí zpráva na počítači je zamknutý a je zablokován veškerý přístup k němu, s generované a uložené na usb-disk je speciální tlačítko pro vypnutí zámku. Aktivace obrazovky zámku se koná ve třech krocích. Vše, co musíte udělat pro ochranu počítače - aby předložily své USB zařízení k výrobě bezpečnostní klíč a zatáhněte zařízení USB. Váš počítač bude zablokován před neoprávněným přístupem. Můžete si vybrat k aktivaci blokování režimu stiskem CTR + L. Hlavní program uzamkne počítač pomocí zařízení přes USV Klávesové zkratky CTR + ALT + DEL, je pohodlné grafické uživatelské rozhraní, které je velmi jednoduché použití, vyžadující jen minimální prostor na počítači pracovat efektivně.
ID USB Lock Key je bezpečnostní program za cíl chránit váš počítač před neoprávněnými uživateli. Popírá přístup, tím, že bezpečnostní blok-obrazovka, která může být odblokována s USB, kde máte klíč vytvořený program.
ID USB Lock Key Hlavní rysy:
• Generuje ochrany-klíč pro každý USB
• Bloky PC stiskem CTR + ALT + L
• Aktivuje-blok obrazovce po uzamčení počítače
• zakázání přístupu neoprávněným uživatelům
• Zachovává blok-stav i po restartu
Podrobné vlastnosti:
• Aktivuje bloku obrazovky pouze tři kroky. Vše, co musíte udělat, aby se váš počítač chráněn, je seznámit studenty s USB klíčenky, vytvářet bezpečnostní soukromý klíč a odpojte USB. Váš počítač pak blokuje neoprávněnému přístupu.
• Zámky počítač sám o sobě, pokud váš stav se stane IDLE. Můžete si vybrat k aktivaci blokování-režim stiskem CTR + ALT + L.
• ID USB Lock Key důkladně chrání tím, že umožňuje přístup a to ani po restartu počítače. Dbá na to, že váš počítač není restartu do původního stavu odblokování.
• Generuje unikátní ochranu klíče pro jeden nebo více USB zařízení. V případě, že ztratíte USB klíčenky, nebo chcete povolit přístup jinému uživateli na jeho soukromé USB, program bude generovat další unikátní klíč.
• Zobrazí zámek obrazovky. ID USB Lock Key ochranu obrazovky zobrazí vždy, když někdo dotkne vašeho počítače, vypnout všechny klíče od mít žádný vliv na to.
• ID USB Lock Key má pohodlné grafické rozhraní, které je velmi jednoduché použití. To vyžaduje minimální prostor na vašem počítači fungovat efektivně.
Systémové požadavky:
• 300 Mhz procesor
• 3 MB volného místa na disku
• 128 MB RAM
• Podporuje Internet Explorer
