Aktuálny čas je Str 30. Sep 2026 2:49:28
 Kerio WinRoute Firewall 6.7.1 Build 6399 [32bit & 64bit]
 Predmet príspevku: Kerio WinRoute Firewall 6.7.1 Build 6399 [32bit & 64bit]
PoslaťNapísal: Str 04. Nov 2009 14:57:48
Kerio WinRoute Firewall 6™ sets new standards in versatility, security and user access control. Designed for corporate networks, it defends against external attacks and viruses and can restrict access to websites based on their content.
Stateful network firewall
Kerio WinRoute Firewall offers detailed rule definition to perform stateful inspection of all outgoing and incoming Internet traffic. A network rules wizard assists in the rapid setup of the firewall. ..
Fast Internet sharing
Support for DSL, cable modems, ISDN, satellite, dial-up or wireless Internet allows administrators to deploy Kerio WinRoute Firewall in networks of all sizes and in all locations. Users can share one or multiple Internet connections.
Antivirus protection
Kerio WinRoute Firewall provides optional scanning of inbound and outbound HTTP and FTP traffic for viruses. In addition to a version with integrated McAfee security, there are several other anti-virus options to choose from.
Content and web filtering
In corporate and educational environments, it is often desirable to ban access to websites with offensive or counterproductive content. Kerio WinRoute Firewall has a built-in content classifier with a categorized database of websites powered by the Cobion Orange Filter Service.
Voice over IP support
Kerio WinRoute Firewall allows H.323 and SIP protocols to run behind it, eliminating the need to publicly expose the VoIP infrastructure to the Internet.
VPN support
Kerio WinRoute Firewall supports NAT traversal for IPSec and PPTP protocols, allowing a variety of third-party VPN solutions to be deployed easily.
UPnP support
Universal Plug and Play (UPnP) in Windows enables applications to communicate over the Internet. Kerio WinRoute Firewall integrates UPnP technology so that compliant applications such as MSN Messenger can run instantly without requiring additional configuration at the firewall.
Protocol inspection
Protocol inspection helps certain applications with proprietary protocols (not originally designed with firewall negotiation in mind) to be used in secured local area networks. Many protocols can be scanned, filtered or modified, thus increasing firewall restrictiveness and reporting capabilities.
Network administration
The administration console can be installed remotely to allow secure configuration from anywhere on the network.
Active Directory integration
Introduced in Windows 2000 Server, Active Directory allows administrators to centrally manage and share information on user accounts and network resources. Transparent support for Active Directory allows Kerio WinRoute Firewall to access user information in real time.
Here are some key features of "Kerio WinRoute Firewall":
· Antivirus control cleans HTTP, FTP, SMTP & POP3 traffic.
· Surf protection prevents users from accessing inappropriate websites.
· One-click Kerio VPN Client securely connects remote workers.
· Transparent proxy cache server speeds up web browsing.
· Forced firewall login allows for stringent user-specific policies for web access.
Kerio WinRoute Firewall 6 ™ nastavuje nové standardy v všestrannost, zabezpečení a řízení přístupu uživatelů. Určen pro podnikové sítě, se brání proti vnějším útokům a viry a může omezit přístup k internetovým stránkám, na základě jejich obsahu.
Stateful síťový firewall
Kerio WinRoute Firewall nabízí podrobnou definici pravidla pro výkon stavovou kontrolu veškeré odchozí i příchozí internetové komunikace. Průvodce komunikačními pravidly pomáhá při rychlé nastavení firewallu. ..
Pohodlné sdílení Internetu
Podpora pro DSL, kabelové modemy, ISDN, satelit, dial-up nebo bezdrátový internet umožňuje administrátorům nasadit Kerio WinRoute Firewall v sítích všech velikostí a ve všech místech. Uživatelé mohou sdílet jeden nebo více připojení k Internetu.
Antivirová ochrana
Kerio WinRoute Firewall nabízí možnost skenování příchozích a odchozích HTTP a FTP komunikaci na přítomnost virů. Kromě verze s integrovanou bezpečnostní společnost McAfee, existuje několik jiných anti-virus možností na výběr.
Obsahu a filtrování webového obsahu
V podnikových a vzdělávací prostředí, je často žádoucí zakázat přístup na webové stránky s urážlivým nebo kontraproduktivní obsah. Kerio WinRoute Firewall má zabudovaný-in obsahu Klasifikátor s databází kategorií internetových stránek poháněných Cobion Orange Filtr Service.
Podpora Voice over IP
Kerio WinRoute Firewall umožňuje H.323 a SIP protokolů běžet za ním, což eliminuje potřebu veřejně vystavit infrastruktury VoIP k Internetu.
Podpora VPN
Kerio WinRoute Firewall podporuje NAT pro IPSec a PPTP protokoly, což umožňuje řadu třetí stranou-řešení VPN, které budou nasazeny snadno.
UPnP
Universal Plug and Play (UPnP) v systému Windows umožňuje aplikacím komunikovat přes internet. Kerio WinRoute Firewall podporuje technologii UPnP, takže kompatibilní aplikace jako např. MSN Messenger můžete spustit okamžitě bez nutnosti další konfigurace na firewallu.
Protokol inspekce
Protokol kontrolní pomáhá některých aplikací s proprietární protokoly (ne původně navržen s firewallem jednání v mysli), které mají být použity v zabezpečených lokálních počítačových sítí. Mnoho protokolů může být kontrolována, filtrovat nebo změněna, čímž se zvýší firewall restrictiveness a reportování.
Správa sítí
Administrační konzole lze instalovat vzdáleně umožňoval bezpečné konfiguraci z libovolného místa v síti.
Integrace služby Active Directory
Zavedený v systému Windows 2000 Server, Active Directory umožňuje administrátorům centrálně spravovat a sdílet informace o uživatelských účtů a síťových prostředků. Transparentní podpora Active Directory umožňuje Kerio WinRoute Firewall pro přístup k informací o uživateli v reálném čase.
Zde jsou některé klíčové rysy "Kerio WinRoute Firewallu":
· Antivirová kontrola čistí HTTP, FTP, SMTP, POP3 & provoz.
· Surf ochrana zabraňuje uživatelům v přístupu k nevhodným webovým stránkám.
One-klikněte Kerio VPN Client připojuje bezpečně vzdálených pracovníků.
· Transparentní proxy cache server rychlostí až prohlížení webových stránek.
· Nucená firewall přihlášení umožňuje přísnější user-specifických politik pro přístup na web.
