Aktuálny čas je Pia 25. Sep 2026 3:14:54
 ArcaVir Home Protection 2010 10.10.3204.9
 Predmet príspevku: ArcaVir Home Protection 2010 10.10.3204.9
PoslaťNapísal: Pon 02. Nov 2009 7:06:45
ArcaVir is a comprehensive suite of intelligent tools that helps you protect your computer from Trojan horses, viruses, Internet Worms and other malware.
ArcaVir contains one of the largest libraries of detected viral definitions currently available. In the event of a threat, it is possible to immediately rate the level of danger and potential losses resulting from the activation of a detected virus.
ArcaVir Antivirus Monitor
ArcaVir Antivirus Monitor is a resident module that in the real time controls all the files executed and saved in the system, as well as used by external devices (e.g. floppy disks).
ArcaVir scanner
ArcaVir scanner is a tool providing a convenient and complete method of checking all the computer resources against virus infections. The program can be easily configured and freely adjusted to your individual needs, preferences and requirements.
ArcaMail mail scanner
The mail scanner is a program that interactively scans electronic mail whether receiving or sending. It can co-operate with any e-mail program via POP3 and SMTP protocols.
ArcaMail uses ainternal driver of the operating system. This solution guarantees high effectiveness (lower computer load) and eliminates the necessity of configuring e-mail accounts in an e-mail client program. ArcaMail has been designed so that it is integrated as part of the operating system.
Automatic Update Module
ArcaVir Update is a tool that allows automatic or manual updates of programs from ArcaVir.
Firewall
The Firewall included with ArcaVir antivirus program gives you an additional layer of protection. In the age of the Internet, a firewall is a essential part of any computer system, increasing your security and protecting your data from hackers. The ArcaVir Firewall was designed to be easy to use even by inexperienced users, but it was also designed to be highly configurable, and as such, it is a great tool for power users as well.
Registry monitor
Registry Monitor is an application used to control changes in neuralgic parts of the Windows Registry.
· RAM memory available for the program 64 MB
· Disk space: 60 MB
· Pentium-class processor
ArcaVir je komplexní sada inteligentních nástrojů, které vám pomohou chránit počítač před trojských koní, virů, internetových červů a dalšího škodlivého softwaru.
ArcaVir obsahuje jednu z největších knihoven zjištěných virových definic v současné době k dispozici. V případě ohrožení, je možné okamžitě kurz úroveň nebezpečí a potenciální ztráty vyplývající z aktivaci viru.
ArcaVir Antivirus Monitor je rezidentní modul, který v reálném čase kontroluje všechny provedené soubory a uložené v systému, stejně jako používá externí zařízení (např. diskety).
ArcaVir skener
ArcaVir skener je nástrojem, který poskytuje pohodlný a úplný způsob kontroly všech počítačových zdrojů proti virovým infekcím. Program lze snadno nastavit a svobodně nastavit podle vašich individuálních potřeb, preferencí a požadavků.
Kontrola pošty je interaktivní program, který prohledává elektronickou poštu, zda přijímání nebo odesílání. Může-pracovat společně s e-mailovým programem prostřednictvím protokolů POP3 a SMTP.
ArcaMail používá ainternal ovladač operačního systému. Toto řešení zaručuje vysokou účinnost (nižší zatížení počítače) a eliminuje nutnost nastavení e-mailových účtů v programu e-mailového klienta. ArcaMail byl navržen tak, že je integrována jako součást operačního systému.
Automatické aktualizace modulu
ArcaVir Update je nástroj, který umožňuje automatické nebo ruční aktualizace programů ze ArcaVir.
Firewall
Firewall je součástí ArcaVir antivirový program umožňuje další vrstvu ochrany. Ve věku internetu, firewall je důležitou součástí každé počítačového systému, zvýšení zabezpečení a chrání vaše data před hackery. ArcaVir Firewall je určen pro snadné použití i nezkušení uživatelé, ale to bylo také navrženo, aby byl vysoce konfigurovatelný, a jako takový, je to skvělý nástroj pro zkušené uživatele stejně.
Registry monitor
Registry Monitor je aplikace pro řízení změn v neuralgických částech registru systému Windows.
· Paměti RAM pro program 64 MB
· Místo na disku: 60 MB
Poznamänávam :
Komplex bezpečnostné systémy ako "NIS ako KIS atd" sú oproti tomuto softu "ArcaVir Home Protection 2010" iba malinký učni zo ZDŠ...
