Aktuálny čas je Štv 10. Sep 2026 6:01:24
 Returnil Virtual System 2010 Home Lux 3.0.6299.4937
 Predmet príspevku: Returnil Virtual System 2010 Home Lux 3.0.6299.4937
PoslaťNapísal: Pia 23. Okt 2009 20:36:35
Returnil Virtual System is a completely new product that uses a combination of antivirus, antimalware and a virtual system to protect your computer from all types of viruses and other malicious threats.
Returnil Virtual System uses an advanced anti-malware and virtualization technology. It clones (copies) your operating system and creates a virtual environment for your PC. Instead of loading the native operating system, a clone is loaded that allows you to run your applications and perform your online activities in an entirely isolated environment. In this manner, your actual operating system is never affected by viruses, Trojans, malware and other malicious threats. To return to the actual operating system environment, you just need to restart your PC. While working in the virtual environment, you have the option of saving documents and files so that your data will not be lost when the system is restarted.
* Detects and removes malware and other malicious threats
* On demand system virus scan
* Define your own exclusion list from the virus scan
* Clones (copies) the operating system and runs the cloned copy in a virtual machine
* Allows easy on-the-fly real-time system protection
* Reduces or eliminates the need for routine disk de-fragmentation
* Save or commit changes to individual files and folders while System Safe is ON
* No need to worry that your changes will be lost with restart
* Changes to folders also supported
* Ability to create and mount an alternate virtual disk/partition
* Saved files and other data will be retained after a restart
* Auto-mount with each system start
* Lock the interface with a custom password setting
* Keep inexperienced users from making changes to your settings
* Hide program user interface to prevent unauthorized usage
* Notifications of malware infections
* Reminders of activation code expiration date
* Other important messages to enhance your RVS experience
* Additional program level protection
* Dynamic Disk caching
* Access and browser for real disk and registry
* Quick overview of all settings
* Desktop Toolbar with right-click menu
* Program hot-key
* Languages: English, Japanese, Chinese (Simplified), Chinese (Traditional), Korean, German, Italian, Spanish, Russian, Polish, Dutch, Czech, Finnish (other languages coming soon, if you want to help, let us know)
* Intuitive, and simple User Interface
* User's Help Manual
What's New RVS 2010?
Instant System Recovery (System level virtualization)
System Safe in RVS 2010 is based on the same virtualization engine in RVS 2008 with a great deal of stability and functionality improvements.
Low Level sector protection
Protection for the MBR is retained and strengthened in RVS 2010
Protect alternate partitions
File Protection has been improved with stability enhancements in RVS 2010
Selective file and folder commit to disk
This feature is refined and has stability improvements in RVS 2010
Means to recover from a “Locked” system – via simple configuration change to turn off protection in safe mode
Emergency/troubleshooting option retained in RVS 2010
Undo or remove malicious and/or unwanted changes to your real System Partition
Preserves real system configurations
Automated commit to disk via customized list
Can use non-contiguous space for creation of disk cache
Anti-Execute control
The AE functionality in RVS 2010 is both improved and significantly simplified
Prevent malicious content from being written to your real hard disk
Real System file browsing
Windows Vista support
Stability and compatibility improvements added to RVS 2010
Windows 7 support
64-bit support
Integrated and simplified Returnil Tools
Returnil Tools in RVS 2008 have been simplified and completely integrated in the RVS 2010 program interface
Integrated Antimalware protection
more info RVS 2010 now includes integrated detection, blocking, and removal of malicious content. Further, the Virus Guard feature is designed to be compatible with your current AV solution
Automated product registration without reinstall (image) limitations
Self help password recovery
Remote client management
Enterprise and customer Management Console access
Network administrators as well as the average consumer now have the possibility to have access to remote management of their RVS client or clients from anywhere with an internet connection
Dynamic, on-the-fly caching using memory and disk in combination,
No need to pre-configure the size of your virtualization cache. Simply specify the maximum size you will allow it to reach and RVS 2010 will do the rest automatically
Real System registry browsing
Authorized users can now make changes to the real system registry while using RVS 2010 System Safe virtualization
Dopravit Efektivní Osoustava je zcela nový produkt, který využívá kombinace antivirus, antimalware a virtuální systém pro ochranu počítače před všemi typy virů a dalších škodlivých hrozeb.
Dopravit Efektivní Osoustava využívá moderní anti-malware a virtualizační technologie. Je klony (kopie) vašeho operačního systému a vytváří virtuální prostředí pro vaše PC. Místo nakládky původní operační systém, je klon naložené, který vám umožní spouštět aplikace a provádět své online aktivity ve zcela izolovaném prostředí. Tímto způsobem je vaše skutečná operační systém nijak neovlivní viry, trojské koně, malware a dalším záludným hrozbám. Pro návrat do skutečného prostředí operačního systému, stačí restartovat počítač. Při práci ve virtuálním prostředí, máte možnost ukládání dokumentů a souborů, takže vaše data nebudou ztracena při restartu systému.
Funkce:
* Detekuje a odstraňuje malware a dalším záludným hrozbám
* Na vyžádání systému virus scan
* Definujte svou vlastní seznamu vyloučení z antivirové kontroly
* Klony (kopie), operační systém a spouští klonované kopie ve virtuálním stroji
* Umožňuje snadné on-letu-real-time systém ochrany
* Snižuje nebo eliminuje nutnost používat běžné fragmentaci disku, de -
* Uložit nebo páchají změny na jednotlivé soubory a složky, zatímco systém Safe je NA
* Nemusíte se obávat, že vaše změny budou ztraceny s restart
* Změny složky také podporovány
* Schopnost vytvořit a připojit alternativní virtuální disk / oddíl
* Uložené soubory a další data budou zachovány i po restartu
* Auto-mount s každým systémem start
* Zámek rozhraní s vlastní nastavení hesla
* Mějte nezkušeným uživatelům v provádění změn v nastavení
* Hide program uživatelské rozhraní, aby se zabránilo neoprávněnému použití
* Oznámení o malware infekce
* Upomínky uplynutí aktivační kód, datum
* Další důležité zprávy pro zvýšení své zkušenosti RVS
* Doprovodný program úrovně ochrany
* Přístup a prohlížeč pro skutečné disku a registru
* Rychlý přehled všech nastavení
* Desktop Toolbar s pravým-click menu
* Program hot-key
* Jazyky: angličtina, japonština, čínština (zjednodušená), čínština (tradiční), korejština, němčina, italština, španělština, ruština, polština, holandština, čeština, finština (jiné jazyky brzy, pokud chcete pomoci, dejte nám vědět)
* Intuitivní a jednoduché uživatelské rozhraní
* Uživatelská příručka Nápověda
Co je nového RVS 2010?
Okamžité obnovení systému (na systémové úrovni virtualizace)
Systém Sejf v RVS 2010 je založena na stejném virtualizační technologie v RVS 2008 s velkou stabilitu a zlepšení funkčnosti.
Nízká úroveň ochrany sektor
Ochranu MBR je zachován a posílen v RVS 2010
Chraňte náhradní příčky
Ochrana souborů se zlepšil stabilitu vylepšení v RVS 2010
Selektivní souborů a složek na disk zavázat
Tato funkce je rafinovaný a zlepšení stability v RVS 2010
Znamená, aby se vzpamatovali ze "Locked" systém - pomocí jednoduché změny konfigurace vypnout ochranu v nouzovém režimu
Emergency / řešení problémů možnost uchovávat v RVS 2010
Zpět nebo odstranit škodlivý a / nebo nežádoucí změny svého skutečného oddíl systému
Zachovává reálné konfigurace systému
Automatizované zavázat na disk přes vlastní seznam
Lze použít non-sousedící prostor pro vytváření diskových cache
Anti-Execute ovládání
Funkce AE v RVS 2010 je tak lepší a výrazně zjednodušilo
Předcházet nebezpečným obsahem napsána na váš pevný disk v reálném
Real systém procházení souborů
Podpora pro Windows Vista
Stabilitu a kompatibilitu vylepšení přidány do RVS 2010
Windows 7 podpora
64-bit support
Integrované a zjednodušené Dopravit Nástroje
Dopravit Nástroje RVS 2008 byly zjednodušeny a plně integrován do rozhraní programu RVS 2010
Integrovaná ochrana Antimalware
více info RVS 2010 nyní obsahuje integrovanou detekci, blokování a odstraňování škodlivého obsahu. Dále se Virus stráž funkce, které mají být v souladu s aktuálním řešením AV
Automatizovaná registrace produktu bez přeinstalovat (obrázek) omezení
Svépomoci obnovení hesla
Vzdálená správa klientů
Podnikání a zákazník Management Console přístup
Správců sítí, stejně jako průměrný spotřebitel nyní mají možnost mít přístup ke vzdálené správy svého klienta RVS nebo klienty odkudkoliv s připojením na internet
Dynamická, on-letu-cache paměť a disk za použití v kombinaci,
Není potřeba nakonfigurovat pre-velikost cache virtualizace. Jednoduše zadejte maximální velikosti mu umožní dosáhnout a RVS 2010 udělá zbytek se automaticky
Real systémového registru procházení
Oprávnění uživatelé si nyní mohou provádět změny v reálném registru systému při použití RVS 2010 systému Bezpečné virtualizace
Každému z Vás tento unikát vrele odporúčam, lebo je to very very good product....
