Aktuálny čas je Sob 24. Okt 2026 22:12:25
 WiFi Attacking Tools 2009
 Predmet príspevku: WiFi Attacking Tools 2009
PoslaťNapísal: Sob 18. Júl 2009 9:03:52
The pack contains the MOST updated and licensed softwares.
1. AirCrack 2.1
Aircrack-ng is an 802.11 WEP and WPA-PSK keys cracking program that can recover keys once enough data packets have been captured. It implements the standard FMS attack along with some optimizations like KoreK attacks, as well as the all-new PTW attack, thus making the attack much faster compared to other WEP cracking tools. In fact, Aircrack-ng is a set of tools for auditing wireless networks.
2. AirSnort 0.2.6
AirSnort is a wireless LAN (WLAN) tool which recovers encryption keys. AirSnort operates by passively monitoring transmissions, computing the encryption key when enough packets have been gathered. 802.11b, using the Wired Equivalent Protocol (WEP), is crippled with numerous security flaws. Most damning of these is the weakness described in " Weaknesses in the Key Scheduling Algorithm of RC4 " by Scott Fluhrer, Itsik Mantin and Adi Shamir. Adam Stubblefield was the first to implement this attack, but he has not made his software public. AirSnort, along with WEPCrack, which was released about the same time as AirSnort, are the first publicly available implementaions of this attack.
3. AeroPeek 2.02
AiroPeek NX captures and decodes packets, with special emphasis on the 802.11 protocol. AiroPeek NX receives all wireless LAN packets based on user settable configuration parameters and stores these packets in memory. For example, you can set a filter to capture all packets, only 802.11 authentication request frames, or all frames except beacons frames. Just about any combination of packet types and protocols are possible.
Tento balíček obsahuje aktuální a licencovaný software.
1. Aircrack 2.1
Aircrack-ng je 802,11 WEP a WPA-PSK klíče krakovacího program, který umí obnovit klíče jednou dost datové pakety byly zachyceny. Implementuje standardní FMS útoku spolu s optimalizací, jako Korek útoků, stejně jako všichni-nový útok PTW, čímž útoku mnohem rychleji ve srovnání s jinými WEP krakovacího nástroje. Ve skutečnosti Aircrack-ng je sada nástrojů pro audit bezdrátových sítí.
2. AirSnort 0.2.6
AirSnort je bezdrátové LAN (WLAN) nástroj, který využívá šifrování klíčů. AirSnort funguje tak, že pasivně sledovat přenosy, počítače šifrovací klíč, kdy dost pakety byly shromážděny. 802.11b, s použitím Wired Equivalent protokolu (WEP), ochromována s řadou bezpečnostních nedostatků. Pádný Většina z nich je slabinou je popsáno v "Nedostatky v Key Plánování algoritmus RC4" by Scott Fluhrer, Itsik Mantin a Adi Shamir. Stubblefield Adam byl první k provedení tohoto útoku, ale neučinil jeho software veřejnost. AirSnort, spolu s WEPCrack, která byla vydána přibližně ve stejnou dobu jako AirSnort, jsou první veřejně dostupné implementaions tohoto útoku.
3. AeroPeek 2,02
AiroPeek NX zachytí a dekóduje pakety, se zvláštním důrazem na 802,11 protokol. AiroPeek NX obdrží všechny bezdrátové LAN pakety založené na uživatelských dláždění konfigurační parametry a ukládá tyto pakety v paměti. Například, můžete nastavit filtr pro zachycení všech paketů, jen 802,11 ověření žádosti snímků nebo všechny snímky kromě majáky snímků. Jen o libovolnou kombinaci typů paketů a protokolů je možné.
:mafia: :mafia: :mafia: :mafia: :mafia: :mafia: :mafia: :mafia: :mafia: :mafia: :mafia: :mafia: :mafia: :mafia:
Mojí ctený a mylí najlepší virtuálný priatelia osobitne "Dr.Thrax, Sisemen, Happyccol a šéf fóra Tomo" tu Vám dávam jeden excelentný produkt vyrobený našími dávnými bratmi s bývalého ZSSR, ktorým ak pomaly postupom času sa naučíte riadne zaobchádzane pracovat - !!! Zdôraznujem !!! - nič a nikto Vám už nebude stáť v ceste, aby ste sa nabúrali ku komukolvek trebárs i do tých najtajnejších serverov a získávali i tie najcitlivejšie informácie....!!! Proste stante sa pravými AGENTMI - VSS = Výzvedná Spravodajská Služba nie pre štátnú inštitúciu, ale pre samých seba, lebo kto pozná informácie ten dokáže s toho i čerpať prípadne i obchodovať - ale zároveň dodávam, že pred začatím týchto aktivít sa musíte velmi dokonale MASKOVANE POISTIT, aby ste nikdy nemohli byť odhalitelnými - ináč dá sa to - sú na to rôzné programové produkty....!!! A ináč Vám všetkým prajem predovšetkým jedine pävné zdravie, lebo jedine zdravie je tou najpodstatnejšou vecou v našom každodennom uponáhlanom a stresovom živote...majte sa.... .A.H.O.J. s pozdravom Váš virtuálný priateľ...PESTA....!!!
