Aktuálny čas je Sob 25. Júl 2026 5:58:50
 Advanced System Protector 2.0.323.1836
 Predmet príspevku: Advanced System Protector 2.0.323.1836
PoslaťNapísal: Pia 17. Júl 2009 22:09:38
Advanced System Protector description
An AntiSpyware with latest spyware definitions and realtime protection guards
Advanced System Protector is the latest security tool to protect your Windows System from all types of Spyware, Adware, Key Loggers, Browser Hijackers, Malware and other malicious programs that may be spying on your system. Advanced System Protector has Real Time guards, which can protect your Computer from any infection before it can cause any harm.
It is the most comprehensive tool for protection from Spyware as it can scan, detect and remove even the most deep-rooted infections from your system. There are regular updates so that the Real Time guards are well equipped with definitions and the can well monitor your PC against any spyware threat. The already prepared database protects you from hundreds of thousands Spyware, Malware and Adware, keeping your data protected.
We keep you safe, today, tomorrow and always.
Here are some key features of "Advanced System Protector":
· Advanced System Protector has been designed to Quick Scan your System and Deep Scan your System. Both these scans are a good way to check your PC for infections. A Quick Scan has been designed so that you can check your PC every morning, without spending much time on the scan. This will check for infections by the file path and warn you in case of any infections found. A Deep Scan should be performed on the first installation of Advanced System Protector, and then on a weekly basis. This is a thorough scan for your computer, where the files and folders are searched for infection on the basis of file path and MD5, a file recognition technology. In case an infection is found, you have the option to remove, ignore, quarantine or delete it, as per your choice.
· Real Time Guards have been designed to continuously monitor your computer for any suspicious activity. These guards monitor the most vulnerable areas of your computer, which may be the gates for most infections. These guards are more active when you are browsing the Internet, opening files or executing applications and programs.
Real Time Guards:
· BHO Guard
· This guard monitors the plug-ins installed in Internet Explorer and warns you when a new plug-in wants to install itself.
· AppInit DLL Guard
· The DLL files, which control the Application Initiation, are monitored by this guard. This ensures that no application gets listed in your Auto-Start list without your permission.
· Winlogon Shell Guard
· This guard is similar to the previous. It monitors the Windows Shell Registry setting and prevents any application from being loaded at the Windows Startup.
· Hosts File Guard
· This guard monitors the Hosts file and restricts changes to it. This means that you can get rid of most automatic and unwanted browser redirects.
· IE Trusted Sites Guard
· Internet Explorer keeps a list of trusted sites, where the browser permits less secure browsing. This guard keeps a check on this list and restricts any website from getting listed here without your permission.
· IE Home Page Guard
· This guard ensures that when you start your computer, you get to see the home-page that you have set in your computer, and not any unwanted home-page designed to lure you into a trap.
· Running Process Guard
· This guard prompts you to allow or restrict the execution of any new processes in your task list, ensuring that no malware starts automatically on your computer.
· Startup Guard
· This guard is designed to stop any unwanted and malicious software from entering the startup folder, preventing any malware to execute at the start of your system.
· Startup Registry Files Guard
· This guard monitors the Registry files for any changes and prompts you to authorize or restrict any suspicious change.
· Advanced System Protector can quarantine any spyware ormalware detected on your computer to safeguard your system. This means that the files are placed in a safe vault, with their format changed. These files can not cause any harm to your computer anymore because they are not in their original format. The quarantine is designed to ensure that the spyware which are embedded in other applications, are prevented from execution or causing harm, without stopping the application to function.
Pokročilý systém Protector je nejnovější bezpečnostní nástroj pro ochranu vašeho systému Windows od všech typů spyware, adware, zaznamenávání stisknutých kláves, Browser únosců, malwaru a dalších škodlivých programů, které mohou být špionáže ve vašem systému. Pokročilý systém má Protector Real Time stráže, který může chránit váš počítač před infekce dříve, než může způsobit újmu.
Jedná se o nejkomplexnější nástroj pro ochranu před spywarem, jak je možné skenovat, odhalovat a odstraňovat i ty nejnáročnější hluboko zakořeněné-infekce ze systému. K dispozici jsou pravidelné aktualizace, takže v reálném čase stráže jsou dobře vybaveny definice a lze dobře sledovat svůj počítač proti spyware žádné ohrožení. Již připravené databáze chrání vás z statisíce Spyware, Malware a Adware, udržet vaše data chráněna.
Rádi Vás v bezpečí, dnes, zítra a vždy.
Zde jsou některé klíčové rysy "moderní systém Protector":
Advanced Protector systém byl navržen tak, aby Quick Scan vašeho systému a Deep Scan systému. Oba tyto skeny jsou dobrým způsobem, jak kontrolovat vaše PC k infekcím. A Quick Scan byla navržena tak, že můžete kontrolovat vaše PC každé ráno, bez výdajů moc času na testování. To bude pro kontrolu infekcí, které cestu k souboru a upozorní vás v případě infekce nalezena. A Deep Scan by mělo být provedeno na první instalaci systému Pokročilá Protector, a pak každý týden. To je důkladné skenování počítače, kde se soubory a složky jsou vyhledávány infekce na základě cestu k souboru a MD5, soubor uznání technologie. V případě infekce je nalezena, máte možnost odstranit, ignorovat, karantény nebo smazat, pokud na vaší volbě.
Real Time gardy byly navrženy tak, aby průběžně sledovat váš počítač pro jakoukoli podezřelou aktivitu. Tyto kryty sledovat nejvíce ohrožených oblastí vašeho počítače, což může být brány pro většinu infekcí. Tyto kryty jsou více aktivní, pokud jste procházení internetu, otevírání souborů nebo spuštění aplikace a programy.
Real Time kryty:
BHO stráže
Tato stráž kontroluje plug-ins instalované v Internet Explorer a upozorní vás, když se nový plug-in chce nainstalovat sám.
AppInit DLL stráže
Soubory DLL, které ovládání aplikací Zahájení, jsou sledovány této stráže. Tím je zajištěno, že žádná aplikace dostane uvedené ve vašem Auto-Start seznamu bez Vašeho souhlasu.
Winlogon Shell stráže
Tento kryt je podobný předchozímu. Sleduje Windows Shell nastavení registru a zabraňuje používání od naložením v spouštění systému Windows.
Soubor Hosts stráže
Tato stráž kontroluje soubor Hosts a omezuje se na změny. To znamená, že můžete zbavit většiny automatických a nechtěné browser redirects.
IE Důvěryhodné servery stráže
Internet Explorer vede seznam důvěryhodných míst, kde je méně bezpečný prohlížeč umožňuje prohlížení. Tato stráž drží šek na tomto seznamu, a omezuje jakoukoli webovou stránku ze seznamu dostat bez Vašeho souhlasu.
Hlavní strana IE stráže
To zajišťuje, že stráže při spuštění počítače, můžete si zobrazit home-stránku, kterou jste nastavili ve vašem počítači, a nemají žádné nežádoucí home-stránku navržen tak, aby vás lákat do pasti.
Spuštění procesu stráže
Tento strážný vyzve k povolit či zakázat provedení jakýchkoli nových procesů ve vašem seznamu úkol zajistit, aby žádný malware automaticky spustí ve vašem počítači.
Spouštěcí stráže
Tento kryt je určen pro zastavení jakéhokoli nechtěného a škodlivého softwaru od vstupu do složky Po spuštění, zabraňováním malware vyřídit na začátku svého systému.
Spouštěcí soubory registru stráže
Tato stráž kontroluje soubory registru pro případné změny a vyzve vás k povolit nebo omezit jakékoli podezřelé změně.
Pokročilý systém Protector může karantény žádné spyware ormalware zjištěny na počítači pro ochranu vašeho systému. To znamená, že soubory jsou umístěny v bezpečném trezoru, se jejich formát změnit. Tyto soubory nemohou způsobit újmu na svém počítači, protože už nejsou v jejich původním formátu. V karanténě je navržen tak, aby se zajistilo, že spyware, které jsou zakotveny v jiných aplikacích, je zabráněno spuštění nebo poškozuje, bez zastavení aplikace fungovat.
