Aktuálny čas je Štv 29. Okt 2026 9:38:49
 Rohos Logon Key 2.5.0.0-1000% ZÁBEZPEKA
 Predmet príspevku: Rohos Logon Key 2.5.0.0-1000% ZÁBEZPEKA
PoslaťNapísal: Sob 13. Jún 2009 15:33:33
It converts any USB drive into a security token for your computer and allows to access Windows in a secure way by USB token, replacing the Windows login.
Your Computer security benefits:
1. Replaces weak password based login with a hardware USB key (USB flash drive or memory card)
2. Uses big password, without the need for remembering it
3. Login with a USB Key is fully automatic and fast!
4. The system is password protected but you don’t need to enter it manually each time you log in or unlock Windows
5. Secure 2-factor login: Your USB Key + PIN code password
6. Use a single USB Key to sing-in into your Home, laptop and office computer
7. Access restriction to computer based on USB Key/time factor
8. Windows is protected even in Safe Mode
9. Assigning a password to your user account allows to set a better protection for hibernated computer.
No risk because of:
1. Emergency Logon that helps to access your system in case you lost USB drive or forgot PIN code
2. PIN code to protect USB Key against unauthorized usage for login (with limited attempts to enter)
3. Safe Mode guard - no chance for Bad Guy to bypass USB Key security by loading Windows in Safe Mode
4. Rohos uses NIST approved data-security principles: password is not stored on the USB Key in open form, USB Key copy protection does not allow to create unauthorized Key duplicates; All data on the Key are encrypted with AES-256 bit key length.
Basic program features explained:
Rohos replaces your Windows login/password with a USB Key. Regular password based login can be prohibited
As USB Key you can use your USB flash drive, U3 Smart flash drive or SD/MMC memory card
Automatic login or unlock when USB Key is detected
Automatic Windows lock when user withdraws USB Key from computer. And more options for what you would like to happen whenever the USB key is removed, such as go into hibernation, activate Screen Saver, Logoff.
[Unique] Protects your computer even in Windows Safe Mode login. It is not possible to bypass USB Key security by loading computer into Safe Mode.
Flexible USB Key options: A single Key can be used to log in into multiple computers - OR - A computer can accept only a single Key for login, ignoring stranger keys.
Restricts access to a PC for certain users based on time factor. Access is limited to a certain amount of time user can stay logged in. When the user’s time is up, Rohos will lock the desktop automatically.
Special options for corporate customers: 60-day trial period, Installation guide, MSI package, Server version with USB Key Management utility.
Authentication integrated within the Windows Logon
Rohos integrates into Windows logon model, USB key for password-less login Rohos integrates into any Windows logon configuration (model): Local computer logon or AD network joined workstation, Windows XP/Vista home computer, Novell Client login, Remote desktop login. Thus, no compatibility problems will be encountered after installing Rohos.
Completely simulate Smart Card logon
In comparison with Smart Card Logon, Rohos Logon Key provides you with more functions that are easier to use. In corporate networks environment Rohos can stop users to use USB login key to store and transmit personal files.
Corporate data security
The Rohos Logon Key can be configured to block the USB flash drive (that is used as a login Key) or any removable media drive from user access. This protects your company from information theft.
Rohos Logon Key is considered to be the most convenient, user-friendly and smart password replacement application on the market.
Převádí jakoukoli USB disk do bezpečnostní token pro váš počítač a umožňuje přístup k Windows v bezpečným způsobem pomocí USB token, nahrazující Windows přihlásit.
Zabezpečení počítače:
1. Nahrazuje slabé přihlašovací heslo založené s hardwarovým USB klíč (USB flash disk nebo paměťové karty)
2. Používá velké heslo, aniž by bylo nutné jej pamatováním
3. Přihlásit se USB klíč je plně automatická a rychle!
4. Systém je chráněn heslem, ale nemusíte zadávat ručně pokaždé, když se přihlásíte do systému Windows nebo odemknout
5. Secure 2-faktor login: Vaše klíč USB + PIN kód heslo
6. Použití jediného USB klíč zpívat-in do svého domova, notebooků a kancelářské počítače
7. Omezení přístupu k počítači založené na USB klíč / časový faktor
8. Windows je chráněn ani v nouzovém režimu
9. Přiřazení hesla ke svému uživatelskému účtu umožňuje nastavit lepší ochranu hibernated počítače.
Žádné riziko, protože:
1. Nouzové přihlášení, které slouží k přístupu svůj systém v případě, že jste ztratil USB disk, nebo zapomněl PIN kód
2. PIN kód pro ochranu USB klíče proti neoprávněnému použití pro přihlášení (s omezenými pokus o vstup)
3. Nouzový režim stráž - bez šance na Bad Guy obejít USB klíč zabezpečení načtením Windows v nouzovém režimu
4. Rohos používá schválený NIST data-bezpečnostní zásady: heslo není uložen na USB klíč ve volné formě, USB klíč ochranu proti kopírování neumožňuje vytvářet nepovolené Klíčové duplikátech; Všechny údaje na klíč je zašifrován pomocí AES 256-bit klíčem délky.
Základní funkce programu vysvětluje:
Rohos nahradí Windows jméno a heslo k účtu s USB klíč. Pravidelné založené přihlašovací heslo může být zakázán
Jako USB klíč můžete použít USB flash disk, U3 Smart flash disk nebo SD / MMC paměťové karty
Automatické přihlášení nebo odemknout, když USB klíč je detekován
Automatický zámek Windows, když uživatel stáhne USB klíče z počítače. A více možností pro to, co byste chtěli dojít kdykoli USB klíč je odstraněna, jako jít do hibernace, aktivuje spořič displeje, Odhlásit.
[Unikátní] Chrání počítač ani v nouzovém režimu Windows přihlásit. Není možné, aby obchvat USB klíč zabezpečení nakládky počítač do nouzového režimu.
Flexibilní USB klíč možnosti: A jediný klíč lze použít k přihlášení do více počítačů - nebo - počítač může přijmout pouze jediný klíč pro přihlášení, zanedbáním cizí klíče.
Omezuje přístup k počítači pro některé uživatele založené na časový faktor. Přístup je omezen na určitou dobu uživatel může zůstat přihlášen Když uživatel čas vypršel, Rohos se zámkem na ploše automaticky.
Speciální možnosti pro firemní zákazníky: 60-denní zkušební doba, instalační příručka, MSI balíček, Server verze s USB klíčů utility.
Autentizace integrovaný do systému Windows Logon
Rohos integruje do Windows přihlašovací model, USB klíč pro přihlášení heslem-méně Rohos integruje do libovolné Windows přihlašovací konfigurace (model): Lokální počítačové sítě AD přihlášení nebo vstoupily stanici, Windows XP / Vista doma počítač, Novell Client login, vzdálené ploše přihlášení. Tudíž žádné problémy s kompatibilitou se setkaly po instalaci Rohos.
Kompletně simulovat Smart Card pro přihlášení
Ve srovnání s Smart Card Logon, Rohos Logon Klíč vám poskytuje další funkce, které jsou jednodušší použití. V podnikových sítích Rohos prostředí lze zastavit uživatelé použít USB klíč k přihlášení ukládat a přenášet data.
Firemní zabezpečení dat
V Rohos Logon Klíčové může být nakonfigurován tak, aby blokoval USB flash disku (který se používá jako přihlašovací klíč) nebo jakákoliv výměnná média řídit z uživatelského přístupu. To chrání vaše firma z informací krádeží.
Rohos Logon klíč je považován za nejvíce pohodlné, uživatelsky přívětivé a chytré-náhradní heslo aplikace na trhu.
