Aktuálny čas je Pia 24. Júl 2026 17:31:57
 Chcete mat 1000% čistý PC-Komp ...? Tak si nahodte toto
 Predmet príspevku: Chcete mat 1000% čistý PC-Komp ...? Tak si nahodte toto
PoslaťNapísal: Ned 19. Apr 2009 10:34:16
Dangerous and annoying spyware can infect your pc in many different ways when you use the internet.Spyware grows more sophisticated everydayExperts agree: Malware Guard gives you the most advanced spyware detection, blocking and removing threads as you browse.If your PC is already infected malware Guard's advanced discovery algorithms find completely and destroy malicious spyware that hide with in your system.
* Scans for almost all spyware components out there today!
* Easy to use (just one click of a mouse)
* Does not require a reboot to remove all traces
* Disconnects the threat without disconnecting you
* Backup and restore removed items
* Multi – Language Support
* List (Found items can be skipped and ignored)
* Also features BHO manager
* Also features startup manager
* Protects itself from malware tampering or shutdown
* Automates updates free to keep you protected from the easiest threat.
Advanced Features:
1. The Fastest scanning algorithm technique in the market
2. New amazing easy-to-navigate interface
3. New results design shows all properties of each detected thread info thread
4. A wide range of actions to perform with detected thread (remove /quarantine)
5. A set scan for options you can highly customize the program (Quick ,Deep and Custom)
6. Instant detailed Description (help) for each item in the program
7. Active Protection stops spyware programs before they can run
8. A System–Wide Real-time system protection. (Shields)
9. Shreds the detected spyware threats files and folders
10. Scans all user accounts
11. Protects the hosts file from modifications
12. Monitors the IE toolbars installations
13. Managers the startup entries in your system
14. Managers the browser Helper Objects in your system
15. Managers the hosts file entries
16. Managers IE Toolbars
17. Immediately suspend the detected malicious processes
Nebezpečný a otravný spyware může nakazit váš procent v mnoha jiných cestách kdy vy užíváte internet.Spyware roste důmyslnější everydayExperts souhlasit: Malware Guard dává vám nejpokročilejší spyware odhalení, blokování a odstranění nití jak vy brouzdáte.Jestli váš PC je již infikovaný malware Guard- ovo pokročilý algoritmus objevu najdou úplně a zničit záludný spyware který zakrýt ve vašem systému.
Rysy:
* snímání téměř všechno spyware součásti venku dnes!
* snadno použitelné (jediné kliknutí myši)
* nepožaduje restart k tomu, aby odstranil všechny stopy
* přeruší spojení hrozbu bez odpojení vás
* zálohování a obnoví odstraněné položky
* multi - – jazyková podpora
* seznam (nalezené položky mohou být skáčou a ignorovaný)
* také uvádí BHO manažera
* také uvádí startovního manažera
* ochrany sám z malware falšování či přerušení práce
* zavádějte automatizaci update k bezplatnému držení vy jste chránili před nejsnadnější hrozbou.
Pokročilé rysy:
1. Fastest skenovací technika algoritmu na trhu
2. Nový úžasný snadný--navigovat rozhraní
3. Nové výsledky navrhují přehlídky veškeré vlastnosti každé objevené informací niti niti
4. Široké akční rádiy k tomu, aby vykonávaly s objevenou nití (odstraní /karanténu)
5. Stanovené snímání pro volby, které vy můžete vysoce přizpůsobit program (rychlý ,hlubina a zvyk)
6. Okamžik podrobná popis (pomoc) pro každou položku v programu
7. Aktivní Protection se zastaví spyware programy předtím, než oni mohou běžet
8. A System–Wide Real - time ochrana systému. (štíty)
9. Roztrhává objevené spyware hrozby soubory a složky
10. Skenuje všechny uživatelské účty
11. Chrání hostitele soubor z modifikací
12. Monitoruje IE lišty s nástroji instalace
13. Manažeři startovní položky ve vašem systému
14. Manažeři prohlížečový Helper Objects ve vašem systému
15. Manažeři hostitelé registrují položky
16. Manažeři IE lišty s nástroji
17. Ihned odložte objevené záludné procesy
