Aktuálny čas je Ned 25. Okt 2026 11:51:07
 Digeus Software Pack AIO - 10 Software
 Predmet príspevku: Digeus Software Pack AIO - 10 Software
PoslaťNapísal: Ned 28. Feb 2010 7:50:51
Digeus Software Pack AIO - 10 Software - 15 MB
System Optimizer
Registry Cleaner
Junk Files Cleaner
Duplicate Files Finder
Registry Defragmenter
Privacy Protection
Jet Email Extractor
Image Resizer
SnapIt Screen Capture
Online TV Player
System Optimizer
Digeus System Optimizer is the smartest way to solve computer problems and protect your valuable data. This easy-to-use software helps you eliminate system crashed, prevent computer problems, and restore your system to a healthy state.
Eliminates system crashes, freezes and slowdowns
Automatically identifies and repairs common Windows problems
Easy to download, install and use
Free support and service
Registry Cleaner
Your PC crashes for no apparent reason. You keep receiving error messages and don't know why. Your PC runs much slower than when you first bought it. Are you frustrated by your computer's bad performance? Do you really want an instant solution?
Problems with the Windows Registry are a common cause of Windows crashes and error messages. Registry problems can occur for many reasons, including references left behind after uninstalling; incorrect removal of software; missing or corrupt hardware drivers; or orphaned start-up programs. This will significantly increase the Registry size and slow down your computer, because Windows will need more time to load, search, and read data from the Registry.
Before you start looking for a new computer, try running a Digeus Registry Cleaner on your system to repair the backbone of your machine. Computers perform best when they receive regular and professional maintenance.This award winning software starts by conducting a deep scan of your registry, checking for file extension errors and other registry conflicts. With Digeus Registry Cleaner you'll see immediate increases in performance and decreases in system conflicts.
Junk Files Cleaner
Junk Files Cleaner is a user friendly, fast and easy to use application developed to free up disk space by deleting junk files that are no longer used by any software on your system. Even the least experienced user can easily remove junk files with this tool.Your hard drive is littered with junk files you don't need, taking up precious hard disk space, and potentially slowing down your PC's performance. There are files of all kinds, such as temporary files that applications should delete when they're no longer needed, various log files, index files, backup files etc. You'd be amazed at how much space these junk files take up.By cleaning your disk with Junk Files Cleaner, your computer will run faster, and you won't have to worry as much about filling your hard drive and replacing it with a newer, bigger one.Junk Files Cleaner can identify more than 50 types of junk files, and you can extend the range by adding your own file types. The program only deletes the files that you tell it to. You can choose to have the files permanently deleted, or first moved to the Recycle Bin. You'll be amazed at how much hard disk space this program can gain for you, so automatically got back plenty of hard disk space.
Duplicate files on your computer waste valuable hard disk space required for smooth performance. Digeus Duplicate Files Finder eliminates duplicate files and increases the free disk space needed to ensure optimal computer performance. Digeus Duplicate Files Finder:
Regains critical hard disk space. It finds and deletes duplicate files in order to regain valuable hard disk space required for smooth computer operation.
Saves time. Reduces time needed to defragment your hard drive and minimizes time used by antivirus software to scan your computer
Registry Defragmenter is fast becoming a useful and essential tool in keeping your registry defragmented. With compacted and optimized Registry you will be amazed at the speed your computer will perform.Registry Defragmenter will rebuild and re-index your registry to eliminate structural mistakes and corruption.It will significantly speed up your computer by helping you defragment registry, remove gaps, and make it contiguous, smaller and faster to access.The Windows Registry constantly grows as data is added to it, but it never shrinks when data is removed. A bloated registry with a lot of empty space in it can slow down the boot time as well as performance of the entire system.The registry is fully kept in the memory when your PC is running. Memory on your PC is much smaller than disk space and the more bloated the Registry becomes, the less space there is for other programs to run. Knowing that, it should not come as a surprise to you that Windows Vista or XP runs noticeably slower after a few months of work.
Privacy Protection
You browse the web, shop online, watch video of anything you do on your computer gets recorded. Privacy Protection utility will erase all tracks. Clean up your PC now!
Every move you make on your computer leaves tracks behind. These tracks contain information about which web sites you visited, which programs you used, which files you opened and much more.
In the wrong hands this data can be used against you. Take action today by clearing these types of data from your system for good. At the same time you will enjoy an increase in browser stability and performance.Privacy Protection utility is designed to protect you by cleaning up all the unwanted history data on your computer. With simply one click, Privacy Protection utility allows you to erase the cache, cookies, history, typed URLs and much more.Privacy Protection utility also acts as a system optimization tool - it can remove unused and temporary files from your system, allowing it to run faster and more efficiently, freeing up more hard-disk space.Privacy Protection utility allows you to regain your computer's privacy with ease. This simple tool cleans your tracks with a single click. The program deletes only the types of tracks you select. After your tracks are cleared, your privacy will be more secure and your browser will run much faster.
Jet Email Extractor
Want to start your email marketing campaigns? Have something to sell, a cause to promote, a service to provide? Whether you're looking to send an email newsletter, a high-impact email promotion, an email event invitation, an online survey, or build your email list, discover how Digeus Jet Email Extractor can help you get it done.
Digeus Jet Email Extractor is a great helper in conducting email marketing campaigns. Every email campaign requires large lists of email addresses. It's almost impossible to extract the email addresses manually. It was designed to collect targeted email addresses of potential customers to boost your sales and revenue.
Digeus Jet Email Extractor will build huge targeted mailing lists. It connects to lots of news servers and retrieves email addresses from the headers of each and every article in chosen target-related newsgroups.
Image Resizer
Digeus Image Resizer is the perfect tool for those who store dozens of digital pictures and images on their PC and who want to resize, compress, convert, create copies, import or organize photos.
With this resize image software, you can create e-mail friendly versions of your images, load them faster, move them easily from folder to folder; edit large numbers of image files/batch image resize and thus save space on your hard drive. Digeus Image Resizer can also change file names using a template.
Working with Digeus Image Resizer is quite simple. Launch the program. Add files for conversion. Specify conversion options and destination path for saving files and press "Convert" button. This is all you need to know to successfully use the program and get professional results.
Digeus Image Resizer can convert JPEG, JPG, JPE, JFIF, BMP, DIB, GIF, TIF, TIFF, PNG format without limiting image size and image amount. Even Huge images can be converted!
Working with huge images is now limited only by your hard drive size.
Capture anything you see on your PC screen!
Don't waste time cropping your captures. Take a "snapshot" of anything exactly what you need, with just a click.
Easy to Learn, Easy to Use!
Online TV Player
Online TV Player is the best available software online today to watch thousands of satellite movies and listen to radio channels from all over the globe. You don’t need a satellite dish, receiver, or any cable or satellite service! All you need is an internet connection and a computer.
Watch local TV, world TV, Live TV, satellite TV from countries of all over the world in different languages on your PC with Online TV Player not just at home, but at the office, work or wireless. Watch anywhere you have your internet Online. Get immediate access to thousands of free streaming Internet TV channels, Online Radios.
We include the widest available variety of genres: music, sports, news, comedy, romance, live shows, erotic cinema, adults, action, novels, series.... you, always, will be able to find a station or channel according to your state of spirit.
Watch all these channels anywhere in the world. More than 100,000 users are already enjoying the incredible variety.
Digeus Software.rar (12,8 MB)
pass : KEY_LOGGER
Digeus Software Pack AIO - Software 10 - 15 MB
System Optimizer
Registry Cleaner
Nevyžádaná Files Cleaner
Defragmentace registru
Ochrana soukromí
Jet Email Extractor
Image Resizer
Online TV Player
System Optimizer
Digeus System Optimizer je nejchytřejší způsob, jak vyřešit problémy s počítačem a ochránit vaše cenná data. Tento bezstarostný-až k-použitelný software pomáhá eliminovat systém zhroutil, předcházení problémů s počítačem a obnovit systém do zdravém stavu.
Eliminuje zhroucení systému, mrznout a zpomalení
Automaticky identifikuje a opravy společných problémů Windows
Snadné stahování, instalace a použití
Bezplatná podpora a servis
Registry Cleaner
Váš počítač havaruje bez zjevného důvodu. Dostáváte chybové zprávy a nevím proč. Počítači běží mnohem pomaleji, než když jste poprvé koupil. Jste frustrovaný počítače špatný výkon? Opravdu chcete okamžité řešení?
Problémy s Windows registru jsou častou příčinou nehod Windows a chybové zprávy. Registru, může dojít k problémům z mnoha důvodů, včetně odkazů zanechal po odinstalování, nesprávná triviální, poškozen nebo ovladače hardwaru, nebo osiřel start-up programů. Tím se výrazně zvýší velikost registru a zpomalit počítač, protože systém Windows bude potřebovat více času, aby zatížení, vyhledávat a číst data z registru.
Než začnete hledat nový počítač, zkuste Digeus Registry Cleaner na váš počítač k opravě páteř vašeho stroje. Počítače fungují nejlépe, když se jim dostane řádné a odborné maintenance.This oceněný software začíná tím, že provádí hlubokou kontrolu svého registru, kontrola chyb příponu souboru registru a dalších konfliktů. S Digeus Registry Cleaner uvidíte okamžité zvýšení výkonu a snížení systému konfliktů.
Nevyžádaná Files Cleaner je uživatelsky příjemný, rychlý a snadno použitelné aplikace vyvinutá na volné místo na disku odstraněním nevyžádané soubory, které se již nepoužívá žádný software na vašem systému. Ještě nejméně zkušený uživatel může snadno odstranit nevyžádané soubory s touto tool.Your pevný disk je poseté nevyžádanou souborů nepotřebujete, které se zakládají drahé místa na pevném disku, a potenciálně zpomalit výkon počítače. Tam jsou soubory všeho druhu, jako jsou dočasné soubory, které aplikace by měly odstranit, když to již nejsou potřebné, různých log soubory, indexové soubory, záložní soubory apod. byste překvapeni, kolik místa tyto nevyžádané soubory zabírají up.By čištění disku s nevyžádané Files Cleaner, počítač běžet rychleji, a nebudete muset starat tolik o vyplnění vašeho pevného disku a jeho nahrazením novějším, můžete větší one.Junk Files Cleaner identifikovat více než 50 druhů smetí soubory a můžete rozšířit řady přidáním vlastních typů souborů. Program odstraní pouze soubory, které vám to říct. Můžete si vybrat, které soubory trvale zrušen, nebo přesunut do prvního koše. Budete překvapeni, kolik místa na pevném disku tohoto programu můžete získat pro vás, tak se automaticky vrátila spousta místa na pevném disku.
Duplicitní soubory na vašem počítači odpadů cenné místo na pevném disku potřebné pro plynulý chod. Digeus Duplicate Files Finder eliminuje duplicitní soubory a zvyšuje volného místa na disku potřebné pro zajištění optimálního výkonu počítače. Digeus Duplicate Files Finder:
Získává kritická místa na pevném disku. To najde a odstraní duplicitní soubory, aby znovu získali cenné místo na pevném disku počítače potřebné pro hladký provoz.
Šetří čas. Zkracuje čas potřebný k defragmentaci pevného disku a minimalizuje čas, který antivirový program ke skenování počítače
Defragmentace registru se rychle stává užitečným a nezbytným nástrojem na udržení svého defragmentace registru. S zpevněné a optimalizované registru budete ohromeni rychlosti vašeho počítače bude perform.Registry Defragmentace obnoví a re-index registru odstranit strukturální chyby a corruption.It výrazně zrychlí Váš počítač pomáhá defragmentaci registru, odstranit mezery, a učinit z ní nesousedí, menší a rychlejší access.The registru Windows neustále roste, jak data jsou k ní, ale nikdy se snižuje, pokud je odstraněn dat. Nafouklý registru se spoustou volného prostoru na to může zpomalovat start systému, stejně jako výkon celé system.The registru je plně uložen v paměti, kdy počítač běží. Paměť na PC, je mnohem menší než místo na disku a více nadutý kanceláři se stává, že je menší prostor pro jiné programy spustit. S vědomím, že by nemělo překvapovat, že vám systém Windows Vista nebo XP běží znatelně pomaleji po několika měsících práce.
Ochrana soukromí
Procházení webu, nakupování on-line, sledování videa na cokoliv, na co v počítači dostane zaznamenána. Ochrana soukromí utility smaže všechny stopy. Clean up your PC now!
Každý pohyb uděláte na počítači za sebou nechává stopy. Tyto stopy obsahují informace o tom, které webové stránky, které jste navštívili, které programy jste použili, které soubory se otevřely a mnoho dalšího.
V nesprávných rukou tato data mohou být použito proti vám. Přijmout opatření dnes zúčtování těchto typů dat z vašeho systému pro dobré. Současně se vám bude líbit zvýšení stability prohlížeče a ochrany performance.Privacy nástroj je navržen tak, aby tě chránil by vyčistit všechny nežádoucí historii data v počítači. S pouze jedním kliknutím, ochrana soukromí utilita vám umožní vymazat cache, cookies, historie, napsaný URL a mnoho more.Privacy ochrany užitné působí také jako nástroj pro optimalizaci systému - je možné odstranit nepoužívané a dočasné soubory z vašeho systému, což mu umožnilo pracovat rychleji a efektivněji, uvolňovat více hard-disk space.Privacy Ochrana utilita vám umožní získat počítače soukromí s lehkostí. Tento jednoduchý nástroj, který čistí vaše skladby s jediným kliknutím. Program vymaže pouze typy tratí si zvolíte. Po stopy jsou vymazány, budou vaše osobní údaje budou bezpečnější a prohlížeč bude probíhat mnohem rychleji.
Jet Email Extractor
Chcete začít vaší e-mailové marketingové kampaně? Mají něco prodat, způsobit, aby podporovaly, služby poskytovat? Ať už hledáte poslat e-mailem newsletter, vysoce-dopad email propagace, e-mail případě pozvání, on-line průzkumu, nebo stavět svůj e-mail seznam, zjistit, jak Digeus Jet Email Extractor vám může pomoci co to dělá.
Digeus Jet Email Extractor je skvělým pomocníkem při provozování e-mailové marketingové kampaně. Každý e-mailovou kampaň vyžaduje velké seznamy e-mailových adres. Je to téměř nemožné získat e-mailové adresy ručně. To bylo zaměřené na koordinaci cílených e-mailové adresy potenciálních zákazníků pro zvýšení prodeje a tržeb.
Digeus Jet Email Extractor bude stavět velké cílených konferencí. To se připojí k mnoha zpravodajských serverů a e-mailové adresy načte z hlavičky každého výrobku ve vybraných cílových-související diskusních skupin.
Image Resizer
Digeus Image Resizer je perfektní nástroj pro ty, kteří desítky ukládání digitálních fotografií a obrázků na svém počítači a chtějí změnit velikost, kompresi, převádět, vytvořit kopie, importovat a organizovat fotografie.
Pomocí tohoto software velikost obrázku, můžete vytvořit pro e-mail verze vašich obrázků, nahrát je rychlejší, je snadno přesunout ze složky do složky, upravovat velké množství obrazových souborů / šarže velikost obrazu, a tím ušetřit místo na pevném disku. Digeus Image Resizer lze také měnit názvy souborů pomocí šablony.
Práce s obrázku Digeus Resizer je poměrně jednoduché. Spusťte program. Přidání souborů pro konverzi. Určete konverzní možnosti a cílovou cestu pro uložení souboru a stiskněte "Převést" tlačítko. To je vše, co potřebujete vědět k úspěšnému používání programu a získat profesionální výsledky.
Digeus Image Resizer umí konvertovat JPEG, JPG, JPE, JFIF, BMP, DIB, GIF, TIF, TIFF, PNG formát bez omezení velikosti obrázku a obrázku výše. Dokonce Obrovské obrazy mohou být přeměněny!
Práce s obrázky se obrovské nyní omezen pouze na váš pevný disk velikosti.
Zachytit co vidíte na obrazovce PC!
Neztrácejte čas ořezávání vaší zachytí. Take "snímek" o něčem, co přesně potřebujete, s spravedlivý jeden cvaknout.
Snadno se učit, snadné použití!
Online TV Player
Online TV Player je nejlepší dostupný software on-line dnes sledovat tisíce satelitních filmů a poslech rozhlasových stanic z celého světa. Nepotřebujete satelitní anténu, přijímač, nebo kabelové nebo satelitní služby! Vše, co potřebujete, je připojení k internetu a počítač.
Sledovat místní TV, world TV, Live TV, TV se satelitním příjmem ze zemí po celém světě v různých jazycích na počítači s Online TV Player nejen doma, ale v kanceláři, práce nebo bezdrátově. Sledovat kdekoliv, kde máte své internetové Online. Získejte okamžitý přístup k tisícům volný streamingu kanálů internetové televize, on-line rádia.
My patří k dispozici nejširší paletu žánrů: hudba, sport, zpravodajství, komedie, romantika, live show, erotický film, dospělí, akce, romány, seriály .... vás vždy bude moci najít stanici nebo kanálu v závislosti na vašem stavu ducha.
Shlédnout všechny tyto kanály kdekoli na světě. Více než 100.000 uživatelů se již těší neuvěřitelné odrůdy.
