Aktuálny čas je Ned 25. Okt 2026 9:13:49
 Ashampoo WinOptimizer v6.20 [18-02-2009]
 Predmet príspevku: Ashampoo WinOptimizer v6.20 [18-02-2009]
PoslaťNapísal: Str 18. Feb 2009 19:54:00
With the reliability of 11 years of experience, Ashampoo WinOptimizer 6 makes Windows maintenance fast and easy – and it works for Windows XP just as well as it does for Vista. The One-click Optimizer does what it says and you can even schedule it to run automatically so that you don’t need to think about it at all. It keeps your Windows computer running as fast and smoothly as on the first day you bought it.
In addition to efficient Windows maintenance you also get a whole suite of powerful, easy-to-use tools that enable you to configure and tune your Windows computer so that it works exactly the way you want it to.
The WinOptimizer Toolbox:
• AntiSpy Module - New!
• Context Menu Manager - New!
• Hard Disk Defragmenter - New Version!
• One-Click Optimizer - Improved
• Drive Cleaner - Improved
• Registry Optimizer - Improved
• Internet Cleaner - Improved
• Windows Tweaking Tools - Improved
• System Benchmark - Improved
• StartUp - Tuner
• Process Manager
• File Undeleter
• File Wiper
• File Splitter & Joiner
• Real- time Backup
• DiskSpace Explorer and System Information
• File Encrypter & Decrypter
• Vista Sidebar Gadget
• Visual Styler
• Icon Saver
New Features in Version 6:
Defrag 3 Disk Defragmenter and Service As you use your hard disk the information on it becomes “fragmented”, making your computer slower. The brand-new Defrag 3 disk defragmenter does the best job ever of defragmenting your hard disks and it comes with a new background service that automatically keeps your hard drives defragmented whenever your computer is idle. The advanced new Boot Time Defragmentation makes Windows start faster. You can run Defrag 3 manually or schedule it to run at regular times or intervals. The continuous background service with a new predictive defragmentation algorithm actually prevents fragmentation before it can happen. It automatically cuts in and defragments your hard disk when your computer is idle, never interfering with your work or other programs. The result is hard disks that are always “freshly defragmented”.
New features:
* Manual, scheduled and automatic defrag options
* Completely new advanced defrag algorithm
* New Boot Time defrag makes Windows start faster
* Powerful, efficient and safe for maximum performance
* Radically improved Windows Vista support
* Exceptionally efficient, very low system load and memory use
* Preview of current hard disk fragmentation with analysis
* Include in One-Click Optimization
AntiSpy Module
This module provides a collection of settings for Windows services and other programs that like to “phone home” and tell Microsoft or their manufacturers about your computer and what you are doing. The settings let you control and stop this behavior to protect your privacy and security, for example for Windows Media Player, the Windows error reporting service and others.
* Automatic configuration with selectable profiles
* Additional individual configuration options for full control
* Full support for both Windows XP and Windows Vista
The new Context Menu Manager enables you to view and manage the contents of right-click context menus in Windows, giving you full control. Popup context menus are displayed when you click the right button on your mouse. They’re useful and configurable and many programs add entries to them to allow you to give you direct access to special functions. The Context Menu Manager gives you detailed information on all the entries and enables you to activate or deactivate them for individual and multiple file types.
Favorites Tab
The new Favorites tab makes using WinOptimizer 6 even easier by giving you direct access to the functions and modules you use most frequently. The program automatically lists the functions you use in the Favorites tab so that you can return to them quickly. Once you’ve used a function or module it becomes even easier to use it again. In addition to this the tab also displays interesting information on how you use the program functions – date of use, frequency of use, last use and so on.
Se spolehlivostí z 11 rokù zkušenosti, Ashampoo WinOptimizer 6 dìlá windowsovskou údržbu rychle a snadný – a to pracuje pro Windows XP právì tak, jako to dìlá pro Vista. One - click Optimizer dìlá co to øíká a vy mùžete dokonce plánovat, že to bìžet automaticky abyste nepotøebujete pøemýšlet o tom vùbec. To drží váš windowsovský poèítaè bìžící tak rychlý a hladce jak prvního dne vy koupili to.
Navíc k úèinné windowsovské údržbì vy také dostanete celou soupravu silný, snadno použitelný nástroje které umožní vám konfigurovat a ladit váš windowsovský poèítaè tak, že to pracují pøesnì cestu vy chtìjí, že to .
WinOptimizer schránka s náøadím:
• AntiSpy jednotka - nová!
• Nabídkový manažer souvislosti - nové!
• Harddisk Defragmenter - nová verze!
• Optimizátor na jedno kliknutí - zlepšený
• Pohon èistírna - zlepšená
• Registraèní optimizátor - zlepšený
• Internet èistírna - zlepšená
• Windows štípající nástroje - zlepšené
• Systémové mìøítko - zlepšené
• Start - tuner
• Zpracovat manažera
• Soubor Undeleter
• Souborový hadr
• Registrovat štípaèku & truhláøe
• Skuteèné- èas zálohování
• DiskSpace prùzkumník a informaèní systém
• Registrovat Encrypter & Decrypter
• Vista Sidebar pøístroj
• Vizuální módní návrháø
• Ikona šetøiè
Nové rysy ve verzi 6:
Defrag 3 Disk Defragmenter a Service As vy užíváte vaši harddisk informaci o, který tom stává se "fragmentovaným", dìláním vašeho poèítaèe pomalejšího. Zbrusu nový Defrag 3 disk defragmentuje dìlá nejlepší práce vùbec kdy z defragmentujících vašich harddiskù a pøichází s novou zadní službou která automaticky drží vaše pevné disky defragmentovala kdykoli váš poèítaè zahálet. Pokroèilý nový Boot Time Defragmentation dìlá Windows zaèít rychlejší. Vy mùžete bìžet Defrag 3 ruènì èi plánuje, že to dosahovat normální pracovní doby èi intervaly. Nepøetržitá zadní služba s novým pøedvídavým defragmentací algoritmem ve skuteènosti pøedchází rozdìlení pøedtím, než to mùže stát se. To automaticky zmenšuje v a defragmentuje váš harddisk kdy váš poèítaè zahálet, nikdy pøekážení s vašimi prací èi jinými programy. Výsledek je harddisk které jsou vždy "èerstvì defragmentoval".
Nové rysy:
* pøíruèka, naplánovaný a automatický defragmentují volby
* úplnì nový pokroèilý defragmentovat algoritmus
* nový bota èas defragmentuje dìlá Windows zaèít rychlejší
* silný, úèinný a bezpeèný pro maximální výkon
* radikálnì zlepšil Windows Visty podporu
* výjimeènì úèinný, velmi nízký zatížení soustavy a pamì užívá
* náhled z proudu harddisku rozdìlení s analýzou
* zahrnout v optimalizaci na jedno kliknutí
AntiSpy jednotka
Tato jednotka poskytuje sbírku nastavení pro Windows služby a jiné programy které rád "telefonovat domovu" a øíkat Microsoft èi jejich výrobci o vašem poèítaèi a co vy dìláte. Nastavení nechala tì ovládat a zastavit toto chování k tomu, aby chránilo vaši soukromí a bezpeènost, napøíklad pro Windows mediální Player, windowsovská chyba zpravodajská služba a jiní.
Rysy:
* automatická konfigurace s volitelnými profily
* dodateèné individuální konfiguraèní volby pro plná kontrola
* plná podpora pro oba Windows XP a Windows Visty
Nové Context Meno Manager umožní vám dívat se na a øídit obsah kliknutí na pravou klávesu menu souvislost ve Windows, dávající vám plnou kontrolu. Vyskakovací menu souvislost jsou zobrazená kdy vy kliknete na pravý knoflík na vaší myši. Oni jsou užiteèné a konfigurovatelné a mnoho programù pøidá položky k nim vám dovolí dát vám pøímý pøístup k zvláštním funkcím. Context Meno Manager dává vám detailní informaci o všechny položkách a umožní vám aktivovat èi ukonèit funkci je pro individuální a vícenásobné typy souboru.
 Predmet príspevku: Re: Ashampoo WinOptimizer v6.20 [18-02-2009]
PoslaťNapísal: Uto 27. Okt 2009 20:00:30
neplatný link.......plz môžeš to reuploadnuť na rapidshare :(
