Aktuálny čas je Pia 23. Okt 2026 16:03:24
 FixCleaner 2010 v1.3.3675 - SUPERBOMBA 100% PRODUKT
 Predmet príspevku: FixCleaner 2010 v1.3.3675 - SUPERBOMBA 100% PRODUKT
PoslaťNapísal: Ned 17. Jan 2010 9:38:35
FixCleaner is an advanced computer utility designed to remove errors and boost the performance of home PCs. System performance is determined by a lot of things. That’s why FixCleaner was engineered with multi-function capabilities. The advanced system cleaner in FixCleaner combines the vital tools you need to regain lost PC performance, remove data clutter and boost startup speed.
PC Optimizer
Optimize your system with easy push-button controls. Manage startup programs and eliminate errors with ease.
Better your Browser
Run easy-to-use Web templates to safely maximize browsing performance and speed.
Delete Junk Files
Seek out and remove unnecessary bulk data in your computer’s memory to free up space and prevent slowdown.
Remove Private Data
Remove activity logs, temp files and Web histories that can expose you to attack or ID theft.
Microsoft updates
Now you can manage MS updates from one easy console. Protect your computer from system crashes and Malicious Software.
Java updates
Update Java and other web apps the right way. View the updates available, point, click and go.
Easy Error Repair:
Means comprehensive diagnoses. FixCleaner’s scanning regimen is so easy, with one click you can employ the industry’s latest assessment technology to find the roots of common PC problems, including program crashes, routine error alerts and even PC freezes.
Control over your PC:
Keep your computer under your control. FixCleaner gives you easy access to the background functions that were either too hidden or too complex to deal with. Use it to safely manage startup applications and to control Active-X objects in Internet Explorer.
On-Demand Updates:
Having a system that is up-to-date is the best way to keep programs running right, to keep errors down and to keep security tight. Thanks to FixCleaner’s update manager tool, you can take control of Microsoft Updates, Java Updates, Adobe updates and more.
System Optimization:
Stopping performance leaks is only half of the solution. To restore your PC to like-new condition, use FixCleaner’s on-board optimization tools to adjust Internet Settings, manage TCP/IP controls and even adjust memory usage, all with easy-to-use templates.
Real World Protection:
Comprehensive protection depends on locating and removing the sensitive data that could expose you to attack or id theft. With FixCleaner’s privacy scan, you can isolate and wipe clean the hidden logs, histories and Temporary Files from all of today’s most used applications.
Backup & Support:
FixCleaner gives you the essential protection needed to safeguard your whole system. Use its automated backup to take snapshots of the registry, and use its integrated system restore to protect of your whole windows setup—on demand restore whenever unexpected trouble strikes.
PASS : warezmacherka = Larijočka
htObrázok
FixCleaner je pokročilý počítač nástroje určené k odstranění chyb a zvýšení výkonnosti domácích počítačů. Systém je určen spoustu věcí. To je důvod, proč byl FixCleaner inženýrství, s multi-funkční schopnosti. Pokročilý systém čistič FixCleaner kombinuje nezbytné nástroje, které potřebujete znovu získat ztracený výkon počítače, odstraňovat data nepořádek a zvýšit rychlost startu.
PC pro optimalizaci
Optimalizujte svůj systém s jednoduchým push-ovládací tlačítka. Správa programů po spuštění a odstranění chyb s lehkostí.
Lepší váš prohlížeč
Run bezstarostný-až k-cvičení Webové šablony bezpečně prohlížet maximalizovat výkon a rychlost.
Odstranit nevyžádané soubory
Najít a odstranit zbytečné část dat v paměti počítače, aby uvolnily místo a zabránit zpomalení.
Odstranit soukromá data
Chod činnosti protokoly, dočasné soubory a webové historie, které mohou vystavit útoku nebo krádeže identity.
Microsoft aktualizace
Nyní můžete spravovat MS aktualizace z jedné konzoly jednoduchá. Chraňte svůj počítač před havárií systému a škodlivého softwaru.
Java aktualizace
Update Javy a dalších webových aplikací správnou cestou. Zobrazit aktualizace k dispozici, místo, klepněte na tlačítko a jdi.
Snadné Error Repair:
Znamená komplexní diagnózy. FixCleaner je skenování režim je tak snadné, s jedním kliknutím můžete použít průmyslu poslední hodnocení, aby našel kořeny problémů běžné PC, včetně programu dojde k chybě, rutinní chybová hlášení a dokonce i počítač zamrzne.
Kontrola nad PC:
Udržujte počítač pod kontrolou. FixCleaner vám poskytuje snadný přístup k funkcím na pozadí, které jsou buď příliš skryté, nebo příliš složité zabývat. Použijte jej bezpečně řídit spouštění aplikací a pro kontrolu Active-X objekty v aplikaci Internet Explorer.
On-Demand aktualizace:
S systém, který je up-to-date je nejlepší způsob, jak udržet programy spuštěné v pořádku, aby se chyby a udržet bezpečnost těsný. Díky aktualizaci FixCleaner manažer nástroj, můžete si vzít kontrolu aktualizací společnosti Microsoft, Java aktualizace, aktualizace, Adobe a další.
Optimalizace systému:
Zastavení výkonu úniku je pouze poloviční řešení. Chcete-li obnovit vaše PC-jako novou podmínku, použijte FixCleaner je na palubě-tools, optimalizace pro nastavení Internet Settings, řízení TCP / IP, kontroly a dokonce nastavit využití paměti, všechny s bezstarostný-až k-použití šablon.
Real World ochrana:
Komplexní ochrana závisí na lokalizaci a odstranění citlivých údajů, které by mohly vystavit útoku nebo krádeže identity. S FixCleaner soukromí skenování, můžete izolovat a otřete čistým skryté záznamy, historie a dočasných souborů ze všech dnešních nejpoužívanějších aplikací.
Backup & Support:
FixCleaner vám základní ochrany potřebné k zajištění celý systém. Využít své automatické zálohování, aby snímky z registru a jeho použití integrovaného systému navrátit k ochraně vašeho celého okna nastavení-na vyžádání kdykoliv obnovit nečekané problémy stávky.
