Aktuálny čas je Ned 01. Nov 2026 7:27:22
 Mixman StudioXPro 5.0.98
 Predmet príspevku: Mixman StudioXPro 5.0.98
PoslaťNapísal: Sob 14. Feb 2009 12:35:23
Mixman StudioXPro enables you to create professional quality music on your PC.
Take your musical ideas from concept to completion with this integrated suite of remixing tools. The patented Mixman remix engine allows you to combine individual sound elements and perform them in real-time. Audio experimentation is fast and fun regardless of musical style. Includes 5 powerful "Studios" that give you control over every aspect of your music: Remixing Studio, Recording Studio, FX Studio, Editing Studio, and the new Track Maker that lets you build your own tracks. It's time to take your music to the next level.
The Remixing Studio in XPro has all the features of regular Studio and StudioPro and a lot more. (See the product pages for those products for basic functionality)
XPro adds the concept of 'platters'. These are four groups of 8 tracks each, for a total of 32 Tracks you can load. This is twice the amount of DM2, and Pro. You can save any platter as a set. Load 4 different platters and use the cross-fader to move continuously from one to another.
Auto-W.A.R.P. allows you to set various patterns and control W.A.R.P auto-matically. Punch-in Record allows you to Record in real-time, and then go back over and over to make various additons or changes. You can re-record just the W.A.R.P, or any specific track.
Voice Overdub allows you to make a Remix in the Remixing Studio, and then hear it while adding vocals or some other live recording on top of it. Add a rapper, or singer on top of your grooves. You can adjust levels, set input sensitivity and then add processing to the overdub. Whne ready, save for Export. This is ONLY available with XPro.
Like Pro this studio also allows you create simple samples to add back into your mix in the Remixing Studio or for use elsewhere. Plug in any compatible microphone to your sound card or use the line in input for a keyboard, mixer or other outside sound source. You can even grab a bit off a CD and sample it in the Recording Studio. Once the file is named and saved you can then trigger it like any other Mixman track (TRK).
Mixman Tracks are more responsive and flexible, but there are settings to help make your samples work well. For maximum control, take a look at our product called Zero-X TrackCreator which allows you to edit any sample you create and turn it into a Mixman TRK file.
Features
32 Tracks, playback in Remix and Editor
Punch-in/Punch-out Recording in Remix
Auto-WARP, other WARP selections
Scratching, use the mouse to scratch
Track Maker Studio, step sequencer for making TRK files; use the powerful "Explode a TRK" feature
Over-Dub Recording, record a "rap" or sing on top of your mix add FX, adjust levels before Exporting the composite
Compatible with the DM2 hardware controller
Requirements
Windows 98 / ME / 2000 / XP
Pentium III, 450 mHz or faster
65 MB RAM (128 preferred)
16-bit DirectX compatible soundcard with most current drivers
DirectX 7.0 or higher
Internet connection to validate authentication
Tested on Vista. Vista Compatible.
Program is full version 100% working and tested.
Mixman StudioXPro umožní vám vytvoøit profesionální kvalitu hudbu na vašem PC.
Vezmìte vaše hudební myšlenky z konceptu k spolu s touto integrovanou soupravou remixování nástrojù. Patentovaný Mixman remixovat motor dovoluje vám spojit individuální zvukové elementy a je úèinkovat v reálném èase. Zvukový experiment je pùst a veselý zábava bez ohledu na hudební styl. Zahrnuje 5 silný "Studia" to dá vy kontrolu nad každým aspektem vaší hudby: Remixování Studio, nahrávací studio, FX Studio, editující studio, a nový Track Tvùrce který nechá vás budovat vaše vlastní dráhy. Je na èase, abychom my vzali vaši hudbu k další úrovni.
Remixing Studio v XPRO má celé rysy pravidelný Studio a StudioPro a daleko víc. (sídlo stránky produktu pro ty produkty pro základní funkènost)
XPRO pøidávají pojmy ' mís ' . Toto jsou ètyøi skupiny 8 drah každých, pro úhrn z 32 drah vy mùžete naložit. Toto je dvakrát množství DM2, a Pro. Vy mùžete chránit nìjakou /každou /žádnou mísu jak sada. Naložte 4 jiné mísy a užívej køíž-prolínaè k tomu, aby pohyboval kontinuálnì z jednoho další.
Auto -W.A.R.P. dovoluje vám nastavit rùzné vzory a ovládat W.A.R.P auto-matjes. Paòáca-v Record dovoluje vám zaznamenat v reálném èase, a potom se vrátit stále znovu udìlat rùzné dodatky èi zmìny. Vy mùžete znovu-zaznamenat jen W.A.R.P, èi nìjaká /každá /žádná specifická dráha.
Hlas Overdub dovoluje vám udìlat Remix v Remixing Studiu, a potom slyšet to pøi pøidávání vokálù èi nìjakého jiného živého nahrávání na vrch toho. Pøidejte rappera, èi zpìváka na vrch vašich rýh. Vy mùžete nastavit úrovnì, nastavit vstupní citlivost a potom pøidat zpracování k overdub. Whne pøipravený, šetøit pro export. Toto ONLY je k dispozici s XPRO.
Jako Pro toto studio také dovoluje vy vytvoøíte jednoduché vzorky k tomu, aby pøidaly zpìt do vaší smìsi v Remixing Studiu èi pro použití jinde. Zastrète do zásuvky nìjaký /každý /žádný kompatibilní mikrofon vaší zvukové kartì èi užívej linku ve vstupu pro klávesnici, míchadlo èi jiný vnìjší zdroj zvuku. Vy mùžete dokonce uchopit trochu mimo CD a dáte za vzor to v nahrávacím studiu. Jednou soubor je pojmenovaný a ušetøený vy mùžete pak spustíte, že to jako jiná Mixman dráha (TRK).
Mixman Tracks jsou víc vnímavý a flexibilní, ale tam jsou nastavení k tomu, aby pomáhala udìlat vaše vzorky pracovat dobøe. Pro maximální kontrolu, podívejte se na náš produkt nazvaný Zero - X TrackCreator který dovoluje vám editovat nìjaký /každý /žádný vzor vy vytvoøí a zmìní ten na Mixman TRK soubor.
Rysy
32 drah, playbacku v Remix a Editor
Paòáca-v/rvaèce nahrávání v remixove
Auto -WARP, jiné WARP výbìry
Poškrabání, užívej myš škrabat
Dráhové výrobní Studio, pøírùstkový tøídiè pro dìlání TRK souborù; užívat silný "Explodujte TRK" rys
Pøílišný-titulovat nahrávání, zaznamenejte "klepat" èi zpívat na vrch vaší smìsi pøidat FX, nastavit úrovnì pøedtím, než Exporting složený
Sluèitelný s DM2 hardwarem kontrolerem
Požadavky
Pentium III, 450 mHz èi rychlejší
65 MB RAM (128 preferovaný)
16 - bitová DirectX kompatibilní zvuková karta s nejaktuálnìjšími øidièi
DirectX 7.0 èi vyšší
Internetové spojení s potvrdit legalizaci
Testovaný na Vistì. Vista kompatibilní.
Program je plný verze 100% pracování a testované.
 Predmet príspevku: Re: Mixman StudioXPro 5.0.98
PoslaťNapísal: Str 04. Nov 2009 15:38:12
