Aktuálny čas je Sob 26. Sep 2026 8:12:20
 Cheat Engine Mega Komplex
 Predmet príspevku: Cheat Engine Mega Komplex
PoslaťNapísal: Pon 07. Dec 2009 9:07:38
Edit running process make changes according to your need. cool software for gamers and hackers
Are you playing a game and stuck in a level just bcoz of you don't have enough score or money required for next level ? then cheat engine is the software for you!
Edit the process and change the value to your need ...
:D A must have software
personally used and tried my me
Information
Changes:
added 'short' and 'far' override to the jump instructions. (Mainly usefull for auto assembler scripts that by default pick the far one)
copied the "Find out what addresses this code accesses" from advanced options to memory view
Made the above function display the current value so you don't have to add them first
And made it non-modal so you can do other stuff while it's working.
Improved custom scan so it can now also display the results
New speedhack implementation
New AutoAssembler window
Removed the question if you want a new scan. (You must now click on new scan yourself)
Added GlobalAlloc to the autoassembler
The dissect structure window can now be opened multiple times (for comparison)
Structures are now saved in the cheat table
The main ce window now has a menu (can be disabled in settings if you don't like it)
The processlist can now show process icons. (could be slow, so can be disabled in settings)
The settings window has been changed from tabs to a list
Added a tools menu so people can add quicklaunch apps. (e.g: calc)
Added the option to save and load tables as XML
Changed copy/pasting of entries to XML
Helpfile changed from .HLP to .CHM , also incorporated the plugin documentaion in the helpfile instead of a seperate .RTF
Added a few new functions to the plugin system and made the examples easier to understand (Mainly for helping with assembly scripts)
Added a packet editor example plugin
Assembler can now work with " and ' strings
Changed the reverse pointer scan to give more details about what is going on
The positions of the main window and memoryview can now be saved
The about window now tells you which version of dbvm is loaded if dbvm is running
If DBVM is running and you choose physical memory, it goes through dbvm's read physical memory instead of windows'
Added a floating point panel to several windows that use system context to display variables
Added the option to the memoryview hexview part to display 2 bytes, 4 byte, float or double instead of bytes
Improved the dissect data window to show addresses next to eachother
The bottom part of the memory view window (hexview) can now display as different types (byte, 2 byte, 4 byte, decimal 4 byte, float, double)
Changed the multi pointer tutorial step so it now represents a real game situation
Added the adminRequired anifest to the standalone trainer
Fixes:
Fixed the multicore scan crash
Fixed the MEMORYFIRST.TMP file showing up in a weird location
Fixed several hotkey setting bugs
Fixed loading back the speedhack hotkey values
Fixed a crash when opening a process with a broken PE-header
Fixed several assembler and disassembler instructions
Fixed memoryviewers "copy to clipboard" option where it picks the wrong option
Fixed binary scan crash on nextscan
Fixed huge memory leak in pointerscanner
Fixed the "No error message" on error during a scan
Fixed bug with calling kernel_XXXX functions in assembler
Fixed a trainer bug regarding clicking on cheats
Fixed 32-bit icons in the trainer maker
Fixed the terminate scan option
Fixed a DPI bug on several windows
Fixed a crash when loading of the symbols failed
Cheat omplex Engine.rar (6,1 MB)
Upravit běžící proces měnit dle aktuálních potřeb klienta. vychladnout software pro hráče a hackery
Hrajete hru a uvízl v úrovni těsně bcoz z vás, nemáte dost peněz a bodů potřebných pro další úroveň? pak podvádět motor je software pro vás!
Upravit procesu a změňte hodnotu na své potřeby ...
: D musí mít software
Osobně jsem se snažil použít, a já
Informace
Změny:
přidáno 'short' a 'až' přepíše na skok pokyny. (Hlavně užitečné pro skripty auto assembleru, že ve výchozím nastavení vybrat daleko jeden)
kopírování "Podívejte se, co řeší tento kód přístupů" od pokročilých možností zobrazení paměti
Made výše uvedené funkce zobrazí aktuální hodnotu, takže nemusíte přidávat jim první
A dělal to bez-modální, takže si můžete dělat jiné věci, zatímco ono to funguje.
Zdokonalené uživatelské scan, takže nyní mohou zobrazovat výsledky
New SpeedHacku provedení
AutoAssembler New window
Odstraněny na otázku, zda chcete vytvořit nový test. (Nyní musíte kliknout na novou úlohu skenování sebe)
Přidáno GlobalAlloc na autoassembler
Struktura pitvat okno může být nyní otevřena vícekrát (pro srovnání)
Struktury jsou nyní uloženy v tabulce podvádět
Hlavní ce okno má nyní nabídky (lze vypnout v nastavení, pokud vám to nelíbí)
Processlist nyní může ukázat ikony procesu. (může být pomalé, takže lze vypnout v nastavení)
Nastavení okna byl změněn z karet do seznamu
Added menu nástroje, aby lidé mohli přidat QuickLaunch apps. (např: calc)
Přidána možnost ukládat a načítat tabulky ve formátu XML
Změněný kopírovat / vložit vstupů do XML
Helpfile změněna z. HLP do. CHM, rovněž začleněny plugin documentaion v helpfile místo zvlášť. RTF
Přidáno několik nových funkcí do systému, a udělal plugin příklady srozumitelnější (především za pomoc s montáží skriptů)
Added packet editor například plugin
Assembler může nyní pracovat s "a 'struny
Změněno reverzní ukazatel skenování poskytnout více informací o tom, co se děje
Pozice hlavního okna a memoryview mohou být nyní uloženy
O okno Nyní vám řekne, která verze dbvm se nahraje, pokud dbvm běží
Je-li DBVM běží a vy si fyzické paměti, prochází dbvm read fyzické paměti místo oken '
Added floating point panel do několika oken, které používají systém kontext pro zobrazení proměnných
Přidána možnost memoryview hexview část zobrazení 2 byty, 4 byte, float nebo double místo bytů
Zlepšená pitvat datového okna pro zobrazení adresy vedle přicházejí do styku
Ve spodní části okna zobrazení paměti (hexview), může se nyní zobrazují jako různé typy (byte, 2 byte, 4 byte, desetinná 4 byte, float, double)
Změnilo více ukazatel tutoriál krok, takže nyní představuje skutečnou herní situaci
Přidáno adminRequired AniFestu k samostatné trenér
Opravy:
Pevná vícejádrových scan crash
Pevná MEMORYFIRST.TMP soubor objevil v podivné místo
Opraveno několik chyb, kterým se hotkey
Opraveno načítání zpět SpeedHacku hotkey hodnoty
Opraven pád při otevření procesu se zlomeným PE-header
Opraveno několik assembleru a disassembleru pokyny
Pevná memoryviewers "zkopírovat do schránky" variantu, kdy se vybírá špatné volby
Pevné binární scan krach nextscan
Pevná obrovský únik paměti v pointerscanner
Opravena "No error message" při chybě při skenování
Opravena chyba při volání funkce kernel_XXXX v assembleru
Opravena chyba trenéra, pokud jde kliknutím na podvádí
Pevné 32-bitových ikon na trenéra výrobce
Pevná ukončit scan
Opravena chyba DPI na několik oken
Opraven pád při načítání ze symbolů selhala
