Aktuálny čas je Ned 25. Okt 2026 23:18:29
 RemoveWAT 2.0 - Bypass Activate Windows 7 Permanently Activa
 Predmet príspevku: RemoveWAT 2.0 - Bypass Activate Windows 7 Permanently Activa
PoslaťNapísal: Ned 22. Nov 2009 10:24:22
RemoveWAT “Bypass Activate” Windows 7 and Server 2008 R2 Forever (Loader Alternative to Remove & Disable Activation Technologies).Despite already has perfect and reliable Windows 7 activation crack based on royalty-OEM mechanism, hackers have managed to come out with a new activation crack method as an alternative to BIOS loader and OEM BIOS mod, which effectively bypass the activation requirement of the installed Windows 7 system, by removing and disabling Windows Activation Technologies (WAT)..
The hack works to “activate” Windows 7 by bypassing activation altogether, and thus does not require any product key. Previously in Windows Vista, the attempt to permenantly bypass Windows Vista activation by stopping activation grace period countdown timer has been unsuccessful and foiled by Microsoft with anti-crack update.In Windows 7 and Windows Server 2008 R2, hackers attempt to block access of Windows Activation Technologies, comprising of SPP (Software Protection Platform) and SLC (Software Licensing Client), which manages and handles licensing and activation matters on the operating system to the core components or files which are required for its operation.
By blocking, preventing, removing and disabling access to or loading of the activation and licensing related system files, SLUI will fail to start, causing activation been circumvented and Windows does not need to be activated anymore, for forever and permanently.
ACTIVATED.rar (384 KB)
RemoveWAT "Bypass Aktivovat" Windows 7 a Server 2008 R2 Forever (Loader Alternative odebrat Zakázat Aktivace Technologies). Přestože již má perfektní a spolehlivý Windows 7 aktivace bezva na základě licenčních-mechanismus OEM, hackerům podařilo vystoupit s novou aktivací bezva metoda jako alternativa k nakladač a OEM BIOS BIOS mod, který účinně obejít aktivaci požadavek nainstalovaný systém Windows 7, odstraněním a zakázáním Aktivace systému Windows Technologies (WAT) ..
Hack pracuje na "aktivovat" Windows 7 obcházet aktivaci úplně, a proto nevyžaduje žádné plod identifikovat. Dříve v systému Windows Vista, pokus permenantly obtok Okna Průhled aktivace zastavením aktivace hudební ozdoba doba countdown čas byl neúspěšný a zmařen Microsoft s anti-bezva update.In Windows 7 a Windows Server 2008 R2, hackeři snaží blokovat přístup Aktivace systému Windows technologií zahrnující SPP (Software Protection Platform) a SLC (Software Licence Client), který spravuje a zpracovává licencování a aktivaci záležitosti na operačním systému k základní složky nebo soubory, které jsou nutné pro jeho provoz.
Blokováním, prevence, odstranění a znemožnění přístupu k nim nebo nakládání aktivace licencí a souvisejících systémových souborů, bude SLUI nepodaří spustit, což způsobuje aktivaci obcházena a Windows nemusí být aktivován již za navždy a trvale.
