Aktuálny čas je Ned 25. Okt 2026 11:48:53
 WindowsXP WGA Fix 1.9.9.1
 Predmet príspevku: WindowsXP WGA Fix 1.9.9.1
PoslaťNapísal: Sob 21. Nov 2009 23:30:01
This is an All-In-One toolkit, containing everything you
need, to deal with the latest anti-piracy measures by
Microsoft, for their most successful OS to date.
The suite contains 3 patches, each with a purpose.
Patch #1:
The oldest fixed in the package.
It's a registry fix, that will bypass old WGA
checks, that are pretty much outdated now.
It won't hurt to install, so go ahead if you
like.
Patch #2:
The new patch, for the latest WGA update.
This will deal with the latest WGA DLL files,
on your PC, and make it pass validation tests.
Always install ALL the WGA updates before
using this! Install all the update, means that
you should also install the manual, Hight
Priority updates for Windows Genuine Advantage,
and Windows Genuine Notifications...
(See the DIZ for the current WGA version)
Patch #3:
This patch deals only with the internal WGA
check, found in the XP installer of Windows
Media Player 11. While installing WMP 11, the
user is required to click a button to validate
Windows. This will work differently than the
normal WGA checks, so you might need this patch.
If your validation fails during the installation,
Simply apply this patch, and click the validation
button again, to make it bypass the check.
Once it's installed, it will bother you no more.
PREDATOR.rar (5,4 MB)
To je zařízení All-In-One toolkit, obsahující vše, co
potřeby, vypořádat se s nejnovější anti-pirátské opatření
Microsoft pro jejich nejúspěšnější OS k dnešnímu dni.
Sada obsahuje 3 náplasti, z nichž každý má svůj účel.
Patch # 1:
Nejstarší stanovené v balíčku.
Je to registry fix, který bude obtok WGA starý
Kontroly, které jsou do velké míry zastaralé nyní.
Nebude to bolet instalovat, tak do toho, pokud
mít rád.
Patch # 2:
Nový patch pro nejnovější WGA aktualizovat.
To bude zabývat nejnovější WGA soubory DLL,
na vašem PC, a učinit z něj projdou ověřením testy.
Vždy nainstaluje ALL WGA aktualizovat dříve
pomocí tohoto! Instalovat všechny aktualizace, znamená to, že
měli byste nainstalovat také manuál, Hight
Prioritní aktualizace pro systém Windows Genuine Advantage
a Okna Pravý Oznámení ...
(Viz DIZ pro aktuální verzi WGA)
Patch # 3:
Tato oprava se zabývá pouze vnitřními WGA
zkontrolovat, nalezený v instalátoru Windows XP
Media Player 11. Při instalaci WMP 11,
Uživatel je povinen klikněte na tlačítko potvrdit
Windows. To bude fungovat jinak než
WGA běžné kontroly, tak se ti bude hodit patch.
Pokud váš ověření selže během instalace,
Jednoduše aplikujte tento patch, a klikněte na ověřování
tlačítko, aby se to obejít kontrolu.
Jakmile je nainstalován, bude vás více obtěžovat.
