Aktuálny čas je Uto 20. Okt 2026 1:27:42
 ExeScript 3.0.8
 Predmet príspevku: ExeScript 3.0.8
PoslaťNapísal: Str 18. Nov 2009 6:45:55
ExeScript is a program that quickly converts batch files (.bat), VBScript, JScript, WSF, WSH and HTA scripts to executable files (.exe).
It also protects contents of .bat, .vbs, .js, .wsf, .wsh and .hta files from being changed by other users accidentally or intentionally.
ExeScript is an excellent solution for advanced PC users who do not know any programming languages. They can create (compile) their own executable files without writing a single line of code.
There are number of features unique to this program, for example, "silent mode" support - a stealth batch file feature that makes execution of converted scripts "invisible" to other users.
Those who know a little bit of programming will like the fact that ExeScript comes with a built-in .bat, .vbs .js, WSF, WSH and HTA file editor which features syntax highlighting and makes editing of files a simple and straightforward process.
ExeScript provides a number of other benefits. For instance, it can be used for automating scheduled tasks execution. The program can also be used to help you create installation files and deployment modules.
ExeScript is fast, simple and compiles any .bat, .vbs, .js, .wsf, .wsh and .hta file to .exe format files. It is compatible with Windows 2000/XP/2003/Vista/x64 Edition. Executable packages created with ExeScript can be run in all Windows operating systems.
ExeScript has the following unique features:
• Converts batch files, VBScript and Jscript into executable files (exe format).
• Protects contents of .bat, .vbs, .js files from modification by other users.
• Contents of generated executables are hidden. The operations performed by converted batch files, VBScript and Jscript can remain secret.
• Users without programming languages can create their own executable programs (exe files).
• Supports "silent mode" - batch files execute invisibly, their launch can be invisible to other users.
• Encrypts file contents.
• Script Type - it is possible to specify the script type - windowed or console.
• Command Line - the command line running the script.
• Executing the script in computer memory without writing to the disk. Therefore, the security of the script is enhanced since it is impossible to see the contents.
• Password-protected launch of the compiled script. You can set a password for running the script converted into an exe application.
• The new built-in file editor for .bat, .vbs, .js files has syntax highlighting.
• ExeScript is ideal for automating many of the routine chores that must be carried out when working with computers.
• Helps you create installation packages for the deployment of modules and programs.
• Converts any .bat, .vbs and .js files into exe files compatible with Windows 2000/XP/2003/Vista/x64 Edition.
ExeScript je program který rychle dávkové soubory (.netopýr), VBSCRIPT, JSCRIPT, WSF, WSH a HTA skripty spustitelným souborům (.exe). To také chrání obsah .netopýr, .vbs, .js, .wsf, .wsh a .hta soubory z toho, být změněné jinými uživateli náhodně či úmyslně. ExeScript je vynikající řešení pro pokročilé PC uživatele kdo neznát nějaké /každé /žádné programovací jazyky. Oni mohou vytvořit (sestavte) jejich vlastní spustitelné soubory bez psaní jednotlivého programového řádku. Tam jsou množství rysů jedinečný k tomuto programu, například, " tichý režim" podpora - dávky tajnosti souborového rysu který dělá výkon konvertorovaných skriptů " neviditelný" dalším uživatelům. Ti kdo zná trochu programování jako skutečnosti, že ExeScript jde se zabudovaný .netopýr, .vbs .js, WSF, WSH a HTA registrovat editora který uvádí syntaxe světelné zvýraznění a dělá vydání souborů jednoduchého a přímého procesu. ExeScript poskytuje řadu jiných výhod. Například, to může být použito pro automatizaci naplánované úkolové exekuce. Program může také být užívaný pro pomoct vám vytvořit instalační soubory a jednotky rozmístění. ExeScript je rychlý, jednoduchý a sestavuje nějaký /každý /žádný .netopýr, .vbs, .js, .wsf, .wsh a .hta soubor k .exe formát soubory. To je slučitelné s Windows 2000/XP/2003/Vista/x64 vydání. Proveditelné balíky vytvořený s ExeScript může být běží ve veškerý windowsovských operačních systémech. ExeScript má následující jedinečné rysy:
• Konvertity dávkové soubory, VBSCRIPT a Jscript do spustitelné souborů (exe formát). • Ochrany obsah .netopýr, .vbs, .js soubory z modifikace jinými uživateli. • Obsah vygenerovaných spustitelných souborů jsou skrytý. Operace vykonaný konvertorovanými dávkovými soubory, VBSCRIPT a Jscript může zůstat v tajnosti. • Uživatelé bez programovacích jazyků mohou vytvořit jejich vlastní proveditelnou programy (exe soubory). • Podpory " tichý režim" - dávkové soubory vykonají neviditelně, jejich vypuštění může být neviditelné dalším uživatelům. • Encrypts souborový obsah. • Skriptový Type - to je možné specifikovat skriptovou typ - okenní či konzolu. • Příkazová řádka - příkazová řádka běžící skript. • Provádění skriptu v počítačové paměti bez psaní k disku. Proto, bezpečnost skriptu je zvětšená od je nemožné vidět obsah. • Heslové-chráněné vypuštění zkompilovaného skriptu. Vy můžete nastavit heslo pro běžící skript převedený do exe aplikace. • Nový zabudovaný souborový editor pro .netopýr, .vbs, .js soubory mají syntaxe světelné zvýraznění. • ExeScript je ideální pro automatizaci mnoho z obvyklých prací v domácnosti které musí být uskutečněné při pracovat s počítači. • Pomoci tobě vytvořit instalační balíky pro rozmístění jednotek a programů. • Konvertity nějaké /každé /žádné .netopýr, .vbs a .js soubory do exe soubory slučitelný s Windows 2000/XP/2003/Vista/x64 Edition.
