Aktuálny čas je Štv 29. Okt 2026 10:53:28
 Adobe Flash Player 10.1.51.45 Pre-Final IE FF, Netscape, Saf
 Predmet príspevku: Adobe Flash Player 10.1.51.45 Pre-Final IE FF, Netscape, Saf
PoslaťNapísal: Str 18. Nov 2009 6:44:27
Adobe® Flash® Player is the high-performance, lightweight, highly expressive client runtime that delivers powerful and consistent user experiences across major operating systems, browsers, mobile phones, and devices. Adobe® (formerly Macromedia) Flash Player - the universal rich client for delivering effective Adobe Flash experiences across desktops and devices. Lets you view the best animation and entertainment on the Web. It displays Web application front-ends, high-impact Web site user interfaces, interactive online advertising, and short-form to long-form animation.
Adobe's Flash Player allows you to view interactive web content like games, business presentations, advertisements. The package includes only the Flash Player and is a stand alone installation. Technically, this is a Flash Player ActiveX Control. It will only play the file through your Web browser.
Installed on over 700 million Internet-connected desktops and mobile devices, Flash Player enables organizations and individuals to build and deliver great digital experiences to their end users. Flash is the world's most pervasive software platform, reaching 97% of Internet-enabled desktops worldwide, as well as many popular devices. Since it is free of the design restrictions of more traditional Web display options, you can use it to clearly and exactly express your brand and company identity.
Top features:
3D effects - New
Create more intuitive, engaging interfaces using built-in support for 3D effects. Get started quickly without being a 3D master by designing in 2D and easily transforming and animating in 3D. Fast, extremely lightweight, and simple-to-use APIs, along with 3D tools in Adobe® Flash® CS4 Professional software, make motion that was previously accessible only to expert users via ActionScript® language or custom third-party libraries available to everyone.
Custom filters and effects - New
Create high-performance, real-time effects for cinematic experiences that quickly engage users. With new Adobe Pixel Bender™, the same technology behind many filters and effects in Adobe After Effects® software, these dynamic and interactive effects can be used both in production with After Effects CS4 and live with Flash Player 10. The Pixel Bender just-in- time (JIT) compiler can also be used to process other types of data, such as sound or mathematical functions, asynchronously in a separate thread.
Advanced text support - New
Take advantage of a new, flexible text layout engine that brings print-quality publishing to the web, building on more than 25 years of Adobe expertise in typography. Gain more control over text layout using an extensible library of ActionScript 3.0 text components to flow text and sophisticated typographic elements such as ligatures across multiple columns, around inline images, bidirectionally, vertically, or chained together. Create multilingual rich Internet applications (RIAs) using device fonts that can now be anti-aliased, rotated, and styled, or build your own unique text components.
Dynamic sound generation - New
Use enhanced sound APIs to dynamically generate audio and create new types of audio applications such as music mixers and sequencers, real-time audio for games, and even audio visualizers. Work with loaded MP3 audio at a lower level by extracting audio data and supplying it to the sound buffer. Process, filter, and mix audio in real time through the Pixel Bender JIT compiler to extend creative freedom beyond the visual experience.
Drawing API - Enhanced
Perform runtime drawing more easily with restyleable properties, 3D APIs, and a new way of drawing sophisticated shapes without having to code them line by line. Developers can tweak parts of curves, change styling, replace parts, and use custom filters and effects, delivering improved throughput, creative control, and greater productivity. Enhancements to the Drawing API add the z dimension, real perspective, textured meshes in 3D space, a retained graphics model, read/write rendering, and triangle drawing with UV coordinates, while adding memory and improving performance.
Hardware acceleration - Enhanced
Use the hardware processing power of the graphics card to paint SWF files into the browser and accelerate compositing calculations of bitmaps, filters, blend modes, and video overlays faster than would be performed in software.
Vector data type - New
Use the new typed array class for better performance, efficiency, and error checking of data.
Dynamic Streaming - New
Show exceptional video with streams that automatically adjust to changing network conditions. Leverage new quality-of-service metrics to provide a better streaming experience.
Speex audio codec - New
Take advantage of the new, high-fidelity and open source Speex voice codec, which offers a low-latency alternative for voice encoding. Flash Player also supports ADPCM, HE-AAC, MP3, and Nellymoser audio.
File upload and download APIs - Enhanced
Bring users into the experience by letting them load and save files from your web application. New file reference runtime access allows local processing of data without roundtripping to the server.
Adobe® Flash® Player je výkonná, lehká kategorie, vysoce výrazový klientský runtime který doručuje silného a shodného uživatele zažívá napříč významnějšími operačními systémy, prohlížeči, mobilním telefonem, a zařízeními. Adobe® (dříve Macromedia) Křiklavý Player - univerzální bohatý klient pro doručování efektivního Adobe Flash zažívá napříč desktopy a zařízeními. Nechejte vás dívat se na nejlepší animaci a zábavy na Webu. To zobrazuje webové aplikační přední strany-konce, účinná webová stránka uživatelská rozhraní, interaktivní online reklama, a šortky-forma dlouhé-formě animaci.
Adobe Flash Player dovoluje vám dívat se na interaktivní webový obsah jako hry, obchodní prezentace, reklamy. Balík zahrnuje jen Flash Player a je samostatnou instalaci. Technicky, toto je křiklavý hráčský ActiveX kontrole. To bude jen hrát na soubor skrz váš internetový prohlížeč.
Nainstalovaný přes 700 milion Internet - connected desktopů a mobilu zařízení, Křiklavý Player umožňuje organizace a jedinci k tomu, aby budovali a doručovat ohromné digitální zkušenosti k jejich koncovým uživatelům. Blesk je světová nejvíce vše prostupující softwarová platforma, dosahující 97% Internet - enabled desktopů celosvětově, stejně jako mnoho populárních zařízení. Od té doby, co to bylo bez omezení designu víc tradičních webových voleb zobrazení, vy můžete použít to jasně a přesně vyjádřit vaši značku a firemní identitu.
Vrchol uvádí:
3D efekty - nové
Vytvořte víc intuitivního, poutavého rozhraní používání zabudované podpory pro 3D efekty. Nastartujte rychle bez toho být 3D pán projektováním v 2D a snadno transformující a oživující v 3D. Rychlá, extrémně lehká kategorie, a jednoduchý--užívat APIs, spolu s 3D nástroji v Adobe® Flash® CS4 Professional softéru, učinit návrh který byl předtím jen přístupný k odborným uživatelům přes ActionScript® jazyk či uživatelské odjinud pocházející knihovny k dispozici pro každého člověka.
Zvyk filtry a efekty - nové
Vytvořte výkonný, real - time efekty pro filmové zkušenosti které rychle se angažují uživatele. S novým Adobe pixelem Bender™, stejná technologie za mnoha filtrů a efektů v Adobe Afteru Effects® softéru, tyto dynamické a interaktivní efekty mohou být použitý v produkci s pozdními účinky CS4 a žít s Flash Player 10. Flám pixelu jen-palec- čas (JIT) kompilátor může také být užívaný pro zpracovat jiné druhy dat, jako zvukové či matematické funkce, asynchronní v separátní niti.
Pokročilá textová podpora - nová
Využijte nový, flexibilní textový motor rozvržení které přináší tisk-kvalitu vydavatelství k pavučině, stavení na víc než 25 roky Adobe odborné znalosti v typografii. Získejte více kontroly nad textovým rozvržením používání rozšiřitelné knihovny ActionScript 3.0 textových součástí k tomu, aby tekly text a sofistikované typografické elementy jako pásky napříč vícenásobnými sloupci, kolem v řadě za sebou obrazy, obousměrný, svisle, či zřetězený společně. Vytvořte mnohojazyčné bohaté internetové aplikace (RIAs) používání přístrojových fontů nyní které může být anti-druhé jméno, okrouhlé, a stylizované, či budovat vaše vlastní jedinečné textové součásti.
Dynamická zvuková generace - nová
Užívej zvětšete zvukový APIs dynamicky generovat audio a vytvořit nové druhy zvukových aplikací jako hudební mixéry a třídičové, reálný čas audio pro hry, a dokonce zvukový představit si. Pracujte s naloženým MP3 zvukový v nižší úrovni extrahováním zvukovým daty a nahrazením to do zvukového buffer. Zpracujte, filtrujte, a míchejte audio v reálném čase skrz Pixel Bender JIT kompilátor k tomu, aby rozšířil tvůrčí svobodu za vizuální zkušeností.
Kresba API - zvětšená
Vykonávejte runtime kresbu snadněji s restyleable nemovitostmi, 3D APIs, a nový způsob kresby sofistikovaných tvarů bez toho, muset kódovat je po řádcích. Vývojáři mohou štípnout části zatáček, změnit styl, vyměnit části, a užívat uživatelské filtry a efekty, doručování zlepšilo výkonnost, tvůrčí kontrola, a větší produktivita. Enhancements Drawing API přidá z dimenze, skutečná perspektiva, upravované dekorativně spleti v 3D prostoru, udržená grafika modeluje, četba/píše překlad, a trojúhelník remizuje s UV sladí se, při přidávající paměti a zlepšování výkonu.
Hardware zrychlení - zvětšené
Užívej hardware zpracovací sílu grafické karty k tomu, aby malovala SWF soubory do prohlížeče a urychlit výpočty kompozice bitových map, filtrů, míchat režimy, a video potáhuje rychleji než by být účinkuje v softéru.
typ datvektoru - nového
Užívej novou napsanou pole třídu pro lepší výkon, efektivitu, a kontrolu chyb dat.
Dynamické proudění - nové
Ukázat výjimečné video s proudy které automaticky uzpůsobit výměnu sítě podmínek. Dělejte pákový efekt nová kvalitní-- metriky služby k tomu, aby poskytovala lepší zalitou slzami zkušenost.
Speex zvukový kodek - nový
Využijte nový, velmi věrnou reprodukcí a otevřený zdrojový Speex hlasový kodek, které nabízí nízkou- alternativu latence pro hlas zakódování. Křiklavý Player také podporuje ADPCM, HE-AAC, MP3, a Nellymoser zvukový.
Registrovat upload a stáhnout APIs - zvětšený
Přineste uživatele do zkušenosti nechat je naložit a chránit soubory z vaší webové aplikace. Nový souborový odkazový runtime přístup dovoluje místní zpracování dat bez cyklu k serveru.
