Aktuálny čas je Pon 26. Okt 2026 9:22:04
 RadioBOSS
 Predmet príspevku: RadioBOSS
PoslaťNapísal: Pon 16. Nov 2009 20:32:36
RadioBOSS is a software product that provides automation capabilities for broadcasting stations, clubs, discos, casinos, shops, cinemas. A large number of features allows using it no matter where you need to play music. The RadioBOSS software can work for months without operator's assistance. Built-in format converter, CD grabber, music database, playlist generator, scheduler, automatic volume control, crossfade and other features make this software a very useful tool to handle your music collection. The simple and convenient interface minimizes the learning curve.Player is the primary component that contains most of the functionality: launching and editing playlists, scheduling, configuring effects and many other. RadioBOSS is a program that allows you play and edit music and broadcast. Musical database that searches you hard drive for music files and saves the list of files into the database. It provides quick search by any field, mass tag editor, sorting, statistics, filter etc.Playlist Generator that generates playlists using templates. You can specify various parameters such as the length of the playlist, generation method, advertisement options, hourly blocks, jingles, rotations. The result is a ready to use playlist that can be broadcast right away.
Key Features:-
· support for mp3, wma, wav, ogg, CD audio formats
· plugins to support other file formats (AAC, FLAC, …)
· automatic generation of playlists using templates
· retranslation is possible
· the ability to run an internet radio station
· indexed music database that supports quick search capabilities
· the level of advertisements and announcements is increased
· you can work with two playlists simultaneously
· built-in effects: echo, reverb, flanger, tempo, pitch
· WinAMP and DirectX (through AdaptX) plugins are now supported
· 12-band equalizer
· crossfade support
· voice track feature
· automatic volume control – all files are played at the same volume
· trimming silence at the beginning and at the end of the track
· the program takes advantage of the multichannel cards (4.0, 5.1, 7.1 etc)
· two independent outputs: stereo split; splitting to channels on multichannel cards; using two sound cards
· flexible scheduling capabilities
· color indication in playlists (jingles and advertisements are highlighted)
· file converter (mp3->wma)
· CD grabber
· support for profiles (individual configuration for each user)
· tag editor that supports any file type
· comments that can be added to any track
· the “playlist in playlist” feature
What's New:-
· Windows Vista/7 Compatible
· Added resizing of interface units
· Support for Unicode
· Player now shows which track is to be played next
· Added launching playlists over air
· Added 'Pause' command to scheduler
RadioBOSS je softwarový produkt, který poskytuje funkce pro automatizaci vysílací stanice, kluby, diskotéky, kasina, obchody, kina. Velké množství funkcí umožňuje používat to bez ohledu na to, kde je třeba přehrávat hudbu. Software RadioBOSS může pracovat po několik měsíců bez pomoci operátora. Built-in formátu převodník, CD hmatat, hudební databáze, playlist generator, plánovač, automatická regulace hlasitosti, crossfade a další funkce, aby tento software velmi užitečným nástrojem pro práci vaší hudební sbírky. Jednoduché a pohodlné rozhraní minimalizuje učení curve.Player je základní složka, která obsahuje většinu funkcí: zahájení a úpravy skladeb, plánování, nastavení efektů a mnoho dalších. RadioBOSS je program, který umožňuje přehrávat a upravovat hudbu a vysílání. Hudební databáze, která si hledá pevný disk pro hudební soubory a uloží do seznamu souborů do databáze. To umožňuje rychlé vyhledávání podle nějaké pole, hmotnost tag editor, třídění, statistiky, filtr etc.Playlist generátor, který generuje seznam skladeb pomocí šablon. Můžete zadat různé parametry, jako je délka skladeb, výrobní metody, možnosti reklamy, hodinových bloků, znělky, rotace. Výsledkem je připraven k použití skladeb, které mohou být vysílány ihned.
Klíčové vlastnosti: --
· Podpora MP3, WMA, WAV, OGG, CD audio formáty
· Pluginy pro podporu jiných formátů souborů (AAC, FLAC, ...)
Automatická generace skladeb pomocí šablon
· Retranslation je možné
· Možnost spustit internetové rozhlasové stanice
· Indexované databáze, hudba, která podporuje rychlé možnosti vyhledávání
· Úroveň reklamy a oznámení, je zvýšená
· Můžete pracovat se dvěma stop současně
· Vestavěný-in efekty: echo, reverb, flanger, tempo, pitch
· WinAMP a DirectX (přes AdaptX) pluginy jsou nyní podporovány
• 12-pásmový ekvalizér
· Crossfade podpora
· Hlas sledovat funkce
Automatická regulace hlasitosti - všechny soubory, které se hrají ve stejný objem
· Ořezávání ticho na začátku a na konci trati
· Program využívá vícekanálový karet (4.0, 5.1, 7.1 atd.)
· Dva nezávislé výstupy: stereo rozdělení, rozdělení na kanály na vícekanálových karet, použití dvou zvukových karet
· Flexibilní plánování kapacit
· Barevné označení v skladeb (znělky a reklamy jsou zvýrazněny)
· Převaděč souborů (mp3-> wma)
· CD Grabber
· Podpora pro profily (individuální nastavení pro každého uživatele)
· Tag editor, který podporuje jakýkoliv typ souboru
· Připomínky, které mohou být přidány do jakékoliv stopy
· "Skladeb v playlistu" feature
Co je nového: --
· Windows Vista / 7 Kompatibilní
· Přidáno změnu velikosti rozhraní jednotek
· Podpora Unicode
· Player nyní ukazuje, které trať má být hrán další
· Přidáno zahájení skladeb přes ovzduší
· Added 'příkaz Pozastavit' do plánovače
