Aktuálny čas je Uto 20. Okt 2026 21:51:43
 ID Unlocker 1.2 - ODBLOKUJTE ČOKOLVEK
 Predmet príspevku: ID Unlocker 1.2 - ODBLOKUJTE ČOKOLVEK
PoslaťNapísal: Ned 15. Nov 2009 20:54:46
ID Unlocker is a high quality performance application,
transcending absolutely all error-messaging programs, unblocking access to all
files.
Unlocks
files that have an error executing. It allows you to see the
content of a folder that shows an error executing message, such as:”
The file is in use by another program or user”, or “The source or
destination file may be in use”.
ID
Unlocker has simply-to-use context menu, with a command line,
letting you choose the action to take. It also provides a “process and
handlers list”, letting you see the name and the path of the process,
and letting you close a handle if you desire.
Enters
programs that show an access deny message. ID
Unlocker simply goes beyond the error accessing message, and allows
you to move files that show error messages like: “There has been a
sharing violation”.
Deletes
stubborn files and index.dat that won’t normally be erased. It
removes and deletes files that have error messages, such as: “Make
sure the disk is not full or write-protected and that the file is not
currently in use.”, or:” Cannot delete file: Access is denied.”
Provides
registration information about the alternative user of the program you
are about to access. ID Unlocker gives you
information about a different source that might be using the program,
and stops it at your request.
Kills
processes at your request. It stops programs and applications
from running if you desire to interrupt its activity, with or without
having to reboot your computer.
Moves
and deletes locked processed and dlls. Applications that have
corrupt content or are permanently locked can be erased or moved.
ID
Unlocker has a convenient easy to use graphic interface, runs
simply and fast with great results, and takes little space on your disk.
ID Unlocker je kvalitní výkon aplikace,
překračujícím naprosto všechny chyby-messaging programy, odblokování přístupu ke všem
souborů.
Odemkne
soubory, které mají chybu provedení. To vám umožní vidět
obsah složky zobrazí chybová vykonávající zprávu, jako například: "
Tento soubor je používán jiným programem nebo uživatele "nebo" zdroj, nebo
Cílový soubor může být v použití ".
ID
Unlocker jednoduše-k-použití kontextové menu, z příkazové řádky,
nechat si vyberete postupu. Poskytuje také "proces a
zpracovávající seznam ", nechat si zobrazit název a cestu k postupu,
a nechat si zpracovat zavřít jestliže si to přejete.
Vstup
programy, které ukazují, že přístup popírají zprávu. ID
Unlocker prostě překračuje chyby přístupu zprávy, a umožňuje
můžete přesunout soubory, které zprávy ukazují chyby jako: "Došlo
narušení sdílení ".
Odstraní
tvrdohlavý a soubory index.dat, že nebude za normálních okolností vymazány. To
odstraňuje a odstraňuje soubory, které mají chybové zprávy, jako například: "Make
zda není disk plný nebo psát-chránit a zda soubor není
v současné době používají. ", nebo:" Soubor nelze odstranit: Přístup byl odepřen. "
Poskytuje
Informace o registraci o alternativních uživatel programu, který
jsou o přístup. ID Odemknout vám
Informace o jiné zdroje, které mohou být pomocí programu,
a zastaví se na požádání.
Kills
procesů na požádání. Zastaví programů a aplikací
z provozu, pokud budete chtít přerušit svou činnost, s nebo bez
nutnosti restartovat počítač.
Tahů
a odstraní zamčené zpracované a dlls. Žádosti, které
poškozený obsah nebo jsou trvale zamčené lze vymazat nebo přesunout.
ID
Unlocker je velmi výhodné pro snadné použití grafického rozhraní, běží
jednoduše a rychle s skvělé výsledky, a má málo místa na disku.
