Aktuálny čas je Str 28. Okt 2026 3:28:32
 Image Line Vocodex v1.0
 Predmet príspevku: Image Line Vocodex v1.0
PoslaťNapísal: Str 11. Nov 2009 8:04:31
Vocodex - the last word in the vocoder, showing the best articulation of envelopes, an integrated synthesizer Airlines and Soundgoodizer maximizer, control over the envelope vocoder and up to 100 groups vocoder multiparameters variable width. Vocodex - your team!.
Coding of speech signals - the process of using the frequency spectrum in real time a sound (modulator) to modulate the frequency spectrum of another (Airlines). Engine vocoder consists of a series of bandpass filters which allow through only those frequencies found in the source of the modulator. For example, when the human voice is used to modulate the synthesizer chord, it would seem that the synthesizer speaks, a classic robot voice from many scientific-fi movies.
Vocodex is the last word in vocoders, featuring advanced articulation envelopes, integrated Carrier synthesizer and Soundgoodizer maximizer, vocoder envelope control and up to 100 variable-width multi-parameter vocoder bands. Vocodex - By your command!.
Vocoding is the process of using the real-time frequency spectrum of one sound (Modulator) to modulate the frequency spectrum of another (Carrier). The vocoder engine consists of a series of bandpass filters that allow through only those frequencies detected in the Modulator source. So, for example, when a human voice is used to modulate a synthesizer chord, it will sound like the synthesizer is talking, the classic robot voice from many sci-fi movies.
Vocodex - poslední slovo v reproduktoru představuje nejlepší artikulaci obálek, integrovaný syntezátor Airlines a Soundgoodizer maximalizovatel kontrola nad rámec reproduktoru a až 100 skupin, vocoder multiparameters variabilní šířku. Vocodex - váš tým!.
Kódování řečových signálů - proces s použitím kmitočtového spektra v reálném čase zvuk (modulátor) modulovat kmitočtového spektra jiného (aerolinie). Motor reproduktor se skládá z řady pásmových filtrů, které umožňují pouze prostřednictvím těchto frekvencích našel ve zdroji modulátoru. Například, když je lidský hlas slouží k modulaci syntezátor akord, by se mohlo zdát, že syntezátor mluví, klasický robot hlas z mnoha vědeckých-fi filmy.
Vocodex je poslední slovo ve reproduktorů, představovat moderní artikulace obálky, integrované Carrier syntezátor a Soundgoodizer maximalizovatel, vocoder obálky kontroly a až 100 proměnlivou šířkou-multi-parametr vocoder kapel. Vocodex - Do vaším velením!.
Vocoding je proces pomocí real-time kmitočtového spektra jednoho zvuku (Modulátor) modulovat frekvenčního spektra jiného (Carrier). Vocoder motoru se skládá z řady pásmových filtrů, které umožňují pouze prostřednictvím těchto frekvencí zjištěn ve zdrojovém modulátor. Takže například, když je lidský hlas slouží k modulaci syntezátor akord, bude to znít jako syntezátor hovoří, klasický robot hlas z mnoha sci-fi filmy.
