Aktuálny čas je Pon 02. Nov 2026 4:01:05
 Lunascape Web Browser 5.1.6 Portable
 Predmet príspevku: Lunascape Web Browser 5.1.6 Portable
PoslaťNapísal: Str 04. Nov 2009 14:59:03
SatHunter is a program for calculating the orientation of a satellite antenna. SatHunter contains all the necessary information for adjusting the satellite antenna to the selected satellite. The adjustment is made with the help of available tools (a compass or a protractor, a plumb, a tape measure) and requires neither expensive equipment nor deep knowledge about satellite television.
Main features:
- Calculates the azimuth and elevation angle.
- Provides a list of satellite transponders for setting up the receiver.
- Calculates the solar azimuth angle.
- Calculates the time when the satellite and solar azimuth angles coincide.
- Calculates the antenna offset angle and tilt.
- Points the antenna using the azimuth with the help of the sun and a protractor.
- Points the antenna using the azimuth with the help of a compass.
- Adjusts the elevation angle with the help of a tape measure and a plumb.
- Detects coordinates by IP or by using a list of cities.
- Detects time using an exact time server.
- Scans transponders with a SkyStar DVB card.
- View signal level and quality with sound signalization.
- Intuitive user interface
Title: SatHunter
Version: 2.2.0.50 Pro Portable Multilang
Developer: Protectedsoft
Homepage: protectedsoft.com
Updated: 2009.11
License / Price: 29.95$(patch)
Language: Multilanguage
Platform: Windows 2K/XP/2K3/Vista/7
SatHunter je program pro výpočet orientace satelitní antény. SatHunter obsahuje všechny nezbytné informace pro nastavení satelitní antény na vybraný satelit. Úprava se provádí pomocí dostupných nástrojů (kompas nebo úhloměr, olovnice, metr) a nevyžaduje ani drahé vybavení, ani hluboké znalosti o satelitní televizi.
Hlavní rysy:
- Počítá azimut a elevační úhel.
- Poskytuje seznam satelitního transpondéru pro nastavení přijímače.
- Výpočet solárního azimutu úhlu.
- Výpočet doby, kdy satelit a sluneční azimut úhly shodné.
- Vypočítá anténa offset úhel a náklon.
- Body anténu pomocí azimutu pomocí slunce a úhloměr.
- Body anténu pomocí azimutu pomocí kompasu.
- Upraví vrchol úhlu s pomocí pásky opatření a olovnice.
- Zjišťuje souřadnice IP nebo pomocí seznamu měst.
- Detekuje čas pomocí přesného časového serveru.
- Kontroluje transpondérů s kartou SkyStar DVB.
- Podívejte se úroveň signálu a kvalita zvuku signalizací.
- Intuitivní uživatelské rozhraní
Název: SatHunter
Verze: 2.2.0.50 Portable Pro Multilang
Domovská stránka: protectedsoft.com
Aktualizováno: 2009,11
License / Cena: 29,95 $ (patch)
Jazyk: Multilanguage
Platforma: Windows 2K/XP/2K3/Vista/7
