Aktuálny čas je Sob 26. Sep 2026 9:21:47
 Uninstall Expert v3.0.1.2103
 Predmet príspevku: Uninstall Expert v3.0.1.2103
PoslaťNapísal: Uto 27. Okt 2009 17:33:50
Uninstall Expert is an easy-in-use and powerful applications that helps you to uninstall unneeded programs completely from your computer. With Uninstall Expert, users can uninstall applications much faster than Windows Add/Remove program, sometimes 5-10 times faster. Still users can pick up the "hidden" programs which can't be displayed by Windows Add/Remove program.
Normally Add/Remove program can not uninstall applications completely, but Uninstall Expert can scan deeply into the computer, and then any broken registry keys and unused files on the hard disk can be removed completely.
Features Overview:
# Clear up remnants of program files and registry keys after uninstalling.
# Ability of uninstalling screen savers.
# Scan all installed applications' details on your computer.
# Lightning speed at startup is faster than the Add/Remove Program of Windows XP.
# Quickly open program install folders, company sites or support sites.
# Create a full report for installed programs and save reports to a text file.
# List all installed programs, system updates and screen savers quickly.
# Backup the registry info of all installed programs.
# Open and run any installed program quickly.
# Add comments for selected programs in the registry.
# Export program registry information.
# Export program list and print or save it at will.
# Display programs in 3 different views (Icons, List and Report).
# Friendly and easy-to-use GUI.
System Requirements:
# Processor type: Pentium
# Processor speed: 233 MHz
# Memory (Cache): 64 MB RAM Minimum
# Hard disk: IDE
# Operating system: Windows 98/2000/XP/2003/Vista
# Graphics: 256 colors @ 800 x 600
Username.....: EMBER
Email........: *anything*
Serial.......: UE8795461
Odinstalovat Expert je jednoduché-in-use a výkonné aplikace, které vám pomůže kompletně odinstalovat nepotřebné programy z vašeho počítače. S Uninstall Expert mohou uživatelé odinstalovat aplikace mnohem rychlejší, než Windows Přidat / Odebrat program, někdy 5-10 krát rychlejší. Stále uživatelé mohou vyzvednout "skryté" programy, které nelze zobrazit Windows Přidat / Odebrat program.
Normálně Přidat / Odebrat program nemůže zcela odinstalovat aplikace, ale Uninstall Expert lze skenovat hluboko do počítače a pak poškozených klíčů registru a nepoužívané soubory na pevném disku mohou být odstraněny úplně.
Přehled funkcí:
# Uklidit zbytky programové soubory a klíče registru po odinstalování.
# Schopnost odinstalaci spořiče obrazovky.
# Testovat všechny instalované aplikace 'na vašem počítači.
# Lightning rychlost při spuštění je rychlejší než Přidat nebo odebrat programy systému Windows XP.
# Rychle otevřít program instalovat složky společnosti weby nebo weby podporu.
# Vytvoření kompletní zprávu o instalované programy a ukládat zprávy do textového souboru.
# Vypíše všechny nainstalované programy, aktualizace systému a spořiče obrazovky rychle.
# Zálohování registru údaje o všech nainstalovaných programů.
# Open a spustit jakýkoli instalovaný program rychle.
# Přidejte komentář pro vybrané programy v registru.
# Program Export informací v registru.
# Export seznamu programů a vytisknout nebo uložit na vůli.
# Displej programů ve 3 různých zobrazení (ikony, Seznam a zpráva).
# Friendly a bezstarostný-až k-cvičení GUI.
Systémové požadavky:
# Typ procesoru: Pentium
# Rychlost procesoru: 233 MHz
# Paměti (cache): minimálně 64 MB RAM
# Pevný disk: IDE
# Operační systém: Windows 98/2000/XP/2003/Vista
# Grafika: 256 barev @ 800 x 600
