Aktuálny čas je Ned 25. Okt 2026 14:08:10
 Bios Utilities All-In-One
 Predmet príspevku: Bios Utilities All-In-One
PoslaťNapísal: Pon 26. Okt 2009 15:47:16
Now all modern motherboards are equipped with proprietary utilities for monitoring and controlling the basic parameters of work. But not every obsolete computer can possess them. Presented assembly tools, is a universal tool to work with Bios computers older than 4 years.
In the pack includes:
01: Bios Agent v3.45
02: Magic Bios v2.0
03: BIOS Patcher v4.00 RC 7.1
04: Bios v1.35.1
05: BIOS Information Tool v1.1
06: CmosPwd v4.6
07: E-book: The BIOS Companiont
The utility displays information about the computer's BIOS. In addition, BIOS Agent displays information about processor, memory and some other components of the system. Displays the following data: BIOS Date, Motherboard OEM data, CPU data, BIOS Type, Motherboard Chipset, BIOS ROM data, BIOS ID String, Super I / O data, Memory data. The utility is useful to those who follow the BIOS and uses only the new firmware. The program interface is simple and intuitive. Additional features include BIOS Agent printing function data obtained using this utility.
02: Magic Bios v2.0
Company EPoX has released a new version of the utility Magic BIOS, intended for flash BIOS on motherboards of products for Windows.
This utility is designed to eliminate errors, defects and limitations in the original BIOS of motherboards.
The author recommends to use the free version from the platform class Pentium 1/2/3, with care for the Pentium 4 platform, and is not recommended for platforms AMD K7 (only for beta testers), given the large number of potential innovations not regulated.
04: Bios v1.35.1
06: CmosPwd v4.6
Allows you to recover your forgotten password BIOS.
Note: for use in Windows NT/W2K/XP/2003 need to first install the driver ioperm ( "ioperm.exe-i"), and then run Cmospwd_win.exe.
Complete reference of the Bios in English.
Nyní jsou všechny moderní základní desky jsou vybaveny vlastní nástroje pro sledování a kontrolu základních parametrů práce. Ale ne každý zastaralý počítač může mít ně. Prezentované montážní nářadí, je univerzální nástroj pro práci s počítači Bios starší než 4 roky.
V balení obsahuje:
02: Magic Bios v2.0
04: Bios v1.35.1
06: CmosPwd v4.6
07: E-knihy: BIOS Companiont
Nástroj zobrazuje informace o systému BIOS počítače. Kromě toho, BIOS Agent zobrazí informace o procesoru, paměti a některé další součásti systému. Zobrazí následující údaje: Datum BIOS, OEM data základní desky, procesoru data, BIOS Typ, Čipová sada základní desky, BIOS ROM dat, BIOS ID String, Super I / O data, Memory data. Nástroj je užitečné pro ty, kteří následují BIOS a používá pouze nový firmware. Programové rozhraní je jednoduché a intuitivní. Mezi další funkce patří BIOS Agent údaje tiskové funkce získané pomocí této utility.
02: Magic Bios v2.0
Společnost EPoX vydala novou verzi nástroje Magic BIOS, určené pro flash BIOSu na základních deskách produktů pro Windows.
Tento nástroj je určen k odstranění chyby, nedostatky a omezení v původním BIOSu základních desek.
Autor doporučuje použít volnou verzi z platformy třídy Pentium 1/2/3, s péčí o platformě Pentium 4, a proto se nedoporučuje pro platformy AMD K7 (pouze pro beta testery), vzhledem k velkému počtu možných inovací není regulovány.
04: Bios v1.35.1
06: CmosPwd v4.6
Umožňuje obnovit zapomenuté heslo systému BIOS.
Poznámka: pro použití v systému Windows NT/W2K/XP/2003 potřeba nejprve nainstalovat ovladač ioperm ( "ioperm.exe-i"), a spusťte Cmospwd_win.exe.
Kompletní odkaz Bios v angličtině.
