Aktuálny čas je Pon 19. Okt 2026 8:46:14
Vytvoriť novú tému Odpovedať na tému  [ Príspevkov: 4 ]
 New - RegCure 2.0.0.0
 Predmet príspevku: New - RegCure 2.0.0.0
PoslaťNapísal: Štv 22. Okt 2009 14:57:16
RegCure™ (from ParetoLogic®) provides fast and efficient scanning and cleaning of your registry so that your computer can run at an optimal level of performance. RegCure identifies invalid registry items and you decide what items you want to remove. After removing registry entries, you have the option to restore your computer to a previous state.
Protect your investment and ensure maximum PC speed and performance with RegCure registry cleaner. Compatible with all Microsoft products and third party applications, RegCure seeks out and repairs those issues in your registry that lead to poor performance such as remnants left behind on your registry from failed installations, incomplete un-installations, disabled drivers, and spyware applications. RegCure enables you to fix your PC's windows registry in the way that is most comfortable for you. Clean your registry manually according to your own specifications or perform a thorough scan and clean it automatically! The user-friendly interface allows you to monitor the progress of your scan, schedule RegCure to scan at the times that are best for you and will even manage and clean up your start up programs for you if you wish.
RegCure cleans and optimizes your Windows Registry :
• COM/ActiveX
• uninstall Entries
• Font Entries
• Shared DLLs
• Application Paths
• Help Files Information
• Windows Startup Items
• File/Path References
• Program Shortcuts
• Empty Registry Keys
• Shell Extensions
• Custom scans
• Automatic scanning with the scheduling tool
• Selection and removal
• Ignore list
• Automatic repair
• Backup and restore
• Startup management
RegCure offers the following features and benefits:
• Custom scans: you can customize how RegCure scans your registry by selecting only the items you want to be scanned. There is a list of registry items that you can check or clear during step 1 of the scanning process.
• Automatic scanning with the scheduling tool: with RegCure you can create schedules so that a registry scan is done automatically. Using the schedule feature you can set more than one schedule to run daily, weekly, monthly, at system startup, and more.
• Selection and removal: You can choose which items RegCure has detected after it completes the registry scan. In step 3 of the process, you can clear the items that you do not want removed.
• Ignore list: RegCure offers you the ability to ignore items that have been detected after the registry is scanned. In this way these items will be ignored for subsequent scans. There is an Ignore list that you can manage should you want to have these items scanned and removed in the future.
• Automatic repair: RegCure offers you the ability to perform an automatic repair of detected items after a scan. You can configure the settings so that a repair of detected items occurs after each scan.
• Backup and restore: An automatic backup is created every time you use RegCure. You can restore the items that were removed.
• Startup management: RegCure offers quick and easy access to all the programs that are launched when you start your computer. You can enable and disable applications in the Manage Startup list.
RegCure ™ (od ParetoLogic ®) poskytuje rychlé a efektivní prohledávání a čištění registru tak, aby počítač mohl běžet na optimální úroveň výkonu. RegCure zjistí neplatné položky registru a vy se rozhodnete, jaké položky, které chcete odstranit. Po odstranění položky registru, máte možnost obnovit počítač do předchozího stavu.
Ochránili své investice a zajistí maximální rychlosti a výkonu počítače s RegCure registru čistší. Kompatibilní se všemi produkty společnosti Microsoft a aplikace třetích stran, RegCure hledá a opravy těchto otázek v registru, které vedou ke slabým výsledkům, jako jsou zbytky po sobě zanechal v registru z selhalo zařízení, neúplné, un-instalace, zdravotně postižené řidiče a spyware. RegCure umožňuje opravit PC oken rejstříku způsobem, který je pro vás nejpohodlnější. Vyčistěte si registry ručně podle vlastních specifikací nebo provést důkladnou kontrolu a vyčistěte ji automaticky! User-přívětivé rozhraní vám umožní sledovat postup skenování, rozvrh RegCure skenovat v časech, které jsou pro vás nejlepší, a bude ještě spravovat a vyčistit si spustit programy pro vás, pokud budete chtít.
RegCure čistí a optimalizuje váš registru systému Windows:
• COM / ActiveX
• odinstalujte Příspěvky
• Písmo Příspěvky
• Sdílené knihovny DLL
• Aplikační Cesty
• Informace souborů nápovědy
• Po spuštění systému Windows položky
• Soubor / Cesta Odkazy
• Program Zkratky
• Vyprázdněte Klíče v registru
• Shell Extensions
• Vlastní skenování
• Automatické skenování s nástrojem plánování
• Výběr a odstraňování
• Ignorovat seznam
• Automatické opravy
• Zálohování a obnovení
• Po spuštění management
RegCure nabízí následující vlastnosti a výhody:
• Vlastní skenování: můžete nastavit, jak RegCure prohledá registry výběrem pouze položky, které chcete skenovat. Tam je seznam položek registru, které můžete navštívit, nebo jasně ukázalo během kroku 1 z procesu skenování.
• Automatické skenování s nástrojem plánování: s RegCure můžete vytvářet plány tak, aby registru scan je prováděna automaticky. Používání programu funkci, můžete nastavit více než jeden program spustit denní, týdenní, měsíční, při spuštění systému, a další.
• Výběr a odstranění: Můžete si vybrat, které položky RegCure zjistil, že po dokončení registru scan. V kroku 3 tohoto procesu, můžete zrušit položky, které nechcete odstranit.
• Ignorovat seznam: RegCure nabízí možnost ignorovat položek, které byly zjištěny po registru kontrolují. Tímto způsobem se tyto položky budou ignorovány pro pozdější prohlédnutí. Existuje Ignore list, který si můžete spravovat byste měli chtít, aby tyto naskenované položky a odstraněn v budoucnosti.
• Automatické opravy: RegCure nabízí schopnost provádět automatické opravy zjištěných položek po skenování. Můžete nakonfigurovat nastavení tak, aby oprava zjištěných položek dochází po každém skenování.
• Zálohování a obnovení: automatická záloha je vytvořen při každém použití RegCure. Můžete obnovit položky, které byly odstraněny.
• Startup řízení: RegCure nabízí rychlý a snadný přístup ke všem programům, které se spustí při spuštění počítače. Můžete povolit nebo zakázat použití v seznamu Spravovat spuštění.
 Predmet príspevku: Re: New - RegCure 2.0.0.0
PoslaťNapísal: Uto 10. Nov 2009 16:09:25
Registrovaný: Uto 10. Nov 2009 16:03:20
Hotovosť: 52.00
..nejako nevidim heslo na rozbalenie.
PoslaťNapísal: Uto 10. Nov 2009 17:28:28
jedentt píše:
Čaues....###
Kámo ale ved pass je tam - no, že sa lepšie kukni a určite ho uvydíš..!!!
PoslaťNapísal: Ned 27. Dec 2009 11:40:05
Hotovosť: 52.00
pista píše:
jedentt píše:
Čaues....###
Ahoj !
jj, asi som mal ocny zakal. som si to potom vsimol.
ale tusim mi viac vyhovuje windows xp manager. vyzera to, ze ten ide do vacsej hlbky systemu aj oproti TuneUpUtilities, ktory pouzivam uz dlhsie.
