Aktuálny čas je Ned 01. Nov 2026 14:54:32
 Windows 7 Manager 1.1.4 Final x86x64
 Predmet príspevku: Windows 7 Manager 1.1.4 Final x86x64
PoslaťNapísal: Štv 22. Okt 2009 14:28:47
The complete solution to optimize, tweak, clean up Windows 7! A all-in-one utility to tweak, optimize, tweak, tune up and clean up your Windows 7, it bundles more than 30 different utilities in one and help your system faster and more stable, secure and personal! Windows 7 Manager is a system utility that helps you optimize, tweak, and clean up Windows 7. It will increase your system speed, improve system security, and meet all of your expectations.
Windows 7 is the newest Operating System for home users and professionals alike. Windows 7 brings clarity to your world, so you can more safely and easily accomplish everyday tasks and instantly find what you want on your PC.
Windows 7 Manager is the powerful software tool to tweak and optimize your Windows 7, it bundles more than 30 different utilities in one and help your system faster and more stable, secure and personal!
Features and Benefits of Windows 7 Manager:
• Information. Get detailed system and all hardware information on your system; show all detailed information of running processes and threads on your machine; Windows 7 Manager offers 1-clicking cleans your system automatically.
• Optimizer.Tweak your system to improve windows startup and shutdown speed; tweak your hardware to increase system speed and performance; Optimize Task Schedule to turn off unnecessary system tasks.
• Cleaner. Find out which files or folders engross your disk space and shown with chart; Find and clean junk files to increase Hard Disk space; Duplicate Files Finder can scan your computer for files with the same size, name and modification time; Registry Cleaner can easily checks your registry and repair incorrectly linked registry entries, automatically remove invalid entries; Registry Defrag rebuilds and re-indexs your registry to reduce application response time and registry access time.
• Customization. Control what is started on Windows startup; tune up Windows 7 boot menu; edit context menus of mouse Right-Clicking; customize system desktop, menus, toolbar and notifications settings; automatically change your desktop wallpaper on background.
• Security. You can improve desktop, menus, Windows logon securities, and enable numerous hidden performance options of system, disable system updates and error reports; hide and restrict to access drives, specify which applications are not allowed to be executed on your computer; encrypt/decrypt and shred files, change the location of system folders; Privacy Protector can maintain your personal privacy by eliminating the tracks that you leave behind; create lots of randomization password once.
• Network. Optimize your Internet connection speed, manage all shares items; tweak your Internet Explorer easily.
• Misc. Utilities. Show the collection of Windows utilities; help you find out the installation key of Windows, Office products; shutdown your PC or remind you automatically.
Kompletní řešení pro optimalizaci, vyladit, uklidit Windows 7! All-in-one utilita pro vyladění, optimalizaci, vyladit, naladit a vyčištění systému Windows 7, se svazky více než 30 různých utilit v jednom a pomůže váš systém rychlejší a stabilnější, bezpečnější a osobní! Windows 7 Manager je systémový nástroj, který vám pomůže optimalizovat, štípnout, a vyčistit Windows 7. To zvýší rychlost vašeho systému, zlepšit zabezpečení systému, a splnit všechny vaše očekávání.
Windows 7 je nejnovější operační systém pro domácí uživatele i profesionály. Windows 7 přináší jasnost do svého světa, takže můžete snadno a bezpečně více plnit každodenní úkoly a okamžitě najít to, co chcete ve vašem počítači.
Windows 7 Manager je výkonný softwarový nástroj pro vyladění a optimalizaci systému Windows 7, se svazky více než 30 různých utilit v jednom a pomůže váš systém rychlejší a stabilnější, bezpečnější a osobní!
Vlastnosti a výhody Windows 7 Správce:
• informace. Získejte podrobný systém a veškeré informace o hardwaru na vašem systému, zobrazit všechny podrobné informace o běžících procesů a vláken na vašem počítači, Windows 7 Manager nabízí 1-kliknutím čistí váš systém automaticky.
• Optimizer.Tweak systému s cílem zlepšit okna spouštění a vypínání rychlosti, vyladění hardwaru pro zvýšení rychlosti a výkonu systému; Optimalizovat pracovní rozvrh pro vypnutí systému zbytečné úkoly.
• Čistič. Zjistit, které soubory nebo složky ovládnout místo na disku a zobrazí se graf; Najít a čisté nevyžádané soubory ke zvýšení na pevném disku; Duplicate Files Finder můžete v počítači vyhledat soubory se stejnou velikost, jméno a změna času, Registry Cleaner snadno kontroly registru a opravy chybně spojené položky registru, automaticky odstranit neplatné položky, Registry Defrag rekonstrukce a re-indexs registru ke snížení odezvy aplikací a přístup k registru čas.
• Přizpůsobení. Kontrola toho, co je spuštěn při každém startu Windows, naladit Windows 7 boot menu, upravit kontextové menu myší Right-Kliknutím; přizpůsobit systém ploše, menu, panel nástrojů a oznámení nastavení, automaticky měnit tapetu na plochu pozadí.
• Bezpečnost. Můžete zlepšit pracovní ploše, menu, dotaz na cenné papíry a umožňují řadu skrytých možností výkonu v systému, vypnout aktualizace a chybová hlášení, skrýt a omezit přístup jednotky, určují, které aplikace nesmějí být prováděny na počítači, šifrování / dešifrování rozřezat a soubory, změnit umístění systémových složek, Privacy Protector může udržet si své soukromí tím, že odstraňuje stopy, které za sebou zanecháváte, vytvořit spoustu náhodného hesla jednou.
• Network. Optimalizujte své rychlosti připojení k Internetu, spravovat všechny akcie položky; vyladění aplikace Internet Explorer jednoduše.
• Misc. Utility. Zobrazit sady nástrojů Windows, vám pomůže zjistit, instalační klíč systému Windows, Office, vypnutí počítače, nebo vám připomenout automaticky.
