Aktuálny čas je Pia 04. Sep 2026 5:18:16
 ClickBook v12.0.0.7
 Predmet príspevku: ClickBook v12.0.0.7
PoslaťNapísal: Ned 04. Okt 2009 13:31:29
You need to print books. You don't need to spend a lot of money to doing so. You could purchase an expensive program like InDesign ($700) to make books, brochures, and eBooks, or you could use ClickBook. With ClickBook you design with Microsoft Word or any program you know and like, and then ClickBook turns your work into a book, brochure, bulletin, poster, or PDF. Easier to use, you don't have to learn a whole new program and you save hundreds of dollars. ClickBook is an award winning booklet printing application, made by Blue Squirrel, that saves you both time and money. ClickBook can save you up to 75% on ink and paper. ClickBook also offers the convenience of printing your own booklets or brochures, saving you time and money.
No more searching for or purchasing different bulletins or brochures for every occasion, or running around town looking for a local printing shop to print your booklets. Simply create the brochure, bulletins, or booklets you want and print them in ClickBook using any of the 170+ different layouts (50+ for the Mac).
ClickBook, is a powerful yet easy to use printing utility.
Easy to install and setup, without the need to learn a how to use a whole new application. ClickBook works like a printer on your system, simply open or create a document then print it to the ClickBook Printer. ClickBook will then open with your document as a print job, next all you have to do is select the layout you want to print with, then click the print button.
ClickBook will scale, rotate, paginate, and duplex print your document into the layout style that you have chosen. It really is that easy to use.
+ 64-Bit OS Compatible.(Vista only.) NEW!
+ Image removal saves time and expensive ink.NEW!
+ Reverse Printing. NEW!
+ New ZINE Layout!NEW!
+ Updated PDF ConverterNEW!
+ Improved Preview with Magnified Zoom - up to 800% and Keyboard shortcuts. NEW!
+ Updated Macro SecurityNEW!
+ Create Custom Letterhead NEW!
+ Create Custom Forms to print. NEW!
+ Create Custom Backgrounds to print your planner or booklet pages.NEW!
+ Quick Click Printers to instantly print booklets, brochures and pdfs.
+ Vista Compatible.
+ Instantly e-mail PDF files to family, and friends.
+ Works with any Inkjet or Laser printer.
+ Hand Fed Tray - Now you can use the hand fed tray instead of the printing drawer with ClickBook.
+ Convert booklets to PDFs.
+ Rearrange print order of each mini-page in a booklet.
+ Print multi-page Banners and Posters.
+ Use 75% less paper with booklet printing!
+ Walks you through double-sided printing.
+ Prints 170+ different styles!
+ Rotates, reduces & realigns documents automatically.
+ Combine files from different applications into a single printout.
+ Save time and money.
+ One-click to Add or Delete a Page.
+ Sample documents.
+ One-click booklet printing from Microsoft Office applications.
Musíte tisk knih. Nemusíte utrácet spoustu peněz na tom. Dalo by se koupit drahý program, jako je InDesign (700 dolarů), aby se knihy, brožury a knihy, nebo můžete použít ClickBook. S ClickBook vám design s aplikací Microsoft Word nebo jakýkoliv program, které znáte a podobně, a pak ClickBook změní vaše práce do knihy, brožury, bulletin, plakát, nebo PDF. Snadnější použití, nemusíte se učit úplně nový program a ušetříte stovky dolarů. ClickBook je oceněný tisk brožur žádosti, k němuž došlo Blue veverky, které vám ušetří čas i peníze. ClickBook můžete ušetřit až 75% na inkoust a papír. ClickBook také nabízí pohodlí vlastní tisk brožur a prospektů, což vám ušetří čas a peníze.
Už žádné hledání, nebo nákupem jiného bulletiny a brožury pro každou příležitost, nebo běhá po městě hledali místní tiskárnu pro tisk brožur. Jednoduše vytvořit brožury, bulletiny, nebo brožur, které chcete vytisknout, a je v ClickBook použitím kteréhokoliv z 170 + různá rozložení (50 + pro Mac).
Funkce:
ClickBook, je výkonný, ale snadno ovladatelný nástroj tisk.
Snadná instalace a nastavení, aniž by bylo nutné se naučit, jak používat zcela novou aplikaci. ClickBook funguje jako tiskárna ve vašem systému, stačí otevřít nebo vytvořit dokument pak ji vytisknout na tiskárně ClickBook. ClickBook pak otevřete s dokumentem v tiskové úlohy, příští vše, co musíte udělat, je vybrat rozvržení při tisku s, pak klikněte na tlačítko Tisk.
ClickBook bude měřítko, rotace, stránkovat, a oboustranného tisku dokumentu do rozložení stylu, který jste si vybrali. Je to opravdu tak snadné použití.
+ 64-bit OS kompatibilní. (Vista only.) NOVINKA!
+ Galerie odstranění šetří čas a drahé ink.NEW!
+ Reverse tisk. NEW!
+ Nové ZINE Layout! NOVINKA!
+ Aktualizováno PDF ConverterNEW!
+ Lepší náhled s Zvětšené zoom - až 800% a klávesové zkratky. NEW!
+ Aktualizováno Makro SecurityNEW!
+ Vytvořit vlastní Hlavičkový NEW!
+ Vytvořit Vlastní formuláře pro tisk. NEW!
+ Vytvořit vlastní Backgrounds k tisku autem nebo brožury pages.NEW!
+ Rychlé Klepněte na položku Tiskárny okamžitě tisk brožury, letáky a PDF.
+ Vista kompatibilní.
+ Okamžitě souborů e-mailem ve formátu PDF na rodinu a přátele.
+ Pracuje s inkoustové nebo laserové tiskárny.
+ Hand Fed zásobník - Nyní můžete použít ruční krmení zásobník namísto tisku zásuvkou ClickBook.
+ Převést do PDF brožur.
+ Přeuspořádat pořadí tisku jednotlivých mini-stránku v brožuře.
+ Tisk multi-stránky transparenty a plakáty.
Použijte + 75% méně papíru, tisk brožur!
+ Vás provede double-oboustranný tisk.
Tiskoviny + 170 + různé styly!
+ Otočí, snižuje & realigns dokumenty automaticky.
+ Kombinování souborů z různých aplikací do jednoho výtisku.
+ Ušetřete čas a peníze.
+ One-klepněte na tlačítko Přidat nebo Odstranit stránku.
+ Vzorových dokumentů.
+ One-Click tisk brožur, tisk z aplikací Microsoft Office.
