Aktuálny čas je Pia 05. Jún 2026 0:57:38
 Arturia CS 80v2 VSTi v2.0 REPACK
 Predmet príspevku: Arturia CS 80v2 VSTi v2.0 REPACK
PoslaťNapísal: Sob 03. Okt 2009 21:08:17
* REPACK NOTE * Our previous release doesn't install ArtFfct.dll, it will be located correctly from now.
The CS-80V is the reproduction of the legendary Yamaha® CS-80, which was considered by many as the "ultimate polyphonic synthesizer", back in the late 70’s. It has been popularized by artists and groups like Toto, Jean-Michel Jarre, Keith Emerson, Stevie Wonder, Vangelis, Ultravox, Peter Gabriel… to name a few, and they all helped to turn this synthesizer into a real myth. More than twenty five years after its release, the time has come to rediscover a sound that has extensively contributed to the history of music.
2.0 FEATURES:
* Switch to Syncrosoft copy protection ( V 2.0 )
* VCF audio quality improvements ( V 2.0 )
* Ring modulator audio quality improvements ( V 2.0 )
* A revolutionary preset navigation system called the SoundMap ( V 2.0 )
* Lower CPU utilization on Mac OSX( V 2.0 )
* Better Audio Unit compatibility (Digital Performer most notably) ( V 2.0 )
* Ability to use NRPN midi messages for automation ( V 2.0 )
* Better handling of control surfaces while changing preset ( V 2.0 )
* New presets added ( V 2.0 )
* Midi RPN "pitch bend range" message is now recognized( V 2.0 )
* Bug fixes
MAIN FEATURES:
* All the original parameters of the Yamaha CS-80: 2 oscillators, 4 filters (high pass, low pass), 2 LFOs, 4 envelopes, 2 VCAs, 1 sub-oscillator (LFO), 1 ring modulator, chorus and tremolo
* New effect: Delay
* New Multi Mode: assign a different sound to each of the 8 voices of polyphony!
* New Modulation Matrix with 12 sources to modulate a choice of 38 destination parameters
* More than 400 presets made by a selection of the most famous sound designers
* Polyphonic aftertouch
* 1 Arpeggiator
* Expression and sustain pedals
* Ribbon controller
* No aliasing from 0.1 Hz to 16 kHz
* 64-bit floating point precision
* Sampling rate: up to 96 kHz
Benefit from the experience of the best sound designers. The CS-80V comes loaded with more than 400 presets made by a selection of talented sound designers.
* We included additional presets in this release
* Factory Preset works fine at our test
Repack * Poznámka * Naše předchozí verzi nenainstaluje ArtFfct.dll, bude umístěn správně, od této chvíle.
CS-80V je reprodukce legendární Yamaha ® CS-80, který byl považován mnohými za "konečný polyfonní syntezátor", zpět v pozdních 70. let. To byl propagován umělců a skupin, jako Toto, Jean-Michel Jarre, Keith Emerson, Stevie Wonder, Vangelis, Ultravox, Peter Gabriel ... abychom jmenovali alespoň některé, a všichni pomohli proměnit tuto syntezátor v reálném mýtus. Více než dvacet pět let po jejím vydání, je nejvyšší čas začít znovu objevovat zvuk, který významně přispěla k historii hudby.
2.0 VLASTNOSTI:
* Přepněte se na ochranu kopírování Syncrosoft (V 2.0)
* VCF zlepšení kvality zvuku (V 2.0)
* Ring modulator zlepšení kvality zvuku (V 2.0)
* Revoluční přednastavených navigační systém s názvem SoundMap (V 2.0)
* Nižší využití procesoru na Mac OSX (V 2.0)
* Lepší Audio Unit kompatibilita (Digital Performer především) (V 2.0)
* Schopnost používat NRPN midi zprávy pro automatizaci (V 2.0)
* Lepší manipulace s řídící plochy při změně přednastavené (V 2.0)
* Nové přednastavení přidané (V 2.0)
* Midi RPN "pitch bend range" zpráva je nyní rozpoznán (V 2.0)
* Bug fixes
HLAVNÍ ZNAKY:
* Všechny původní parametry Yamaha CS-80: 2 oscilátory, 4 filtry (horní propust, dolní propust), 2 LFOs, 4 obálky, 2 VCAs, 1 sub-oscilátor (LFO), 1 kruhový modulátor, chorus a tremolo
* Nový efekt: Zpoždění
* New Multi Mode: přiřadit jiný zvuk pro každý z 8 hlasů polyfonie!
* Nové Modulace Matrix s 12 zdroji modulovat výběr 38 určení parametrů
* Více než 400 přednastavených provedené výběrem z nejznámějších zvukařů
* Polyfonní aftertouch
* 1 Arpeggiator
* Exprese a udržet pedály
* Pásky controller
* No aliasing od 0,1 Hz do 16 kHz
* 64-bit floating point přesnost
* Vzorkovací frekvence: až 96 kHz
Těžit ze zkušeností těch nejlepších zvukařů. CS-80V ale jděte břímě s více než 400 presetů provedené výběr talentovaných zvukařů.
* My včetně další předvoleb v této verzi
* Tovární přednastavení funguje v našem testu
