Aktuálny čas je Sob 24. Okt 2026 6:50:00
 Conceiva ConvertHQ v1.1.1.1
 Predmet príspevku: Conceiva ConvertHQ v1.1.1.1
PoslaťNapísal: Pia 25. Sep 2009 9:56:47
ConvertHQ is your complete audio & video conversion utility. It converts files to all popular audio & video file formats - for your computer, portable media player, mobile phone, digital media appliance, games console and more. If you need to convert an audio or video file, then ConvertHQ is the perfect choice!
ConvertHQ is optimized for high-quality conversions, yet has easy-to-use presets for each file format so you do not have to be an audio/video expert to create great-looking, great-sounding files! Just select your file and the file format to convert to. Then click Start and that's it!
ConvertHQ converts files into formats that you use everyday.
ConvertHQ can create files for all popular portable media players (iPod, Zune, PSP, Nintendo DS), mobile phones, PS3, Xbox 360, digital media appliances and much more. In fact, ConvertHQ has among the most comprehensive file format support of all audio & converters available today!
Perfect for home users. Even better for digital geeks.
ConvertHQ has been designed for home users in mind. Just select High, Medium or Low settings when converting and great-looking, great-sounding files will be generated every time. You don't need to understand terms like bitrate, sample rate, frame rate, GOP, QCIF, etc. ConvertHQ looks after it for you.
A great timesaver is the ability to convert complete folders of files in just one click. Some conversions can take a long time, so ConvertHQ lets you schedule your conversions for a later time when its convenient.
If you are familiar with audio & video, then you will find ConvertHQ to be a must-have utility. Using ConvertHQ's custom settings, you can adjust all audio and video parameters so that you get exactly the file that you need. You are in full control with ConvertHQ!
You have two choices with ConvertHQ
Two editions of ConvertHQ are available - ConvertHQ Premium and ConvertHQ. ConvertHQ Premium is the professional edition that supports all popular formats. Its superior support will mean that you will have a converter for your current and future needs. ConvertHQ contains the same features as ConvertHQ Premium but supports just the common formats at an affordable price.
ConvertHQ je vaše kompletní audio a video konverzní utilita. Převádí soubory všech populárních audio a video formátů - pro váš počítač, přenosný přehrávač médií, mobilních telefonů, digitálních médií zařízení, herní konzole a další. Pokud potřebujete převést audio a video souborů, pak ConvertHQ je ideální volbou!
ConvertHQ je optimalizován pro vysoce-kvalitní konverze, ale má snadný-k-používat nastavení pro každý formát souboru, takže nemusíte být audio / video expert na vytvoření pra-hledáte, velký-znít soubory! Stačí si vybrat a soubor převést do formátu. Klepněte na tlačítko Start a je to!
ConvertHQ převádí soubory do formátů, které používáte každý den.
ConvertHQ mohou vytvářet soubory pro všechny populární přenosné multimediální přehrávače (iPod, Zune, PSP, Nintendo DS), mobilní telefony, PS3, Xbox 360, digitálních médií spotřebiče a mnoho dalšího. Ve skutečnosti, ConvertHQ má mezi nejvíce komplexní podporu formátu všech audio a převodníky jsou k dispozici ještě dnes!
Perfektní pro domácí uživatele. Ještě lepší pro digitální geeks.
ConvertHQ byl navržen pro domácí uživatele. Stačí si vybrat Vysoká, Střední nebo Nízká nastavení při konverzi a velký-hledáte, velký-znějící soubory budou generovány pokaždé. Nemusíte pochopit pojmy jako bitrate, vzorkovací frekvence, počet snímků za sekundu, GOP, QCIF, atd. ConvertHQ stará za vás.
Timesaver velká je schopnost převést kompletní složky souborů jedním kliknutím. Některé převody mohou trvat dlouhou dobu, takže ConvertHQ umožňuje naplánovat své konverze na pozdější dobu, kdy své výhodné.
Pokud jste obeznámeni s audio a video, pak zjistíte, ConvertHQ být musit-mít nástroj. Použití ConvertHQ je vlastní nastavení, můžete upravit veškeré audio a video parametrů tak, že dostanete přesně soubor, který potřebujete. Nacházíte se v plně pod kontrolou s ConvertHQ!
Máte dvě možnosti s ConvertHQ
Dvě vydání ConvertHQ jsou k dispozici - ConvertHQ Premium a ConvertHQ. ConvertHQ Premium je profesionální edice, která podporuje všechny populární formáty. Jeho vynikající podporu bude znamenat, že budete mít konvertor pro své současné a budoucí potřeby. ConvertHQ obsahuje stejné funkce jako ConvertHQ Premium, ale podporuje jen běžných formátů za dostupnou cenu.
:ahoj:
