Aktuálny čas je Štv 10. Sep 2026 4:15:46
 Terabyte Unlimited Image for Windows 2.50
 Predmet príspevku: Terabyte Unlimited Image for Windows 2.50
PoslaťNapísal: Pia 25. Sep 2009 9:53:14
Image for Windows is an affordable, reliable drive image backup and restore solution that provides an easy and convenient way to completely backup all your hard drive is data and operating systems. Your backups can be saved directly to external USB and FireWire drives, to internal or network drives, and even directly to CD or DVD. The Image for Windows package includes an easy-to-use MakeDisk wizard for creating a recovery boot disk. To restore your data and operating systems back to the way they were when the backup was created, simply boot the recovery disk and restore the partition(s) or drive(s) you need to recover. It is that easy.
Image for Windows Features
• Total Reliability - Provides the option to verify each and every byte it backs up.
• Convenience - Runs directly from Windows and when used with the free PHYLock™ add-on, it can create a true image of the Windows partition itself, without requiring a reboot.
• Security - Your backups can be secured using simple password protection, or full 256-bit AES encryption.
• Backup Changed Data - Differential backup option allows you to backup only data that has changed since the last full backup was created.
• Simple, Wizard-Driven interface - Easy to use the first time, and every time.
• Maximum Compression - By default, compression is applied to the drive images you create.
• Maximum Speed - If backup speed is paramount, you can bypass compression entirely.
• Optical Drive Support - You can save directly to a CD, DVD, DVD-DL, BD.
• Bootable Rescue Discs - Whenever you save directly to a CD, DVD, DVD-DL, BD, it will automatically become a bootable restore disc.
• Restore Individual Files or Folders - Using the free TBIView add-on, you can view the contents of the drive image files, and optionally restore individual files or folders within them.
• Compatibility - Automatically recognizes and backs up used area of FAT16, FAT32, NTFS, Ext2, Ext3, ReiserFS, and XFS partitions. Partitions with other file system types can be backed up in their entirety. Supports all standard partitions in an MBR, EMBR, or GPT
• Windows Servers - Supports both Workstation and Server versions of Windows.
• Cost Effectiveness - Includes Image for DOS and Image for Linux at no additional charge, making it a uniquely affordable and complete disk imaging solution.
• Flexibility - Restore partitions, regardless of the file system on the partition being restored. This gives you the power to restore NTFS partitions from Windows 98 or even DOS (as just a couple of examples).
• Wide-Ranging Device Support - Compatible with USB 2 and IEEE 1394 external drives. Better yet, Image for DOS supports these drives directly, without requiring complicated driver installation. (Image for Windows simply uses the drivers already available under Windows.)
• Power - Using Image for DOS or Image for Linux (each of which is included with the purchase of Image for Windows) versions gives you the ability to recover your data, even if Windows won't start.
• Network Support - Save backups to any drive accessible to Windows itself.
• RAID Support - Works seamlessly with on-board hardware- and firmware-based RAID.
• Command Line Support - Powerful, complete command line support is built in, allowing you to automate backup or restore procedures.
• Image File Validation - Allows you to thoroughly check the integrity of the disk image files, either as part of the backup process, or at any time thereafter. TeraByte imaging products are renown for their thorough and accurate validation process.
• Restored Partition Expansion - When restoring an image, you can expand the restored partition to occupy any free space that would be left over.
• Selectable Image File Sizes - If desired, you can specify a maximum size for the disk image files that are created. This allows you to create image files that readily fit on the removable media of your choice.
Operating System: all versions of Windows, including Windows Vista, Windows Servers, W7
Obrázek pro Windows je cenově dostupné, spolehlivé image disku pro zálohování a obnovu řešení, které poskytuje snadný a pohodlný způsob, jak zcela zálohovat vaše data je pevný disk a operační systémy. Vaše zálohy mohou být uloženy přímo na externí USB a FireWire disky, na vnitřní nebo síťové disky, a dokonce i přímo na CD nebo DVD. Soubor balíčku pro Windows obsahuje bezstarostný-až k-cvičení MakeDisk průvodce pro vytvoření spouštěcí disketu obnovy. Chcete-li obnovit data a operační systémy zpět na cestu v době, kdy byla vytvořena záloha, jednoduše zavést využití disku a obnovit diskový oddíl (y) nebo cesta (y), je třeba obnovit. Je to tak snadné.
Image pro systém Windows Funkce
• Celkem Spolehlivost - poskytuje možnost ověřit každý byte je zálohuje.
• Pohodlí - Běží přímo z Windows a při použití s volný PHYLock ™ add-on, může to vytvořit pravdivý obraz o oddílu Windows sám o sobě, bez nutnosti restartu.
• Bezpečnost - Vaše zálohy lze zabezpečit pomocí jednoduchých ochrana heslem, nebo plnou 256-bit AES šifrování.
• Změněný Zálohování dat - Diferenciální možnost zálohování umožňuje zálohovat pouze údaje, které se změnilo od poslední plné zálohy byla vytvořena.
• Jednoduché, průvodce-Driven rozhraní - Snadná obsluha poprvé a pokaždé.
• Maximální komprese - Ve výchozím nastavení je použita komprese na disku obrázky, které vytvoříte.
• Maximální rychlost - Pokud záloha rychlost je prvořadá, můžete obejít úplně komprese.
• Optická mechanika Podpora - můžete ukládat přímo na CD, DVD, DVD-DL, BD.
• Bootable Rescue disky - Kdykoli můžete uložit přímo na CD, DVD, DVD-DL, BD, se automaticky stane zaváděcí disk obnovit.
• obnovit jednotlivé soubory a složky - Využití volného TBIView add-on, si můžete prohlédnout obsah souborů image disku, a případně obnovit jednotlivé soubory nebo složky v nich.
• Kompatibilita - Automaticky rozpoznává a zálohuje použité oblasti FAT16, FAT32, NTFS, Ext2, Ext3, ReiserFS, XFS a oddíly. Diskových oddílů s jinými typy souborů systému lze zálohovat v plném rozsahu. Podporuje všechny standardní příčky v MBR, EMBR, nebo GPT
• Windows Server - Podporuje Workstation a Server verze systému Windows.
• Efektivita nákladů - Obsahuje obrázek pro DOS a Image pro Linux bez dodatečných nákladů, což je jednoznačně cenově dostupné a kompletní deska zobrazení řešení.
• Flexibilita - Obnovit oddílů, bez ohledu na souborový systém na oddílu obnovena. To vám dává sílu k obnovení NTFS oddílů z Windows 98 nebo dokonce DOS (jak je jen pár příkladů).
• Wide-ranging zařízení Podpora - kompatibilní s USB 2 a IEEE 1394 externí disky. Ještě lépe, obrázek pro DOS podporuje tyto disky přímo, bez nutnosti složité instalace ovladačů. (Obrázek pro Windows jednoduše používá ovladače již k dispozici pod Windows.)
• Power - Použití obrázek pro DOS a Image pro Linux (z nichž každá je součástí nákupu Image for Windows) verze vám dává možnost obnovit data, i když nelze spustit systém Windows.
• Podpora sítě - Uložení zálohy na libovolnou jednotku přístupný Windows.
• Podpora RAID - funguje bez problémů s On-Board-hardware a firmware-RAID.
• Command Line Support - Silný, je kompletní příkazový řádek vestavěné podpoře, umožňuje automatické zálohování a obnovu řízení.
• Image File Validation - Umožňuje důkladně zkontrolovat integritu souborů obraz disku, a to buď jako součást procesu zálohování, nebo kdykoli později. TeraByte zobrazovací produkty jsou věhlas pro jejich důkladné a přesné procesu validace.
• Obnovená Partition Expansion - Při obnovení obrazu, můžete rozšířit obnoveného diskového oddílu zabírat žádné volné místo, které by zbylo.
• Volitelné Obrázek velikosti souborů - Pokud chcete, můžete určit maximální velikost souboru pro obraz disku, které jsou vytvořeny. To vám umožní vytvářet image soubory, které se snadno vejde na vyměnitelné médium, dle Vašeho výběru.
:ahoj:
