Aktuálny čas je Pia 25. Sep 2026 0:39:17
 Wondershare Products 3 in 1 Fully-Activated
 Predmet príspevku: Wondershare Products 3 in 1 Fully-Activated
PoslaťNapísal: Ned 20. Sep 2009 11:04:58
Wondershare Products 3 in 1 Fully-Activated | 37.7 MB
The Package Contain the Following Products:
1-Wondershare Flash Slideshow Builder 4.6 :
Wondershare Flash Slideshow Builder is an easy to use, time-saving yet powerful program to create webpage used flash, stunning flash slideshows and flash presentation with transition effects, dazzling preset templates, text captions, background music and more. Besides, there are many choices for you to publish and share your slideshow with your family and friends. You are free to publish your slideshows in local disk, on internet or as email sending to desired people. If you wish, you could even embed your favorite slideshow into your blog, Myspace, or other ordinary web pages to show off!
2-Wondershare HD Video Converter 4.2.0.56 :
Wondershare HD Video Converter is powerful and professional video converter tool which is specialized in converting various video/audio formats into HD video or other audio formats with excellent quality and super fast conversion speed! Wondershare HD Video Converter empowers you:
To convert all types of video formats to other popular video and audio formats including HD formats.
To extract audio from video file and convert them to MP3 without any loss.
To crop video as removing black bars to make tailor-made video in the palm of your hands.
To trim video by setting start and end time to get your desired video clips.
To adjust video effect such as brightness, contrast and saturation etc to get the best video effects.
To edit either customizable text or image watermark to coin and color your video files in a personalized way.
To add the subtitles for MKV files.
To capture any picture from video and save as jpeg or bmp format.
To customize output parameters including resolution, bit rate, frame rate, etc to completely fulfill your different requirements.
To preview video with two real-time preview windows out of your movies in an intuitive way.
3-Wondershare QuizCreator 3.0 :
Wondershare QuizCreator is a powerful solution to easily creating interactive Flash-based quizzes. It is specially designed for teachers, testers, researchers, evaluators and organizational improvement specialists. This is one of the easy yet effective ways to access knowledge and get valuable opinions. Your Flash quizzes can be distribute all over the world.
With QuizCreator, you can easily and quickly create your own Flash-based quizzes with up to 9 different question types. You can add animated images, Flash movies and sound effects to polish and individualize your quizzes with comprehensive properties. We also provide an online quiz managment system(QMS) for QuizCreator, which empowers users to collect and manage quiz results by a database without setting up a learning management system (LMS). Quizzes created by QuizCreator can be deployed through AICC and SCORM 1.2/2004.
:inf: sk
Wondershare Produkty 3 v 1-plne aktivovaný | 37.7 MB
Balík obsahuje tieto produkty:
1-Wondershare Flash obrázku Slideshow Builder 4.6:
Wondershare Flash obrázku Slideshow Builder je ľahko ovládateľný, čas-úspory, ale výkonný program pre tvorbu webových stránok použiť blesk, ohromujúci flash prezentácií a flash prezentáciu s prechodovými efekty, oslnivo prednastavené šablóny, textové titulky, hudbu na pozadí a ďalšie. Okrem toho existuje veľa možností pre vás publikovať a zdieľať svoje snímok s rodinou a priateľmi. Tie sú zadarmo publikovať svoje prezentácie na lokálny disk, na internete či posielanie e-mailu je žiaduce, aby ľudí. Ak budete chcieť, môžete vložiť aj svoje obľúbené snímok do svojho blogu, Myspace, alebo iné bežné webové stránky sa chváliť!
2-Wondershare HD Video Converter 4.2.0.56:
Wondershare HD Video Converter je výkonný a profesionálny video konvertor nástroj, ktorý sa špecializuje na prevod rôznych audio / video formátov do HD video alebo iné zvukové formáty s vynikajúcou kvalitou a super rýchly prevod rýchlosť! Wondershare HD Video Converter vám dáva moc:
Ak chcete previesť všetky typy video formátov na ďalšie populárne video a audio formátov, vrátane HD formátov.
Extrahovať zvuk z video súboru a previesť ich do formátu MP3 bez straty.
Ak chcete orezať video ako odstránenie čiernych pruhov, aby sa na mieru-sa video v dlani vašej ruky.
Lišta na video pomocou nastavenia začiatku a konca času, aby si požadované videoklipy.
Ak chcete upraviť video efekt, ako je jas, kontrast a sýtosť atď dostať najlepšie video efekty.
Ak chcete upraviť buď upraviteľný text alebo obrázok vodoznak mince a farbu si video súbory v osobnom spôsobom.
Ak chcete pridať titulky u súborov MKV.
Ak chcete zachytiť nejaký obrázok z videa a uložiť ako JPEG alebo BMP formáte.
Ak chcete prispôsobiť výstupné parametre vrátane rozlíšenie, bit rate, frame rate, etc úplne naplniť svoje odlišné požiadavky.
Ak chcete zobraziť náhľad videa s dvoma oknami v reálnom čase-náhľad z vašich filmov v intuitívnym spôsobom.
3-Wondershare QuizCreator 3.0:
Wondershare QuizCreator je výkonné riešenie pre jednoduchú tvorbu interaktívnych Flash-založenej kvízy. Je špeciálne určený pre učiteľov, testery, výskumníci, hodnotiteľov a organizačných zlepšení špecialistov. To je jeden z jednoduchej napriek tomu účinný spôsob, ako získavať vedomosti a získať cenné názory. Váš Flash kvízy môžu distribuovať po celom svete.
QuizCreator sa môžete ľahko a rýchlo vytvoriť svoj vlastný flash-založené kvízy, až 9 rôznych typov úloh. Môžete pridať animácie, Flash animácií a zvukových efektov pre lesk a individualizovať vaše kvízy s komplexné vlastností. Poskytujeme aj on-line kvíz systému riadenia (QMS) pre QuizCreator, ktorý používateľom umožňuje zhromažďovať a spravovať kvíze výsledkov databázy bez vytvorenia systému pre riadenie výučby (LMS). Kvízy vytvorené QuizCreator môže byť nasadené cez AICC a SCORM 1.2/2004.
