Aktuálny čas je Pon 26. Okt 2026 7:02:30
 Re: Rosetta Stone Application v2.0.8.1 FULL ISO
 Predmet príspevku: Re: Rosetta Stone Application v2.0.8.1 FULL ISO
PoslaťNapísal: Štv 27. Aug 2009 21:18:35
Finally! A breakthrough language learning program that delivers fast, effective instruction that rewards effort with success. Rosetta Stone offers CD-ROM and Online solutions for every use. Individuals at home, at work or on the road. Teachers. Trainers. Institutions with global networks. Millions of users in over 100 countries simply say, “It works!”
What’s the best way to learn a NEW language?
The way we learned our native language. The Rosetta Stone’s award-winning method uses thousands of real-life images, written text and voices of native speakers to teach you like a native learner. Each lesson taps your intuitive ability to connect words and meanings "from the inside."
You learn to speak, read and write the new language quickly, naturally and easily.
Download:
Install Notes
This is a CD image file (ISO) for the install disk to the Rosetta Stone Language System.
There are many other Rosetta Stone torrents out there, but mine are simple CD images for you to download and burn to disk. EASY & QUICK
You MUST download at least one language disk to go along with this disk for the language system to work.
1) Burn the install disk to a disk with magiciso
2) Burn any language disk to a disk
3) Install Rosetta Stone on your Windows PC with the install disk
4) Insert above created language disk and start Rosetta Sone
CZ
Konečne! Prielom jazykov program, ktorý zaisťuje rýchle, efektívne vyučovanie, ktorý odmeňuje úsilie s úspechom. Rosetta Stone ponúka CD-ROM a on-line riešenie pre každé použitie. Jedinci doma, v práci alebo na cestách. Učiteľov. Trénerov. Inštitúcie s globálnou sieťou. Milióny užívateľov vo viac ako 100 krajinách jednoducho povedať, Â "Funguje to! Â"
What € ™ s najlepším spôsobom, ako sa naučiť nový jazyk?
Spôsob, akým sme sa naučili ich materinskom jazyku. Rosetta Stonea € ™ s cena-vyhrávať metóda využíva tisíc real-obrázkov, písaný text a hlasmi rodených hovorcov naučiť sa vám páči natívne žiaka. Každá lekcia kohúty intuitívne schopnosť spojiť slová a významy "zvnútra".
Naučíte hovoriť, čítať a písať nový jazyk rýchlo, prirodzene a ľahko.
Download:
Nainštalujte Notes
Ide o CD image súborov (ISO) pre inštaláciu na disku Rosetta Stone Language System.
Existuje mnoho ďalších Rosetta Stone torrenty tam vonku, ale moje sú jednoduché obrazy CD si budete môcť stiahnuť a napáliť na disk. QUICK \x26 EASY
MUSÍTE stiahnuť aspoň jeden jazyk disk ísť spolu s týmto diskom pre jazykový systém pracovať.
1) Burn inštaláciu disku na disk s MagicISO
2) Burn akomkoľvek jazyku disku na disk
3) Nainštalujte Rosetta Stone v počítači so systémom Windows inštalačný disk
4) Vložte vyššie vytvorený jazyk disk a spustite Rosetta Sone
RAR Password:
http://www.maxgrab.org
:ok:
