Aktuálny čas je Ned 25. Okt 2026 6:54:02
 Smarty Uninstaller 2009 Pro 2.5.2 [Multi]
 Predmet príspevku: Smarty Uninstaller 2009 Pro 2.5.2 [Multi]
PoslaťNapísal: Štv 20. Aug 2009 22:01:16
Smarty Uninstaller 2009 Pro - professional uninstall manager with intuitive and easy to use interface that allows you to manage and completely remove Windows® applications. At most cases Windows applications are very complicated. They put large number of traces to your system. Especially that refers to such things as entries in Windows Registry, Program Files and Shortcuts. In general the problem lies in Uninstaller (simply, an uninstaller is the opposite of an installer. During the uninstallation, the uninstaller removes all the components which were installed) that can't properly remove all traces in Windows. Also some users simply doesn't use uninstaller! They just delete the application program files from hard drive. Other traces still stays untouched! Large amount of junk traces will make your PC much slower.
Key features:
- Smarty Uninstall - COMPLETELY removes applications from your PC (all files, shortcuts and registry entries)
- Smarty Analyzer will deeply scan your computer for traces left by selected application.
- Smarty UI - easy to use and modern user interface allows to comfortably work with Smarty Uninstaller!
- Smarty Cache - makes Smarty Uninstaller very fast and reliable. Much faster solution than regular Windows Add/Remove.
- Smarty Protection feature - this feature will protect critical system components. You will not be able to delete system files accidentally or in any other way.
- Smarty Groups - allow you to organize applications list into logical groupings. This will make your work more flexible and organized.
- Smarty Drag-and-Drop - uninstall applications using drag-drop and context menu! Just drop application's icon to the Smarty Uninstaller icon on the desktop. Or choose appropriate command in context menu (Right mouse click).
- Smarty Reports - Create and Print detailed reports about installed applications.
- Create a queue of applications for analyzing or uninstalling
- Force uninstalling applications with broken uninstaller! Complete uninstall.
- Automatically detects invalid installations and give ways to fix them
- Detailed information about application (Name, Version, Size, Install location etc.)
- Backup your system directly from Smarty Uninstaller.
- Useful tips and detailed Help - provide you with all information you need to work with it.
- Multilanguage interface! Translate to your language and get it for free!
- Fast search feature allows to quickly find application you need.
Smarty Uninstaller 2009 Pro - profesionální odinstalovat manažer s intuitivní a snadno použitelné rozhraní, které vám umožní spravovat a zcela odstranit Windows ® aplikace. Ve většině případů Windows aplikace jsou velmi složitá. Dali velký počet stop na váš systém. Hlavně, že se vztahuje na takové věci, jako záznamy v registru systému Windows, Program Files a klávesové zkratky. Obecně lze říci, že problém spočívá v Uninstaller (prostě je Uninstaller je opakem instalační. Při odinstalování se Uninstaller smaže všechny složky, které byly nainstalovány), že nemůže řádně odstraňte všechny stopy v systému Windows. Také někteří uživatelé prostě nevyužije Uninstaller! Jen odstranit aplikační program soubory z pevného disku. Ostatní stopy stále zůstává neporušen! Velké množství nevyžádané stopy bude vaše PC mnohem pomalejší.
Klíčové vlastnosti:
- Smarty Uninstall - zcela odstraní aplikace z vašeho počítače (všechny soubory, zástupce a položky registru)
- Smarty Analyzer se hluboce skenovat počítače pro stopy zanechané vybrané aplikace.
- Smarty UI - snadné použití a moderní uživatelské rozhraní umožňuje pohodlně pracovat s Smarty Uninstaller!
- Smarty Cache - Smarty Uninstaller umožňuje velmi rychlé a spolehlivé. Mnohem rychlejší řešení než běžný Windows Přidat / Odebrat.
- Smarty funkci ochrany - tuto funkci bude chránit kritické komponenty systému. Nebudete moci smazat systémové soubory náhodně nebo jakýmkoli jiným způsobem.
- Smarty Groups - vám umožní uspořádat seznam aplikací do logických skupin. To umožní, aby vaše práce pružnější a organizované.
- Smarty Drag-and-drop - odinstalací aplikace pomocí drag-kapka a kontextové menu! Stačí kapka aplikace ikonu na Smarty Uninstaller ikony na ploše. Nebo si vyberte příslušný příkaz v kontextovém menu (pravé tlačítko myši).
- Smarty Zprávy - Vytvoření a tisk podrobné zprávy o instalované aplikace.
- Vytvoření fronty aplikací pro analýzu nebo odinstalací
- Síla odinstalací aplikace se člení Uninstaller! Kompletní odinstalování.
- Automaticky rozpozná neplatné zařízení a způsoby, dát jim opravit
- Podrobné informace o žádosti (jméno, verze, velikost, umístění instalace atd.)
- Záloha dat přímo z Smarty Uninstaller.
- Užitečné rady a podrobné Nápověda - poskytnout vám všechny informace, které potřebujete pro práci s ním.
- Multilanguage rozhraní! Přeložit do svého jazyka a získejte zdarma!
- Rychlé vyhledávání umožňuje rychle najít aplikace, které potřebujete.
LIKVIDUJTE VŠETKO ÚPLNE BEZ STOPY
 Predmet príspevku: Re: Smarty Uninstaller 2009 Pro 2.5.2 [Multi]
PoslaťNapísal: Pia 21. Aug 2009 18:05:04
Pozor na ten soft niekedy premaze aj to co nema a to viem ocom kecam.Moze sa stat ze restartnete pc a uz nenabehne.
PoslaťNapísal: Pia 21. Aug 2009 20:58:26
Dr.Thrax píše:
Ináč AHOJ Dr.Thrax a čo sa týka Tvojho príspevku za to Ti samozrejme vopred dakujem, že si na to upozornil, lebo ja osobne som to ešte nikde nepočul a ani nezistil, ale ešte od toho ten problém samozrejme môže existovať....maj sa päkne AHOJ...s pozdravom...Tvoj virtuálný priatel ...PISTA....!!!
