Aktuálny čas je Štv 23. Júl 2026 12:42:49
 Najnovšia verzia - registry Victor 5.4.7.14
 Predmet príspevku: Najnovšia verzia - registry Victor 5.4.7.14
PoslaťNapísal: Uto 28. Júl 2009 7:46:55
A tool which enables to enhance your pc performance by 300%.The Registry Victor application was designed to be an advanced multi-language registry cleaner in pc diagnosis and repair. It can do a complete scan of the pc errors such as system slowdown, freezing, crashing and deadlock. Safely optimize the speed of the system and set your PC in a fantastic performance!Registry Victor uses the top-ranking error-resolution technology, it can put PC back to work for you. By scanning the registry, diagnosing the system errors and fixing the problems, Registry Victor can enhance your pc performance and increase the speed by up to 300%.
Registry Victor uses the most advanced technology to scan your hard driver and give you a comprehensive diagnosis in seconds. Once the problems have been identified, Registry Victor offers you a professional and highly efficient solution, which will keep your computer functioning perfectly. By using Registry Victor regularly, your system should not only be more stable but it will also help streamline your pc registry without expensive hardware upgrades.
Here are some key features of "Registry Victor":
Registry Optimizer:
· Performs an all-around scan of your Windows registry to detect and fix invalid references and incorrect errors, which also helps streamline your pc registry without expensive hardware upgrades. Your pc will perform like new and run much faster after using this tool.
Privacy Safeguard:
· Protects your privacy by ensuring all traces of your online Internet and computer activities are permanently erased and unrecoverable, which speeds up system performance and retrieves more hard drive space.
Junk File Remover:
· Scans and removes almost all junk files from system to provide more free space on your hard drive and allow applications to run faster and more efficiently. This tool will help to keep your system free of clutter and clean up all the unwanted data and information.
File Shredder:
· With three different shredding levels, file shredder will shred or destroy unwanted files beyond recovery. It completely removes a file or more files from your computer, making it nearly impossible to recover.
PC Optimizer:
· PC Optimizer Is an optimizer toolkit containing Startup Manager, Uninstall Manager, System Optimizer,Service Optimizer and Memory Optimizer. Besides monitoring the startup and un-install programs, it also optimizes network speed, disk, desktop, files, system service and Memory to peak performance.
IE Doctor:
· Contains a vast number of useful tips and tricks to manage Internet Explorer's windows when surfing on Internet. It customizes your Internet properties, restores Internet files and manages browser help objects which greatly streamlines your surfing experience.
Czech....!!!
Nástroj, který umožňuje zvýšit výkon vašeho počítače, které 300%. Rejstříkem Victor aplikaci byla navržena tak, aby byla pro moderní multi-jazyk registru čistší v PC diagnostiku a opravy. To můžete udělat úplný sken PC chybám, jako je zpomalení systému, zmrazení, shazovat a deadlock. Bezpečně optimalizaci rychlosti systému a nastavení svého počítače v fantastický výkon! Registru Victor používá top-žebříčku chyba-technologické řešení, je možné dát PC zpátky do práce pro Vás. Skenováním registru diagnostiku systému chyby a problémy, kterým se stanoví, Registry Victor může zvýšit výkon vašeho počítače a zvýšení rychlosti až o 300%.
Registry Victor využívá nejvyspělejších technologií skenovat pevný a řidič vám může poskytnout komplexní diagnostiku v sekundách. Jakmile se problémy byly identifikovány, Registr Victor Vám nabízí profesionální a vysoce efektivní řešení, které bude udržovat váš počítač funguje dokonale. Pomocí registru Victor pravidelně, systém by měl být nejen stabilnější, ale také pomůže zefektivnit vaše PC registru bez nákladných hardwarových upgradů.
Zde jsou některé klíčové rysy "rejstříkem Victor":
Registry optimalizaci:
Zvládá vše-scan kolem vašeho registru systému Windows pro detekci a opravu neplatných odkazů a nesprávné chyby, které také pomáhá zefektivnit vaše PC registru bez nákladných hardwarových upgradů. Váš počítač bude vykonávat, jako nové a běžet mnohem rychleji po použití tohoto nástroje.
Soukromí záruková:
Chrání vaše soukromí tím, že zajistí veškeré stopy vašich on-line Internet a počítačové aktivity jsou trvale vymazat a nepoužitelný, který urychluje výkon systému a načte více místa na disku.
Junk odstraňovač souboru:
Kontroluje a odstraňuje téměř veškeré nevyžádané soubory ze systému, který poskytuje více volného místa na pevném disku a umožňují spustit aplikace rychleji a efektivněji. Tento nástroj pomůže udržet systém bez zbytečných souborů a vyčištění všech nechtěných dat a informací.
Drtič souboru:
Se třemi různými úrovněmi drcení, soubor drticím bude trhat nebo ničit nechtěné soubory mimo využití. Je zcela odstraní soubor nebo více souborů z vašeho počítače, takže je téměř nemožné získat zpět.
PC pro optimalizaci:
PC pro optimalizaci optimalizátora toolkitu obsahující spouštěcí Manager, Uninstall Manager, systém pro optimalizaci Service optimalizaci a Memory Optimizer. Kromě sledování startu a un-instalovat programy, ale také optimalizuje rychlost sítě, disk, desktop, soubory, systémové služby a paměť na špičkový výkon.
IE Lékař:
Obsahuje velké množství užitečných tipů a triků pro správu aplikace Internet Explorer oken při surfování na internetu. Je customizes Váš internetový nemovitostí, obnovuje soubory Internetu a spravuje prohlížeč objektů, které výrazně pomohou zjednodušuje vaše surfování zkušenosti.
Magyar....!!!
Egy eszköz, amely lehetővé teszi, hogy fokozza a PC teljesítményét 300%. A nyilvántartó Victor alkalmazásának célja az volt, hogy egy fejlett multi-nyelvi jegyzék tisztább számítógépes diagnosztika és javítás. Ez nem egy teljes scan a PC hibák, mint például a rendszer lassulása, fagyasztás, összeomlik és a holtpontról. Safely optimalizálni a sebességet, a rendszer és a számítógép egy fantasztikus teljesítményt! Rendszerleíróadatbázis Victor használja a top-ranking error felbontású technológia, a számítógép nem tud vissza dolgozni az Ön számára. A szkennelés a Rendszernyilvántartást, diagnosztizálására a rendszer hibákat és rögzítési problémák, Rendszerleíróadatbázis Victor javíthatják a számítógép teljesítményét és növelje a sebesség akár a 300%.
Rendszerleíróadatbázis Victor használja a legfejlettebb technológiát szkennelni kemény vezető és kapsz egy átfogó diagnosztikai másodperc. Miután a problémákat állapítottak meg, Rendszerleíróadatbázis Victor kínál a professzionális és igen hatékony megoldás, amely megtartja a számítógép működése teljesen. A Beállításszerkesztővel Victor rendszeresen, akkor a rendszer nem csak a sokkal stabilabb, de abban is segít, racionalizálja a számítógép rendszerleíró nélkül drága hardver frissítéseket.
Íme néhány kulcsfontosságú jellemzőit "Rendszerleíróadatbázis Victor:
Registry optimalizáló:
Végrehajtja az összes körül scan Windows rendszerleíró felderítése és rögzíti az érvénytelen hivatkozások és nem hiba, ami szintén segít ésszerűsítse a számítógép rendszerleíró nélkül drága hardver frissítéseket. Elvégzi a számítógép, mint új, és sokkal gyorsabban fut-e az eszköz használata után.
Adatvédelmi Védintézkedési:
Védi a személyes adatok védelmét azáltal, hogy biztosítja minden nyomot online internetes és számítógépes tevékenységet véglegesen törölni és behajthatatlan, amely felgyorsítja a rendszer teljesítményét, és letölti a nagyobb merevlemez.
Junk File Remover:
Scans és eltávolítja szinte minden dzsunka fájlokat a rendszer, hogy több szabad hely a merevlemezen, és lehetővé teszi az alkalmazások futtatása gyorsabb és hatékonyabb. Ez az eszköz segít, hogy a rendszer a szabad és tiszta zűrzavar az összes kívánt adatokat és információkat.
File Shredder:
A három különböző szinteken aprítás, aprítógépek fájlt fogja pusztítani, vagy a nem kívánt fájlokat túl hasznosítás. Teljesen eltávolítja a fájlt vagy fájlokat a számítógépre, így szinte lehetetlen behajtani.
PC optimalizáló:
PC optimalizáló egy optimalizáló eszköztárat tartalmaz Startup Manager, Uninstall Manager, System Optimizer, szolgáltatás-optimalizáló és a Memory Optimizer. Felügyelete mellett az indítási és az ENSZ-install programot is optimalizálja a hálózati sebességet, lemez-, asztali, fájlokat, a rendszer szolgáltatási és memória-csúcs teljesítmény.
IE Doctor:
Tartalmaz egy hatalmas számos hasznos tippeket és trükköket, hogy kezelje az Internet Explorer ablakokat, ha szörfözés az interneten. Ez Testreszabja az Internet tulajdonságai, helyreállítja a fájlokat, és kezeli az Internet böngésző súgó tárgyak nagymértékben egyszerűsíti a szörfözés tapasztalat.
Odjakživa sme žili vedla seba madari+slováci jedine v pokoji a mieri, ale s nástupom demokrácie prišli i taký politici na oboch stranách kôli ktorým sa tie celoživotné dobré vztahy naštrbily a neustále zrejme zámerne niečo sledujúc naštrbujú, ale kašlime na politikov a snažme sa tie vztahy medzi sebou aj v tomto cybersvete udržiavať jedine v priatelskom duchu - duchu porozumenia a v mieri spolupatričnosti, lebo násilie a teror ešte nič dobrého nikdy nikde vo svete nepriniesli a preto si to chránme....!!!
 Predmet príspevku: Re: Najnovšia verzia - registry Victor 5.4.7.14
PoslaťNapísal: Uto 28. Júl 2009 17:22:43
Registrovaný: Ned 15. Feb 2009 0:23:08
aj ta toto dakujem pista urcite vyskusam
