Aktuálny čas je Str 28. Okt 2026 3:58:22
 Kvalitny material 5x full komplex
 Predmet príspevku: Kvalitny material 5x full komplex
PoslaťNapísal: Ned 28. Jún 2009 14:14:11
WinMend System Doctor is a Windows-based security improvement. With its innovative and intelligent detection engine, WinMend System Doctor can effectively detect and fix security vulnerabilities in the system, fix software vulnerabilities in third-party applications, and prevent the running of malicious startup programs, Trojans, BHOs, processes and system services to significantly improve system security. It also provides an Expert level system scan option to scan potential security threats in the system, protects the system from the intrusion of spyware, adware, Trojans and viruses, and eliminates system security risks.
Features
1. Intelligent Scan Engine
WinMend System Doctor is integrated with a brand-new scan engine that can intelligently detect system vulnerabilities in Windows, software vulnerabilities in third-party applications and problems corresponding security settings, and it can help users fix problems found. It simplifies user operation, and helps you solve security risks more promptly and efficiently.
2. Unique System Security Rating System
WinMend System Doctor can rate the security of your operating system for you to see the security status of the system more visually.
3. Comprehensive and Detailed Security Report
WinMend System Doctor can generate comprehensive security reports that elaborate all details about each single security vulnerability and potential security threat in your system, so you can understand the security problems in the system and how to fix them with improved clarity.
4. Expert-Level System Scan
An "Expert"-level system scan is offered by WinMend System Doctor. It scans potential security threats in the system, such as in shared resources, user privilege management, remote control, etc., that could be easily used by malicious programs (or hackers), and can guide you through the steps to fix vulnerabilities and eliminate security risks in the system.
Czech...!!!
WinMend System Doctor je Windows - based bezpečnostní zlepšení. S jeho inovačním a inteligentním identifikačním motorem, WinMend System Doctor může efektivně zjistit a upevnit bezpečnostní zranitelnosti v systému, upevnit softwarové zranitelnosti v odjinud pocházejících aplikacích, a předejít běhu záludných startovních programů, trojských koní, BHOs, procesy a systém služby k významně zlepšit ochranu systému. To také poskytuje Expert úroveň systémovou snímací volbu k tomu, aby skenovala potenciální bezpečnostní hrozby v systému, chrání systém z vetření se spyware, adware, trojských koní a virů, a odstraňuje systémová bezpečnostní rizika.
Rysy1. Inteligentní snímací motor
WinMend System Doctor je integrovaný do zbrusu nového snímacího motoru který může inteligentně zjistit systémové zranitelnosti ve Windows, softwarové zranitelnosti v odjinud pocházejících aplikacích a problémech odpovídajících bezpečnostních nastaveních, a to může pomáhat uživatelům odstraněním problému najít. To zjednodušuje uživatelskou operaci, a pomáhá Vám řešit bezpečnostní rizika více okamžitě a efektivně.
2. Jedinečný systémový bezpečnostní hodnotící systém
WinMend System Doctor může cenit bezpečnost vašeho operačního systému pro vás vidět bezpečnostní status systému více vizuálně.
3. Komplexní a detailní bezpečnostní zpráva
WinMend System Doctor může generovat komplexní bezpečnostní zprávy které vypracují všechny detaily o každé jednotlivé bezpečnostní zranitelnosti a potenciální bezpečnostní hrozbě ve vašem systému, tak vy můžete rozumět bezpečnostním problémům v systému a jak je podívat se zlepšenou jasnost.
4. Expert-úroveň systém skenuje
"Expert" -úroveň systém skenuje je nabízený WinMend System doktorem. To skenuje potenciální bezpečnostní hrozby v systému, jako v společně používaných prostředcích, uživatelský management privilegia, dálkového ovládání, atd., které by mohlo být snadno užívané záludnými programy (či hakeři), a může provázet vás skrz kroky k upevnit zranitelnosti a odstraníte bezpečnostní rizika v systému.
WinMend History Cleaner is a utility that can comprehensively clean histories produced by various programs in the system. It can effectively scan and clean histories generated by more than 100 programs. These histories include cookies, browsing histories and cache files by browsers such as Internet Explorer, Firefox and histories by a great number of other applications such as Microsoft Office, WinRAR, Windows Media Player and RealPlayer. Clearing these histories not only can boost system speed, but can also effectively prevent your privacy from being disclosed. WinMend History Cleaner can give you a cleaner and safer operating system!
Features
1. Comprehensive Scan
WinMend History Cleaner scans the histories of system programs, browsers and other various applications. Its comprehensive categories help you select, scan and clear history with ease.
2. Safe Scan Results
The scan engine of WinMend History Cleaner can intelligently screen scan targets and leave out results that may affect Windows system files. We guarantee the safe history deletion.
3. Clear Results Display
WinMend History Cleaner shows the results with detailed and clear classification. The result list tells you what those histories are, so that you can decide to keep or delete them with much confidence.
4. Cookies Management
WinMend History Cleaner manages Internet Explorer cookies independently and makes it easy for users to keep the cookies they need.
Czech...!!!
WinMend History Cleaner je utilita která může úplně čistit historie produkované různými programy v systému. To může efektivně skenovat a čisté historie vygenerované víc než 100 programy. Tyto historie zahrnují koláčky, brouzdající historie a cache soubory prohlížeči jako Internet Explorer, Firefox a historie velkým počtem jiných aplikací jako Microsoft Office, WinRAR, windowsovský mediální Player a RealPlayer. Vyčištění těchto historií nejen může podporovat systémovou rychlost, ale může také efektivně zabránit vašemu soukromí z toho, být odhalenému. WinMend History Cleaner může dát vám čistější a bezpečnější operační systém!
Rysy1. Komplexní snímání
WinMend History Cleaner skenuje historie systémových programů, prohlížečů a jiných různých aplikací. Jeho komplexní kategorie pomohou vám vybrat, skenovat a vyčistit historii snadno.
2. Bezpečné snímání vyplývá
Snímací motor WinMend History Cleaner může inteligentně zastínit snímací cíle a vynechat výsledky které mohly ovlivnit windowsovské systémové soubory. My garantujeme bezpečné historické zrušení.
3. Jasné výsledky zobrazí
WinMend History Cleaner ukazuje výsledky s detailním a jasným tříděním. Výsledkový seznam říká vám co ty historie jsou, abys mohl rozhodne se držet či vymazat je s moc důvěry.
4. Management koláčků
WinMend History Cleaner řídí Internet Explorer koláčky nezávisle a usnadní to uživatelům k tomu, aby drželi koláčky oni potřebují.
WinMend Data Recovery is a Windows-based data recovery application. It recovers data on FAT12/ FAT16/FAT32/NTFS/NTFS5 partitions in Windows operating systems. It can be used to scan partitions in various hard drives, removable drives and even in data cards, and to search and recover deleted or missing files, files lost during formatting or due to partition exceptions. With unique recovery algorithm, WinMend Data Recovery can significantly improve the accuracy and speed of scanning, and ensure everything done in an absolutely safe condition without any negative impact on the system.
Features
1. Quick Scan
With this safe and high-speed scan engine, you can quickly locate and recover most deleted files.
2. Full Scan
In case Quick Scan fails, you can go through Full Scan, which will never miss a single chance to find missing files. Full Scan may take longer. However, with our unique engine, its speed and reliability are still significantly higher than its peers. (Full Scan is strongly recommended for formatted partitions.)
3. Unformat a Drive
If you lost your files due to the formatting of a drive, you can recover them with our Unformat a Drive function. Unformat a Drive helps you easily look for the lost files on the formatted drives and get them back with a few simple clicks!
4. Safe File Recovery
WinMend Data Recovery always ensures safe operations while recovering files. It never overwrites any current files. For those files that are not deleted but inaccessible because they are locked by the operating system or other applications, WinMend Data Recovery recovers and saves them to other partitions. Keep in mind, all operations are safe, and your current files will not be damaged or overwritten.
Czech...!!!
WinMend obnova dat je Windows - based data recovery aplikace. To obnovuje data na FAT12/ FAT16/FAT32/NTFS/NTFS5 úseky ve windowsovských operačních systémech. To může být použito skenovat úseky v různých pevných discích, odstranitelných pohonech a dokonce v datovém děrném štítku, a hledat a obnovit vymazané či chybějící soubory, soubory ztracené během formátování či kvůli přepážce výjimek. S jedinečným obnovovacím algoritmem, WinMend obnova dat může významně zlepšit přesnost a rychlost skenování, a zajistit všechno udělaný v absolutně bezpečném stavu bez jakéhokoliv záporného dopadu na systém.
Rysy1. Rychlé snímání
S tímto bezpečným a vysokorychlostním snímacím motorem, vy můžete rychle lokalizovat a obnovit největší vymazané soubory.
2. Plné snímání
V případě, že Quick Scan selhává, vy můžete projít Full Scan, které nikdy nemine jednotlivou šanci na to najít chybějící soubory. Plný Scan může trval delší. Ať tak nebo onak, s naším jedinečným motorem, jeho rychlost a spolehlivosti jsou ještě významně vyšší než to panstvo. (plné snímání je silně doporučené pro formátované úseky.)
3. Unformat pohon
Jestli vy jste ztratili vaše soubory kvůli formě pohonu, vy můžete obnovit je s naší Unformat Drive funkcí. Unformat Drive pomáhá Vám snadno hledat ztracené soubory na formátovaných pohonech a je vrátí s málo jednoduchých kliknutí!
4. Bezpečné zotavení souboru
WinMend obnova dat vždy zajišťuje bezpečné provozy při znovuzískání souborů. To nikdy nepopisuje nějaké /každé /žádné běžné soubory dat. Pro ty soubory které nejsou vymazaný ale nepřístupné protože oni jsou zamčení operačním systémem či jinými aplikacemi, WinMend obnova dat obnovuje a chrání je k jiným úsekům. Mějte na paměti, všechny operace jsou bezpečné, a váš běžný soubory dat nebude poškozený či přepíšou.
WinMend Disk Cleaner is a quick and safe junk file cleaner. With a powerful scan engine, it safely and quickly locates junk files in your system. By deleting junk files, it increases available disk space and improves system performance. You can specify the content to include or exclude in the scan and select drives to scan. The scan results will be displayed with subtotals. Its Disk Analyzer module enables you to see the types of files in charts or lists.
Features
1. Safe and Comprehensive Scan Settings
Base on much testing, we decided that the changes to certain folders might affect system security and automatically add these folders to the Exclude Folder list. These folders will be skipped during the scan to avoid any potential risks.
2. Scan Results Confirmation
If you are not sure whether a junk file should be deleted, you can check its content by using the Open File or Properties commands before making the decision.
3. Powerful Disk Analysis
Disk Analyzer can perform comprehensive scan and analysis of local drives and the data in them. It can then present the results in charts or detailed lists for you to have a visual overview of the distribution of files on each drive. The unique junk file classification makes it easy for you to identify and safely delete junk files on local drives.
Czech...!!!
WinMend Disk Cleaner je rychlý a bezpečný odpad čistič pilníků. Se silným snímacím motorem, to bezpečně a rychle lokalizuje odpadové soubory ve vašem systému. mazáním odpadové soubory, to zvyšuje dostupné místo na disku a zlepšuje charakteristiku systému. Vy můžete specifikovat obsah k tomu, aby zahrnul či vyloučit v snímání a vybrat dojede do skenovat. Snímací výsledky budou zobrazené s mezisoučty. Jeho Disk Analyzer jednotka umožní vám vidět druhy souborů v grafech či seznamech.
Rysy1. Bezpečný a komplexní snímací nastavení
Základna na moc testování, my jsme rozhodli , že změny do určité složky mohly by ovlivnit ochranu systému a automaticky přidat tyto složky k vyloučit Folder seznam. Tyto složky bude skákal během snímání k tomu, aby vyhnulo se nějakým /každým /žádným potenciálním rizikům.
2. Skenujte vyplývá potvrzení
Jestli vy nejste si jistý zda odpadový soubor by měl být vymazaný, vy můžete kontrolovat obsah použitím načtete soubor či Properties příkazy před děláním rozhodnutí.
3. Silný disk analýza
Disk Analyzer může vykonávat komplexní snímání a analýzu diskových mechanik a dat v sobě. To může pak prezentovat výsledky v grafech či podrobných schématech pro vás mít vizuální celkový pohled distribuce souborů na každém pohonu. Jedinečné odpadové souborové třídění usnadní to, že Vám identifikovat a bezpečně vymazat odpadové soubory na diskových mechanikách.
WinMend Registry Cleaner is a powerful and secure registry cleaning and optimization application. It has four main function modules: Registry Cleaner, Registry Optimizer, Registry Backup and Scheduler. The application can efficiently and comprehensively analyze system, accurately locate errors and obsolete data, safely fix or delete them, thus effectively reducing the workload in your computer and improving the speed and performance of your system. It also analyzes various system settings such as those for CPU, memory, disks and provides comprehensive and automatic system optimization solutions to further increase the speed of system startup and running. Safe analysis, comprehensive registry scan and faster scan engine are our powerful tools for registry cleanup and optimization!
Features
1. Safe Scan
With our constant commitment to developing high-quality registry scanning and cleaning products, our products are safer than their peers. No complaint has been filed by any user till today against our registry scanning and cleaning products.
2. Comprehensive Scan
Dozens of scan categories and more than 10,000 data checkpoints have made WinMend Registry Cleaner the most comprehensive and deepest registry fix and cleanup application.
3. Quick Scan
This application has been specially optimized for Windows 2000/XP/Vista (32-bit & 64-bit) and its scanning speed has been significantly improved. It only takes several minutes to complete a full scan of the Windows registry.
4. Regular Scan
As you add files and applications to your computer, or make configuration changes, your registry grows and your system slows downs. Cleaning up your registry regularly keeps your system run smoothly. WinMend Registry Cleaner’s Scheduler helps you set up the clean up on a regular basis.
Czech...!!!
WinMend Registry Cleaner je silný a bezpečný registrační čistící a optimalizační aplikaci. To má čtyři hlavní funkční moduly: Registr čistější, registrační optimizátor, registrační zálohování a plánovač. Aplikace může efektivně a úplně analyzovat systém, přesně lokalizovat chyby a zastaralá data, bezpečně upevnit či vymazat je, tak efektivně snižování pracovní náplně ve vašem počítači a zlepšování rychlosti a výkonu vašeho systému. To také analyzuje různá systémová nastavení jako ti pro CPU, paměť, disky a poskytují komplexní a automatická systémová optimalizační řešení dále zvýšit rychlost systémového startu a běhu. Bezpečná analýza, komplexní registrační snímání a rychlejší snímací motor jsou náš silný nástroj pro registrační vyčištění a optimalizaci!
Rysy1. Bezpečné snímání
S naším stálým závazkem k vyvíjejícím vysoce kvalitním registračním skenovacím a čistým produktům, naše produkty jsou bezpečnější než jejich panstvo. Žádná stížnost byla vyplněná kterýkoli uživatelem do dneška proti našim registračním skenovacím a čistým produktům.
2. Komplexní snímání
Tucty ze snímací kategorie a více než 10,000 datový kontrolních stanoviště udělala WinMend Registry Cleaner nejkomplexnější a nejhlubší registrační oprava a aplikace vyčištění.
3. Rychlé snímání
Tato aplikace byla speciálně optimalizovaná pro Windows 2000/XP/Vista (32 - bitový & 64 - bitová) a jeho rychlost rozkladu byla významně zlepšená. To jen několik dělá zápisy dokončit plné snímání registrů Windows.
4. Pravidelné snímání
Jak vy přidáte soubory a aplikace vašemu počítači, či udělá konfigurační změny, váš registr rostou a váš systém se zpomalí duny. Čistící váš registr pravidelně drží váš systém provozovaný hladce. WinMend Registry Cleaner- ovo Scheduler pomáhá Vám nastavil čistý nahoru pravidelně.
