Aktuálny čas je Sob 24. Okt 2026 9:46:48
 Teleport Ultra 1.60 Portable
 Predmet príspevku: Teleport Ultra 1.60 Portable
PoslaťNapísal: Štv 11. Jún 2009 17:21:27
Teleport Pro's big brother, Teleport Ultra, has Pro's intuitive interface and easy-to-use project-based design -- but it also has the ability to scan up to 260,000 addresses in a single project. Like Teleport Pro, Teleport Ultra can handle multiple servers in a single project, dramatically improving its throughput.
Its larger database, however, allows it to handle much larger websites and more servers, enabling you to download much more information in a single project. (And if you need even larger capacity, try Teleport VLX.)
» Cookie support lets Teleport mimic browsers more effectively
» javascript parsing capability for better, more thorough exploration of complex sites
» Ten simultaneous retrieval threads get data at the fastest speeds possible
» Reads all variants of HTML 4.0, CSS 2.0, and DHTML; performs some javascript analysis
» Can retrieve files from FTP servers
» Full offline browsing and site mirroring capabilities
» Project Scheduler lets you schedule projects to run at any time, on any connection
» Automatic connect/disconnect system lets Teleport handle dial-up Internet connections for you, saving phone charges and connection time
» Java applet retrieval gets Java classes and base classes
» Retrieval filters let you download only files matching desired type and size constraints
» Independently configurable internal and external exploration depths
» Server-side image map exploration -- translates server-side maps into client-side maps for offline browsing
» Accesses password-protected sites
» Full proxy server and firewall support
» Domain Dispersed Querying™ ensures that slow servers do not affect retrieval speed
» Server Overload Protection™ prevents remote servers from overloading and dropping connection early
Features of Ultra:
» Use regular expressions to specify included as well as excluded areas to crawl
» Specify domain aliases for crawling servers with multiple names
» Borrow the browser's cookie cache, letting you perform complex authentication with your browser, and then crawl with Teleport
» Inject custom HTTP headers into server requests
» Synchronize your offline copy so that old files and orphans are automatically removed
» Use customizable messages when rewriting links to unretrieved files
» Control HTML markup and inject meta tags with original URL and retrieval date/time stamps
» Can crawl HTTPS (secure) servers
Version 1.60, Mar 18 2009
- Improved browser compatibility mode to add zip, doc, avi, mov, mpg, mp3, xml extensions for files that need them
- Fixed bug, Clear Project Database in Exec could cause modal dialog if used without a run option
Teleport Pro je Big Brother, Teleport Ultra má Pro je intuitivní rozhraní a snadné-to-use-projekt založený design - ale má také možnost skenování až 260.000 adres do jednoho projektu. Jako Teleport Pro, Teleport Ultra dokáže zpracovat více serverů v jednom projektu, dramaticky zlepšuje jeho výkon.
Její větší databáze však umožňuje zvládnout mnohem rozsáhlejší webové stránky a více serverů, umožní vám stáhnout mnohem více informací v jediném projektu. (A pokud potřebujete ještě větší kapacitu, zkuste Teleport VLX.)
Vlastnosti:
»Cookie umožňuje podporu Teleport mimických prohlížecu efektivněji
»Javascript parsování schopnost lepší, důkladnější průzkum komplexu stránky
»Deset simultánní vyhledávání závity získat údaje na nejrychlejší možnou rychlostí
»Čte všechny varianty HTML 4.0, CSS 2.0 a DHTML, provádí některé javascript analýzy
»Můžeme načítat soubory z FTP serverů
»Celý offline prohlížení stránek a zrcadlení schopnosti
»Projekt plánovače umožňuje naplánovat projekty běžet kdykoli, z jakéhokoli připojení
»Automatické připojení / odpojení systému umožňuje zpracovávat Teleport dial-up připojení k internetu pro vás, šetří telefonní poplatky a připojení času
»Java applet vyhledávání dostane Java tříd a základní třídy
»Vyhledání filtry vám stáhnout jen soubory vyhovující požadovaný typ a velikost omezení
»Nezávisle konfigurovatelná vnitřní a vnější průzkum hlubin
»Server-boční obrázek mapy průzkum - překládá server-straně mapy do client-straně mapy pro offline prohlížení
»Heslo Přístupy-chráněných lokalit
»Kompletní proxy server a firewall podpora
»Domain Rozptýlená dotazování ™ zajišťuje, že pomalé servery nemají vliv na rychlost načítání
»Server Overload Protection ™ zabraňuje vzdálených serverů z přetížení a kapátková připojení rané
Ultra rysy:
»Použití regulárních výrazů specifikovat zahrnuty i vyloučených oblastech na crawl
»Specifikují aliasy domén pro procházení serverů s více jmény
»Borrow prohlížeče cookie cache, což vám provádět složité ověřování s vašem prohlížeči, a pak procházet s Teleport
»Vstříkněte vlastní záhlaví HTTP server v žádosti
»Synchronizovat offline kopie tak, že staré soubory a sirotčí, se automaticky odstraní
»Použití upravitelnými zpráv při přepisování odkazy na soubory unretrieved
»Kontrola HTML značkovací a vstříkněte meta tagy s originálním URL a vyhledávání Datum / čas razítek
»Můžete procházet HTTPS (zabezpečené) servery
Verze 1.60, 18. března 2009
- Vylepšené prohlížeče režimu kompatibility přidat zip, doc, avi, mov, mpg, mp3, xml rozšíření pro soubory, které potřebují
- Opravena chyba, Clear Projekt databáze v Exec by mohly způsobit modal dialog, pokud jsou používány bez spuštění volby
