Aktuálny čas je Uto 20. Okt 2026 13:28:20
 ZoneLINK SystemUp 2009 Tuning-Najvyššia kvalita výkonu
 Predmet príspevku: ZoneLINK SystemUp 2009 Tuning-Najvyššia kvalita výkonu
PoslaťNapísal: Str 03. Jún 2009 21:29:39
With the SystemUp-TuningSuite, you receive a comprehensive toolbox to optimize and individually adjust your Windows PC. The all-in-one solution offers you more than 400 optimization and adjustment options and is as secure as never before: The integrated RescueCenter creates backups of all changes fully automatically to enable you to reset the system at any time and without any problems should you require to do so. SystemUp Defrag optimizes your hard disks, USB sticks, memory cards, etc. thanks to innovative defragmentation methods. The 3-zone optimization algorithm increases the access speed of your data mediums and protects them against refragmentation. A further 8 optimization methods enable specific optimization for special application purposes of your system.
10 convincing reasons for SystemUp Tuning 2009
1. Increasing the efficiency of PCs and notebooks is as easy as never before
2. Helps with Windows and system problems
3. System analysis with optimization suggestions
4. Profiles or individual performance adjustment
5. Professional hard disk cleanup and acceleration
6. High-performance 3-step defragmentation for improved loading times and maximum performance gain for all data mediums
7. Secure deletion of files, directories and removal of data garbage
8. Undelete module for data recovery
9. Automatic optimization of many areas of your system
10. Helpful wizards for most of the program modules
Requirements
* Windows XP or Vista 32Bit
* Screen-Resolution min. 1024x768
* Internet Connection required for using all features
* 1 GB RAM
link opravený............. :cert: :cert: :cert: :cert: :cert: :cert: :cert: :cert: :cert: :cert: :cert:
Se SystemUp-TuningSuite, vy přijmete komplexní schránku s nářadím optimalizovat a jednotlivě nastavit váš windowsovský PC. Vše v jednom řešení nabízí vám víc než 400 optimalizace a regulační volby a je tak zajištěné, jak nikdy předtím: Integrovaný RescueCenter vytváří zálohování všech mění plně automatický k tomu, aby umožnila vám resetovat systém kdykoliv a bez jakýchkoliv problémů měly bys požadovat dělat tak. SystemUp Defrag optimalizuje vaše harddisky, USB přilepuje, paměťové karty, a tak dále díky inovačním defragmentaci metodám 3- optimalizační algoritmus zóny zvyšuje vybavovací rychlost vašich paměťových médií a je chrání před refragmentation. A dále 8 optimalizační metody umožní specifickou optimalizaci pro zvláštní aplikační účely vašeho systému.
10 přesvědčivé důvody pro SystemUp Tuning 2009
1. Rostoucí efektivita PCS a zápisníků je tak snadné, jak nikdy předtím
2. Pomoci s windowsovskými a systémovými problémy
3. Systémová analýza s optimalizačními návrhy
4. Profily či individuální výkonové nastavení
5. Profesionál harddisk vyčištění a zrychlení
6. Výkonná 3-přírůstková defragmentace pro zlepšený doby nakládky a maximální výkon získá pro všechny paměťová média
7. Bezpečné zrušení souborů, adresářů a vyjmutí datových odpadků
8. Obnovte jednotku pro obnovu dat
9. Automatická optimalizace mnoha oblastí vašeho systému
10. Užiteční průvodcové pro většinu modulů programu
Požadavky
* Windows XP či Vista 32Bit
* Screen - Resolution minuta 1024x768
* internetový Connection požadovaný pro náš všechny rysy
* 1 GB RAM
Modlím sa za Vás a prajem Vám velmi veľa zdravia, lebo jedine zdravie je tou najpodstatnejšou vecou v našom živote...
 Predmet príspevku: Re: ZoneLINK SystemUp 2009 Tuning-Najvyššia kvalita výkonu
PoslaťNapísal: Štv 04. Jún 2009 21:51:11
Registrovaný: Ned 15. Feb 2009 0:23:08
prepac kamarat môj nerad som ti pisal SS ale Dr.Thrax (čize doky)mi to povedal aby som ti napisal spravu a pekne dakujem za soft s pozdravom happycoool
