Aktuálny čas je Pia 30. Okt 2026 9:45:10
 Virtuálna Grafická Karta-Hrajte i tie najnovšie hry
 Predmet príspevku: Virtuálna Grafická Karta-Hrajte i tie najnovšie hry
PoslaťNapísal: Pia 29. Máj 2009 14:14:52
3D ANALYZER 2.6 STEP BY STEP!
1) Go to your games website....and check MINIMUM REQUIREMENTS (Or recommended)
For the exaple, i'll look at "The Witcher" requirements.
(http://www.thewitcher.com/community/en/ ... ments.html):
Minimum requirements:
Microsoft® Windows® XP Service Pack 2, Vista (Operating System must be up to date with the latest fixes)
Intel Pentium 4 2.4GHz or AMD Athlon 64 +2800
1 GB RAM for Microsoft® Windows® XP / 1536 MB for Microsoft® Windows® Vista
128 MB Video RAM or greater with DirectX9 Vertex Shader/ Pixel Shader 2.0 support (NVIDIA GeForce 6600 or ATI Radeon 9800 or better)
8.5 GB available hard drive space
DirectX 9.0c compliant soundcard, plus speakers or headphones
DVD-Rom
2) Launch "3D Analyzer.exe".
3)OK, so let's have a look at these requirements. Uh oh, it needs "Pixel Shader" 2.0, and a NVIDIA or ATI card. So since i have an Intel Graphics card, which doesn't even support Shader, we'll use the analyzer.
4) Click "Select", now since i'm playing "The Witcher" I'm gonna go to my CD Drive and then select "launcher.exe". It's the Installation file, and these Next gen PC games won't let you install the game if you don't have the requirements, it'll give you a warning before you install. Before, you could install the game, but once you clicked on the .exe or shortcut, it wouldn't start up, so i'm using the installation file, for now. If you're using a game/application later then, about 2007/2006 you'll need the root "exe" file of your application/game for it to work. After installation one, in the "Program Files".
5)Emulation: Ok, i've got my file, now be sure to select ALL the "Hardware Limits" check boxes.
6)Shader: Most of these games need shader, this is a very useful program. Under "Pixel and vertex Shader" i'm going to click "Force max. pixel shader 1.4" and then my game needs shader at least 2.0, so i'm gonna click "skip pixel version 2.0".
7) Set your Hardware ID: Ok under the "Run:" button, and the Icon, you'll see "Vendor ID" and "Device ID". On the right it gives you numbers. I need a Nvidia card, so the numbers for the Vendor ID will be "4318", and Devide ID "592".
8) IMPORTANT OTHERS: "Performance" will just change game/application options such as, instead of full screen, force window, or enable a "texturless" or "renderless" mode, which is not recommended.
Game/Demo Fixes: Here are some pre-patched games, if you have any of them, they are just a few, like Spiderman 3, or Gun Metal.
"Open GL Performance": You'll need Open GL for this, you probably won't need to adjust this at all, even if you have "Open GL", which some games might need, if you need it go here:
(http://www.freedownloadscenter.com/Util ... nload.html)
ANTI-DETECT MODE: Don't use, not recommended, it changes Shader and Pixel detection, so it doesn't show.
9) Click "Run". Make sure it runs OK. If not, adjust options such as your graphics card (replace with others on the right of the ID boxes). If it does it's a good idea to click "Save Batch File" at the very bottom. That lets you save everything, so next time you need to launch the program, just click and it automatically launches.
That covers the basics! Hope it's helped! Here are some other notes:
Don't worry, it won't permanantley alter your settings, just while your using the game/application, after you exit the 3D analyzer, everything goes back to default.
Only alters the .EXE, nothing else.
The "3D Analyzer" Will be launched, and MUST be launched in the background while application/game is running
It is 99.3% Safe!! Only problems are, crashing may occur, changes .EXE temporarily and overrides settings temporary.
Legal!
1) Jděte do vašich her websajtu....a kontrolujte MINIMUM REQUIREMENTS (či jste doporučili)
Pro exaple, já dívat se na "Witcher" požadavky.
Minimální požadavky:
Microsoft® Windows® XP opravný balík 2, Vista (operační systém musí být moderní s posledními opravami)
Intel Pentium 4 2.4GHz či AMD Athlon 64 +2800
1 GB RAM pro Microsoft® Windows® XP / 1536 MB pro Microsoft® Windows® Vistu
128 MB obrazová paměť či větší s DirectX9 Vertex Shader/ pixelem Shader 2.0 podporuje (NVIDIA GeForce 6600 či ATI Radeon 9800 či lepší)
8.5 GB dostupný tvrdý diskový prostor
DirectX 9.0c vyhovující zvuková karta, plus reproduktory či sluchátka
DVD-Rom
2) Spusťte "3D Analyzer.exe".
3)OK, tak nechejme se podívat na tyto požadavky. Uh ó!, to potřebuje "Pixel Shader" 2.0, a NVIDIA či ATI karta. Tak od i mít Intel grafickou kartu, co dokonce nepodporuje Shader, my budeme užívat analyzátor.
4) Cvakněte "Vyberte", nyní od i hrajte "Witcher" Chystám se jdu do mé CD mechaniky a potom vybrat "launcher.exe". To je Installation soubor, a tyto další počítačové hry informací nebudou nechat tě instalovat hru jestli nemáte požadavky, to dá vám upozornění předtím než vy instalujete. Předtím, mohl bys instalovat hru, ale jakmile vy jste klikli na the .exe či zkratka, to by nevystartovalo, tak i používám instalační soubor, prozatím. Jestli vy používáte hru/aplikaci později pak, asi 2007/2006 vy budete potřebovat kořen "exe" soubor vašich aplikace/her pro to pracovat. Po instalaci jedné, v "Programové soubory".
5)Emulace: Ok, mám můj soubor, teď být si jistý, že vybrat celý "Hardware Limits" řídicí boxy.
6)Shader: Většina těchto her potřebuje stín, toto je velmi použitelný program. Pod "Pixel a vrchol Shader" chystá se cvaknout "Nuťte max. stín pixelu 1.4" a potom můj hra potřebuje stín přinejmenším 2.0, tak chystá se cvaknout "skákat pixel verzi 2.0".
7) Nastavte váš hardware ID: Ok pod "Běh:" knoflík, a Icon, vy uvidíte " ID prodavače" a "Přístrojový ID". Vpravo dávají vám čísla. Já potřebuji Nvidia kartu, tak čísla pro Vendor ID bude "4318", a Devide ID "592".
8) DŮLEŽITÝ JINÍ: "Výkon" jen změní herní/aplikační volby jako, namísto celé obrazovky, nutit okno, či umožnit "texturless" či "renderless" mód, který není doporučený.
Hra/demoverze upevní: Zde jsou nějaký před --záplatované hry, jestli vy máte každý z je, oni jsou jen několik, jako Spiderman 3, či Gun Metal.
"Otevřený GL výkon": Vy budete potřebovat otevřít GL kvůli tomu, pravděpodobně vy nebudete potřebovat nastavit toto vůbec, i když you máte "Otevřete GL", které nějaké hry mohl by potřebovat, pokud potřebujete to jít zde:
ANTI-ZJISTIT MÓD: Neužívejte, ne doporučený, to mění Shader a Pixel odhalení, tak to neukáže.
9) Cvakněte "Běžte". Ujistěte se, že to běží OK. Jestliže ne, nastavte volby jako vaše grafická karta (vyměnit s ostatními vpravo ID boxů). Jestli to dělá to je dobrý nápad k tomu, aby cvakl "Chraňte dávkový soubor" velmi dole. To nechá vás šetřit všechno, tak příště vy potřebujete spustit program, jen cvaknout a to automaticky spouští.
To pokrývá základy! Naděje to pomohlo! Zde jsou nějaké jiné poznámky:
Nedělejte si starosti, to nebude permanantley změnit vaše nastavení, jen zatímco vaše používání hry/aplikace, potom co vy východu 3D analyzátoru, všechno vrátí se k neplnit.
Jen mění .EXE, nic jiného.
"3D analyzátor" Bude vypuštěný, a musí být vypuštěný v pozadí zatímco aplikaci/hře běží
To je 99.3% sejf!! Jen problémy jsou, narážení mohou vyskytovat se, mění .EXE dočasně a nedbat na nastavení dočasná.
Právní!
:ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: Ó Bože pomôž ma zbaviť tých ľadvinových bolestí od, ktorých mám neustále jazyk vyplazený :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble: :ble:
 Predmet príspevku: Re: Virtuálna Grafická Karta-Hrajte i tie najnovšie hry
PoslaťNapísal: Sob 30. Máj 2009 19:43:47
Podla mna to je blbost nijaky sof sa nevyrovna nadupanej karte
