Aktuálny čas je Sob 24. Okt 2026 22:33:21
 Generic Trial Starter 1.02
 Predmet príspevku: Generic Trial Starter 1.02
PoslaťNapísal: Ned 24. Máj 2009 8:39:11
Generic Trial Program Starter serves for the start of the programs, having limitation on the term of the use. Many programs renounce correctly to work, if a system date on Your computer goes beyond set borders. This utility allows briefly to change a system date and start capricious application.
Often happens so, that some programs on quite incomprehensible reasons stop to work, requiring, that a system date was translated forward or back.To the number such programs the row of electronic dictionaries, programs, belong with a trial period and others like that dim software.The executable module is produced by the start of the required program with the changed system date.
After proshestviya of time, indicated in the field of Virtual Time Interval Configurator, the executable module returns a system date into place (in the actual state). A virtual time domain must be little more than time, required for the start of the trial'noy program.
Utility ILYA-Corp. Generic Trial Program Starter is designed to run third-party programs,
without restrictions on time of use. Many refused to work correctly if the system
date on your computer are out of bounds. This utility allows to change the system, briefly
start date and capricious application, thereby avoiding all the associated inconvenience. The utility consists of this
module-setup, and from the executable module, which will run the desired program with the modified system
date. After the lapse of time specified in the Virtual Time Interval, an executable module returns the system
date in place. The interval of virtual time to be a little more than the time required to start trial
program. Important. If, after the forced start of the trial and before the expiration of the interval
virtual time fails (hangs the computer, power, reboot, etc.), then
system date will not be returned to its original state. In this case, possible problems with other programs,
which work only with the actual date. These programs include Microsoft Windows, which will not be
boot! In this case, do not worry, but when you restart the computer, log into your BIOS Setup Utility System
Boards and install the current date. To run the BIOS Setup Utility, in most cases when you start your computer
need to press Del. WARNING! DO NOT USE THIS TOOLS FOR COMMERCIAL hacking software products,
Because this is contrary to the law on copyright protection and could lead to criminal prosecution. AUTHOR TOOLS
"GENERIC TRIAL PROGRAM STARTER" IS NOT WHAT ANY LIABILITY AND can not be held to it, BECAUSE TOOLS
Does not produce the file modification third-party programs and system files OPERATING SYSTEMS.
Best regards,
Teamhackers ILYA-Corp.
Generický Trial Program Starter slouží pro začátek programů, mají ohraničení termínu použití. Mnoho programů se zřeknou správně pracovat, jestli systémové datum na vašem počítači přesahuje stanovené hranice. Tato utilita dovoluje krátce měnit systémové datum a začít vrtošivou aplikaci.
Často stane se tak, že nějaké programy na docela nepochopitelných důvodech zastaví pracovat, požadující, že systémové datum bylo přeložené vpřed či zádo.Do čísla takových programů řada elektronických slovníků, programů, patří k zkušební době a jiní jako ten matný software.Proveditelná jednotka je produkovaná začátkem požadovaného programu se změněným systémovým datem.
Po proshestviya času, indikovaný na poli Virtual Time Intervalu Configurator, proveditelný jednotka vrací systémové datum na místo (v aktuálním stavu / stát). A virtuální časová oblast musí být malý nejvyšší čas, požadovaný pro začátek trial'noy programu.
Užitková ILYA-Corp. Generický Trial Program Starter je navržený k tomu, aby běžel odjinud pocházející programy,bez omezení času použití. Mnozí odmítnuli pracovat správně jestli systémové datum na vašem počítači jsou z mezí. Tato utilita dovoluje měnit systém, krátcestartovní datum a vrtošivou aplikaci, tím únik celou spojenou potíž. Utilita se sestává z tétojednotky-nastavení, a z proveditelné jednotky, která bude řídit požadovaný program s upraveným systémovým datem. Po uplynutí času specifikovaného ve Virtual časovém intervalu, proveditelná jednotka vrací systémové datum v místech. Interval virtuálního času na to být trochu víc než čas požadoval začít zkušebníprogram. Důležitý. Jestli, po přinuceném začátku soudu a před uplynutím intervaluvirtuálního času selhává (visí počítač, sílu, restartuje, atd.), paksystémové datum nebude návrat do jeho originálního stavu / státu. V tomto případě, možné problémy s ostatními programy,které jen pracují s datem splatnostmi. Tyto programy zahrnují Microsoft Windows, které nebudebota! V tomto případě, nedělají si starosti, ale kdy vy spustíte znovu počítač, kmen do vašeho BIOS Setup systému obslužných programů
Prkna a instalují dnešní datum. Pro řídit BIOS Setup Utility, ve většině případech kdy vy začnete váš počítačpotřebovat tisknout Delaware WARNING! NEUŽÍVAT THIS TOOLS FOR COMMERCIAL hackerské programové produkty,
Protože toto je v rozporu se zákonem na autorskoprávní ochraně a mohla vést k trestnímu stíhání. NAPSAT NÁSTROJE
"GENERICKÝ TRIAL PROGRAM STARTER" NENÍ NOT WHAT ANY LIABILITY A nemůže být držený v tom, protože NÁSTROJE
Neprodukuje souborové modifikace odjinud pocházející programy a systémové soubory operační systémy.
S úctou,
