Aktuálny čas je Ned 01. Nov 2026 10:52:32
 Portable Hard Disk Serial Number Changer
 Predmet príspevku: Portable Hard Disk Serial Number Changer
PoslaťNapísal: Štv 30. Apr 2009 16:29:22
In order to restrict software installed or control the number of activation allowed in one particular computer, the volume serial number has been used by software developers to track where and how many times the software has been installed. Volume serial number is unique and it will be changed whenever the hard disk is formatted.
If you would like to restore your PC image back to your hard disk after it is formatted, you may run into the problem of not able to run some software due to not able to recognize the old volume serial number. To get this issue solved, there is one utility, named as Hard Disk Serial Number Changer that can change your volume serial number back to previous serial number.
Hard Disk Serial Number Changer is freeware and handy to use. It can change the volume serial number to what you preferred. Prior to format your hard disk, remember to write down the volume serial number so that you can change the volume serial number back to previous one after it is formatted. If you are not sure where to get the serial number, just go to command prompt, then type dir and press enter, the volume serial number is listed as shown below:
C:\Documents and Settings\Administrator>dir
Volume in drive C is OSDisk
Volume Serial Number is 12AF-AABB
Once you have changed the volume serial number, you must reboot your computer in order for the changes to be effective.
Hard Disk Serial Number Changer works perfectly with file systems like NTFS, FAT and FAT32 and is compatible to run in Windows Vista/XP/ME/2000/98/2003/NT. If you plan to format your hard disk but still plan to ensure its software compatibility, this tool is definitely useful and worth getting one.
n objednávka k tomu, aby omezila software nainstalovaný či ovládat počet aktivace dovolené v jeden specifickém počítači, hlasitost sériové číslo bylo užívané softwarovými vývojáři k tomu, aby sledovali kde a kolikrát software byl instalovaný. Hlasitost sériové číslo je jedinečné a to bude změněný kdykoli harddisk je formátovaný.
Pokud bys chtěl obnovit váš PC obraz zpět k vašemu harddisku poté co to je formátovaný, můžete vběhnout do problému neschopný běžet nějaký software kvůli neschopný poznat staré hlasitost sériové číslo. Pro dostat tuto záležitost vyřešenou, tam je jedna utilita, pojmenovaný jak Hard pořadový číslo disku Changer která může měnit vaše hlasitost sériové číslo zpět do předchozího sériového čísla.
Tvrdý pořadový číslo disku Changer je freeware a příhodně položený pro použití. To může měnit hlasitost sériové číslo k co vy jste preferovali. Před formátem vaším harddiskem, pamatujte si napsat hlasitost sériové číslo abys mohl měnit hlasitost sériové číslo zpět do předchozí jedno poté co to je formátované. Jestli vy nejste si jistý kde dostat sériové číslo, jen jít přikázat výzvě, pak píše adresář disku a tisk vstoupit, hlasitost sériové číslo je uvedené jak je ukázáno dole:
C:\dokumenty a nastavení\administrátor>adresář disku
Hlasitost v diskový C je OSDISK
Hlasitost sériové číslo je 12AF-AABB
Když je jednou změnila hlasitost sériové číslo, musíte restartovat vaše počítač aby změny k tomu, aby byly účinné.
Tvrdý pořadový číslo disku Changer pracuje dokonale se systémy souborů jako NTFS, FAT a FAT32 a je kompatibilní k tomu, aby běžel ve Windows Vistě/XP/ME/2000/98/2003/NT. Jestli vy plánujete formátu vašemu harddisku přece však plánu k tomu, aby zajistil jeho kompatibilitu programového vybavení, tento nástroj je definitivně užitečný a mající cenu dostávání jeden.
