Aktuálny čas je Ned 27. Sep 2026 0:27:44
 ABC Amber Text Converter 2.09 1000% KVALITA
 Predmet príspevku: ABC Amber Text Converter 2.09 1000% KVALITA
PoslaťNapísal: Pia 24. Apr 2009 21:38:13
Document converter with support for conversion between many file formats
ABC Amber Text Converter - It's a cheap alternative to Adobe Acrobat.
ABC Amber Text Converter - we all try our best to be in step with the times. The times take us to convert our business content to Adobe PDF.
That's why we developed ABC Amber Text Converter - to help ourselves and to help you.
Key features of conversion to PDF using ABC Amber Text Converter program includes 40/128 bits PDF encryption, different PDF security options, page size and page orientation support, resolution mode, compression mode, etc.
Not only conversion to PDF is supported.
ABC Amber Text Converter is the award-winning, powerful tool to convert documents to PDF, HTML, RTF, TXT (ANSI and Unicode), DOC, XLS, MCW, WRI, WPD, WK4, WPS, SAM, RFT, WSD, and more.
It's easy like ABC and powerful like amber.
Currently our software supports more than 50 languages, and more to come.
ABC Amber Text Converter is used by companies in many areas which are really in step with the times.
Important note: Adobe Acrobat doesn't need to be installed.
Here are some key features of "ABC Amber Text Converter":
· Imports HTML, RTF (MS Word doesn't need to be installed), XLS (MS Excel Worksheet), TXT (ANSI and Unicode), DOC (Word 6.0/95/97-2003, Asian Versions 6.0/95), WRI (Windows Write), WPD (WordPerfect 5.x/6.x/4.1/4.2), WK1, WK3, WK4 (Lotus 1-2-3), MCW (Word for Macintosh 4.0-5.1), WPS (Works 4.0 for Windows, Works 2000, Works for Windows 3.0), DOC (Word 2.x for Windows, Word 3.x-5.x for MS-DOS, Word 6.0 for MS-DOS), SAM (Ami Pro 3.0), WSD (WordStar for Windows 1.0-2.0, WordStar 3.3-7.0), dBase (FoxPro/dBASE), RFT (IBM's RFT-DCA), PWI (InkWriter/Note Taker), PSW (Pocket InkWord Document), PDT (InkWriter/Note Taker Template), PWD (Pocket Word Document), PWT (Pocket Word Template), Clipboard, Lexicon for DOS, recovers text from any file
· Eexports PDF (doesn't require Adobe Acrobat to be installed), HTML, CHM, RTF (MS Word doesn't need to be installed), HLP, TXT (ANSI and Unicode), DOC (Word 6.0/95/97-2003), WRI (Windows Write 3.0/3.1), WPD (WordPerfect 5.0/5.1 for DOS/5.x for Win/5.1-5.2 secondary, 5.0 secondary, WordPerfect 4.1/4.2), MCW (Word for Macintosh 4.0-5.1), WPS (Works 4.0 for Windows, Works 2000, Works for Windows 3.0), DOC (Word 2.x for Windows, Word 3.x-5.x for MS-DOS, Word 6.0 for MS-DOS), SAM (Ami Pro 3.0), WSD (WordStar 4.0/7.0), RFT (IBM's RFT-DCA), PWI (InkWriter/Note Taker), PSW (Pocket InkWord Document), PWD (Pocket Word Document), Clipboard
· Batch conversion (registered version only)
· Command line support
· Scheduler
· Supports multiple character sets and encoding tables
· Includes a powerful embedded editor
· Supports advanced PDF export options (document information, 40/128 bits PDF encryption, multiple PDF security options, page size, page orientation and page margins, resolution mode, compression mode, viewer options, embedding style)
· Maintains hyperlinks
· Supports multiple CHM and HLP export options
· Multi-language support AND more!
Dokumentový konvertor s podporou pro konverzi mezi mnoha formátů souboru
ABC Amber Text Converter - to je levná alternativa Adobe Acrobat.
ABC Amber Text Converter - my všichni zkusí náš nejlepší k tomu, aby drželi krok s časy. Časy vezmou nás přeměnit náš obchodní obsah k Adobe PDF.
Proto my jsme vyvinuli ABC jantarový textový konvertor - pomocný my sami a pomoct vám.
Klíčové rysy konverze k PDF používání ABC Amber Textu Converteru programu zahrnují 40/128 kousky PDF šifrování, jiných PDF bezpečnostních voleb, velikost stránky a orientace stránky podporují, rozlišovací mód, kompresní mód, a tak dále
Nejenže konverze k PDF je podporovaná.
ABC Amber Text Converter je oceněný, silný nástroj k tomu, aby přeměnil dokumenty PDF, HTML, RTF, TXT (ANSI a Unicode), , DOC, XLS, MCW, WRI, WPD, WK4, WPS, SAM, RFT, WSD, a více.
To je snadný jako ABC a silný jako jantarový.
Aktuálně náš software podporuje víc než 50 jazyky, a víc, co přijde.
ABC Amber Text Converter je užívaný společnostmi v mnoha oblastech které opravdu drží krok s časy.
Důležitá poznámka: Adobe Acrobat nemusí být nainstalovaný.
Zde jsou nějaké klíčové rysy "ABC jantarový textový konvertor":
· dovozy HTML, RTF (MS WORD nemusí být nainstalovaný), , XLS (MS překonat se pracovní tabulku), , TXT (ANSI a Unicode), , DOC (slovo 6.0/95/97-2003, asijské verze 6.0/95), , WRI (Windows píší), , WPD (WordPerfect 5.x/6.x/4.1/4.2), , WK1, WK3, WK4 (lotos 1-2-3), , MCW (slovo pro Macintosh 4.0-5.1), , WPS (pracují 4.0 pro Windows, práce 2000, pracuje pro Windows 3.0), , DOC (slovní 2.x pro Windows, slovo 3.x-5.x pro MS-DOS, slovo 6.0 pro MS-DOS), , SAM (Ami Pro 3.0), , WSD (WordStar pro Windows 1.0-2.0, WordStar 3.3-7.0), dBase (FoxPro/dBASE), , RFT (IBM'S RFT-DCA), , PWI (inkoustová zapisovač/poznámka kdo bere), , PSW (kapesní InkWord dokument), , PDT (inkoustová zapisovač/poznámka kdo bere šablonu), , PWD (kapesní dokumenty Wordu), , PWT (kapesní slovní šablona), , Clipboard, slovník pro DOS, obnovuje text z nějakého /každého /žádného souboru
· Eexports PDF (nevyžadovat Adobe Acrobat být instalovaný), , HTML, CHM, RTF (MS WORD nemusí být nainstalovaný), , HLP, TXT (ANSI a Unicode), , DOC (slovo 6.0/95/97-2003), , WRI (Windows píší 3.0/3.1), , WPD (WordPerfect 5.0/5.1 pro DOS/5.x pro vyhraje/5.1-5.2 sekundární, 5.0 sekundární, WordPerfect 4.1/4.2), , MCW (slovo pro Macintosh 4.0-5.1), , WPS (pracují 4.0 pro Windows, práce 2000, pracuje pro Windows 3.0), , DOC (slovní 2.x pro Windows, slovo 3.x-5.x pro MS-DOS, slovo 6.0 pro MS-DOS), , SAM (Ami Pro 3.0), , WSD (WordStar 4.0/7.0), , RFT (IBM'S RFT-DCA), , PWI (inkoustová zapisovač/poznámka kdo bere), , PSW (kapesní InkWord dokument), , PWD (kapesní dokumenty Wordu), , Clipboard
· konverze dávky (registrovaný verzi jen)
· nařízená lineární podpora
· plánovač
· podpory vícenásobné znakové sady a zakódování odloží ad acta
· zahrnuje silný začleněný editor
· podpory pokročilé PDF exportní volby (dokumentová informace, 40/128 kousky PDF šifrování, vícenásobné PDF bezpečnostní volby, velikost stránky, orientace stránky a okraje stránky, rozlišovací mód, kompresní mód, volby diváka, vkládající styl)
· udržovat hyperlinky
· podpory vícenásobný CHM a HLP exportují volby
· Multi - language podpora AND více!
 Predmet príspevku: Re: ABC Amber Text Converter 2.09 1000% KVALITA
PoslaťNapísal: Pon 11. Máj 2009 16:29:48
Registrovaný: Uto 03. Mar 2009 16:00:25
· plánovač
Password:
FCBGabo
