Aktuálny čas je Sob 01. Aug 2026 4:37:52
 Snooper v1.36.50 - Odpočúvajte nekompromisne každého
 Predmet príspevku: Snooper v1.36.50 - Odpočúvajte nekompromisne každého
PoslaťNapísal: Uto 21. Apr 2009 18:00:21
Snooper is a professional sound activated audio recording software package with many options and features.Secret recordings: Recording automatically starts when sound is detected from the microphone input and stops when there is silence. Stealth mode will hide the program from taskbar and tray. System wide user definable hot keys can be set to control the program.
Smart recording system: Will start the recording before the actual sound trigger occur.
Dictation mode: All recordings are collected in a single mp3-file. Locate recordings by time stamps in the recorded file.
E-mail handling: After the recording is done the audio file can automatically be sent by e-mail to designated address. The maximum file size option will split a recording in to smaller chunks when sending e-mail. So if you can receive e-mail you can listen to what is sounded in your Snooper equipped PC, wherever you are in the world!. You can also create voice mail with the integrated voice mail function.
Scheduler: Several recording can be setup to start and stop in different mode and at specific time and date.MP3 technology: Using compact MPEG layer 3 audio format the file size will be less than 4 MB for one hour of recording! Various settings available including bit rate, sample rate, mono, stereo, etc.
Suggested applications:
- Telephone recordings.
- Voice notes.
- Unattended recordings of radios etc.
- Scanner recordings. Catch channels that rarly have activity.
System requirements:
Windows 98/ME/NT4/2000/XP, Sound card, microphone and Internet connection for voice mail.
Obrázok :ahoj: :ahoj: :ahoj:
Špeh je profesionál zvukový aktivoval zvukový zaznamenávající soubor programů s mnoha volbami a rysy.Tajné nahrávky: Nahrávání automaticky začíná kdy zvuk je objevený z vstupu mikrofonu a zastaví kdy tam je ticho. mód tajnosti skryje program z lišty s nástroji a podnos. Systém široké uživatel vymezitelné klávesové zkratky mohou chystat se ovládat program.
Chytrá lístkovnice: Začít nahrávání před aktuální zvukovou spouští se vyskytovat.
mód diktátu: Všechny nahrávky jsou sebrané v singl mp3-souboru. Lokalizujte nahrávky časovými údaji v souboru záznamů.
E - mail zacházení: Po nahrávání je udělaný zvukový soubor automaticky může být poslaný e - mailem určené adrese. Maximální souborová velikostní volba bude rozštěpí nahrávání v menším pořádným kusům při posílání e - mailu. Tak jestli vy můžete přijmout e - mail, který vy můžete poslouchat co je znělo ve vašem špehovi vybaveném PC, kdekoli vy jste na světě!. Vy můžete také vytvořit hlasovou poštu s integrovanou hlasovou poštovní funkcí.
Plánovač: Několik nahrávání může být nastavení k tomu, aby začalo a zastaví v jiném módu a v specifickém čase a datu.MP3 technologie: Používání kompaktní MPEG vrstvy 3 audio formát velikost souboru bude méně než 4 MB pro jednu hodinu nahrávání! Různá nastavení včetně dostupného rychlosti přenosu, vzorového poměru, mono, stereo, a tak dále
Navrhované aplikace:
- telefonní nahrávky.
- hlas poznámky.
- bez dozoru nahrávky rádi a tak dá le
- nahrávky snímacího zařízení. Chytit kanály které vzácný měly aktivitu.
Systémové požadavky:
Windows 98/ME/NT4/2000/XP, zvuková karta, mikrofon a internetové spojení pro hlasovou poštu.
