Aktuálny čas je Str 28. Okt 2026 15:20:00
 Image for Windows 2.26b + Serial - Vytvorte si obrázok C:\ s
 Predmet príspevku: Image for Windows 2.26b + Serial - Vytvorte si obrázok C:\ s
PoslaťNapísal: Ned 19. Apr 2009 13:59:27
A Win32 based backup and restore utility that creates a snapshot of an entire partition or volume
Image for Windows is an affordable and reliable drive image backup and restore utility. Drive imaging from Windows is an easy and convenient way to backup all your hard drive's data and operating system partitions.
Image for Windows it creates snapshots of the partitions and is able to backup and restore data.
Your backups can be saved to a set of files on local or network drives, or directly to most CD or DVD drives. Backups saved directly to CD/DVD are bootable by default, making a convenient recovery disc. Simply restore the the partition(s) you need to recover, and they will be completely restored back to the way they were when the backup was created.
Image for Windows utilizes the technology available in the included PHYLock add-on utility. PHYLock allows you to continue using your computer while the backup is locked to a point-in-time. This eliminates the inconsistencies typically experienced while backing up a partition that is in use.
As its name implies, Image for Windows runs on the Windows operating system, but it can backup or restore any partition, including those of DOS or Linux. Image for Windows can also image to or restore from just about any drive letter, including network drives.
The drive image files are compatible across all TeraByte Unlimited disk imaging products of the same major version number (i.e. all 1.x products are compatible with other 1.x products). This makes it easy to restore the disk images even when Windows isn't available.
Bonus: Every purchase of Image for Windows includes a copy of Image for DOS and Image for Linux. Image for DOS and Image for Linux support the same powerful drive image functionality without requiring a working Windows installation. It also includes a licensed copy of the TeraByte OS Deployment Tool Suite (TBOSDTS). TBOSDT contains a set of powerful utilities that, among other things, will help you deploy Windows to completely different hardware.
Here are some key features of "Image for Windows":
· Simple, Wizard-Driven interface - Easy to use the first time, and every time.
· Total Reliability - Provides the option to verify each and every byte it backs up.
· Convenience - Runs directly from Windows and when used with the free PHYLock add-on, it can create a true image of the Windows partition itself, without requiring a reboot.
· Maximum Compression - By default, maximum compression is applied to the drive images you create.
· Maximum Speed - If backup speed is paramount, you can bypass compression entirely.
· Optical Drive Support - You can save directly to a CD or DVD disc.
· Bootable Rescue Discs - Whenever you save directly to a CD or DVD, it will automatically become a bootable restore disc.
· Restore Individual Files or Folders - Using the free TBIView add-on, you can view the contents of the drive image files, and optionally restore individual files or folders within them.
· Compatibility - Automatically recognizes and backs up used area of FAT16, FAT32, NTFS, Ext2, Ext3, ReiserFS, and XFS partitions. Partitions with other file system types can be backed up in their entirety.
· Cost Effectiveness - Includes Image for DOS and Image for Linux at no additional charge, making it a uniquely affordable and complete disk imaging solution.
· Flexibility - Restore partitions, regardless of the file system on the partition being restored. This gives you the power to restore NTFS partitions from Windows 98 or even DOS (as just a couple of examples).
· Wide-Ranging Device Support - Compatible with USB 2 and IEEE 1394 drives. Better yet, Image for DOS supports these drives directly, without requiring complicated driver installation. (Image for Windows simply uses the drivers already available under Windows.)
· Power - Using Image for DOS or Image for Linux (each of which is included with the purchase of Image for Windows) versions gives you the ability to recover your data, even if Windows won't start.
· Network Support - Save backups to any drive accessible to Windows itself.
· RAID Support - Works seamlessly with on-board hardware- and firmware-based RAID.
· Command Line Support - Powerful, complete command line support is built in, allowing you to automate backup or restore procedures.
· Image File Validation - Allows you to check the integrity of the disk image files, either as part of the backup process, or at any time thereafter.
· Restored Partition Expansion - When restoring an image, you can expand the restored partition to occupy any free space that would be left over.
· Selectable Image File Sizes - If desired, you can specify a maximum size for the disk image files that are created. This allows you to create image files that readily fit on the removable media of your choice.
· If you will be restoring outside of Windows, as most home users will, or you are running Windows 95/98/Me, your computer's BIOS must provide access to the hard drive.
· IBM-compatible personal computer (i386 or newer)
· 32-MB RAM
· Recommended: External hard drive
A Win32 založené zálohování a obnoví utilitu která vytváří snímek celého rozdělení či hlasitosti
Obraz pro Windows je dostupný a spolehlivý diskový obrazový zálohování a obnoví utilitu. Diskové zobrazování z Windows je snadná a vhodná cesta do zálohování veškeré vaše tvrdé diskové dat a operační systémové segmenty.
Obraz pro Windows, který to vytváří snímky úseků a může zálohovat a obnoví data.
Vaše zálohování mohou být ušetřený k sadě souborů na místních či síti pohonech, či přímo do největších CD či DVD pohonů. Zálohování ušetřený přímo k CD/DVD jsou zaveditelná standardně, dělání vhodného obnovovacího disku. Jednoduše obnovte rozdělení(s) vy potřebujete obnovit, a oni budou úplně obnovený zpět do cesty, kterou byla kdy zálohování bylo vytvořené.
Obraz pro Windows zužitkuje technologii dostupnou v zahrnuté PHYLOCK připojené utilitě. PHYLOCK dovoluje vám pokračovat s používáním vašeho počítače zatímco zálohování je zamčený k bodu-palci-času. Toto odstraňuje neslučitelnosti typicky zkušené při zálohování rozdělení které/ho se užívá.
Jak její jméno naznačuje, obraz pro Windows běží na windowsovském operačním systému, ale to může zálohovat či obnovit nějaké /každé /žádné rozdělení, včetně těch DOS či Linux. Obraz pro Windows může také vyobrazit či obnovit z jen o nějakém /každém /žádném písmeně disku, včetně síťových disků.
Diskové obrazové soubor y jsou kompatibilní napříč vším TeraByte Unlimited diskem zobrazovacími produkty stejné významnější verze počítá (i.e. všechny 1.x produkty jsou slučitelné s jiným 1.x produkty). Toto usnadní obnovit disk obrazy dokonce když Windows nejsou dostupné.
Prémie: Každý nákup Image pro Windows zahrnuje kopii Image pro DOS a Image pro Linux. Obraz pro DOS a Image pro Linux podporuje stejnou silnou diskovou obrazovou funkčnost bez vyžadující pracující windowsovské instalace. To také zahrnuje licencovanou kopii TeraByte OS Deploymentu Toolu Suite (TBOSDTS). TBOSDT obsahuje sadu silných utilit které, kromě jiného, pomohou vám rozmístit Windows k úplně jinému hardwaru.
Zde jsou nějaké klíčové rysy "Obraz pro Windows":
· jednoduché, Wizard - Driven rozhraní - snadno použitelný poprvé, a vždycky.
· celková spolehlivost - poskytuje volbu k tomu, aby ověřila úplně každý bajt, který to zálohuje.
· výhoda - slzy přímo z Windows a kdy užívaný s volným PHYLOCK doplňkem, to může vytvořit pravdivý obraz Windows rozdělit sám, bez vyžadující restart.
· maximální komprese - standardně, maximální komprese je aplikovaná na diskové obrazy, které vy vytvoříte.
· nejvyšší rychlost - jestli záložní rychlost je nadřazená, vy můžete obejít kompresi zcela.
· optická disková podpora - vy můžete chránit přímo do CD či DVD disku.
· zaveditelné záchranné disky - kdykoli vy chráníte přímo do CD či DVD, to bude automaticky se stát zaveditelný obnovit disk.
· obnovte individuální soubory či Folders - používání volného TBIVIEW doplňku, vy se můžete dívat na obsah diskových obrazových souborů, a volitelně obnovit individuální soubory či složky uvnitř je.
· kompatibilita - automaticky poznává a zálohuje užívané oblasti FAT16, FAT32, NTFS, Ext2, Ext3, ReiserFS, a XFS úseky. Úseky s ostatními souborovými systémovými druhy mohou být zálohovaný v jejich celistvosti.
· efektivnost nákladů - zahrnuje obraz pro DOS a Image pro Linux bez příplatku, dělání toho jedinečně dostupného a kompletního disku zobrazovacího řešení.
· flexibilita - obnoví rozděluje, bez ohledu na systém souborů na rozdělení být obnovené. Toto dává vám sílu k tomu, aby obnovila NTFS úseky z Windows 98 či dokonce DOS (jak jen pár příkladů).
· Wide - Ranging Device Support - slučitelný s USB 2 a IEEE 1394 pohony. Lépe ještě, obraz pro DOS podporuje tyto pohony přímo, bez požadující komplikované řidičské instalace. (obraz pro Windows jednoduše užívá ovladače již dostupný pod Windows.)
· síla - používání obrazu pro DOS či Image pro Linux (z nichž každý je obsažený v nákupu Image pro Windows) verze dávají vám schopnost k tomu, aby obnovila vaše data, i když Windows nezačnou.
· síťová podpora - chraňte zálohování nějakému /každému /žádnému pohonu přístupnému k Windows sám.
· RAID podpora - prací bezproblémově s na palubě hardware- a mikroprogramové vybavení-založený RAID.
· nařízená lineární podpora - silný, kompletní nařízený lineární podpora je postavená v, dovolující vás automatizovat zálohování či obnovit procedury.
· obrazová kontrola platnosti souboru - dovolují vás kontrolovat integritu disku obrazových souborů, také jako části zálohování procesu, či kdykoliv potom.
· obnovená rozdělovací expanze - při obnovení obrazu, vy můžete expandovat obnovené rozdělení k tomu, aby zabíralo nějaké /každé /žádné prostranství které by jste byli zbylí.
· volitelné obrazové velikosti souboru - jestli požadovaný, vy můžete specifikovat maximální velikost pro disk obrazové soubory které byly vytvořené. Toto dovoluje vám vytvořit obrazové soubory které pohotově si zkoušely výměnné médium dle vaší volby.
· jestli vy budete obnovení vně Windows, jak největší domácí uživatelé bude, či vy běžíte Windows 95/98/mě, váš počítačový BIOS musí poskytovat přístup k pevnému disku.
· IBM-COMPATIBLE osobní počítač (i386 či novější)
· 32-MB RAM
· doporučený: Externí pevný disk
