Aktuálny čas je Sob 26. Sep 2026 19:17:06
 Vášnivý hráči POZOR je tu pre Vás B.O.M.B.A.
 Predmet príspevku: Vášnivý hráči POZOR je tu pre Vás B.O.M.B.A.
PoslaťNapísal: Ned 19. Apr 2009 13:30:09
5Star Game Copy seamlessly combines powerful and sophisticated "Under-the-hood" technology with an incredibly easy to use interface.
The application integrates several varied backup techniques into a single utility, which manages to copy even the discs that other programs simply cannot.
It can copy and/or emulate all major copy protection techniques, even the trickier methods such as VOB Protect CD, StarForce 1 & 2, the latest SafeDisc and Securecom up to version 5, as well as copying DVDs, including PS2 (the PSX 2 will require a modchip, however). With support for Dual-Layer and Double Layer DVDs.
5-Star GameCopy also offers and integrated copy protection scanner and support for the famous DPM, RMPS, and RAW Copy modes. Just one of its exclusive features is the integrated game launcher, allowing you to play copy-protected games without having the disc in the drive, and without modifying the game files at all, such as a "No CD" crack might.
Here are some key features of "5Star Game Copy":
· An "Advanced Copy" dialog, which allows you to change or add files while in 1:1 (direct) copy mode.
· An integrated copy protection scanner.
· An Intelligent Copy Mechanism, including DPM Mode�, fast skipping of damaged sectors, EFM optimization to copy 'weak' sectors and RAW Copy Mode�.
· HideATIP, which prevents the game from detecting that the disc is a copy.
· Image splitting
· One included virtual drive, with wide support for an alternative third-party drive instead.
· Multiple Image Archiving: Since most discs are only really used during installation, a lot of space is wasted in storing them on the hard drive. With this feature, you can store several games on a single DVD as well as other files, such as updates/patches and serials, effortlessly. You can even launch or install directly from the archives!
5Star herní kopie bezproblémově kombinuje silná a sofistikovaná "Pod--kapuce" technologie s neuvěřitelně snadno použitelným rozhraním.
Aplikace integruje několik měnila se záložní techniky do jednotlivé utility, která daří se kopírovat dokonce disky které jiné programy jednoduše nemůže.
To může kopírovat a/či soupeřte s veškerý významnějšími kopírovacími ochrannými technikami, dokonce ošidnějšími metodami jako VOB Protect CD, StarForce 1 & 2, poslední SafeDisc a Securecom až do verze 5, stejně jako kopírovací DVDS, včetně PS2 ( PSX 2 bude požadovat modchip, ať tak nebo onak). S podporou pro Dual - Layer a dvouvrstvový DVDS.
pětihvězdičkový GameCopy také nabízí a integrované kopírovací ochranné snímací zařízení a podporovat pro slavné DPM, RMPS, a RAW Copy režimy. Jen jeden z jeho exkluzivních rysů je integrovaný herní spouštěč, dovolující vás hrát kopírovací-chráněné hry bez toho, mít disk v pohonu, a bez modifikování herních souborů vůbec, jako "Ne CD" trhlina mohla by.
Zde jsou nějaké klíčové rysy "5Star herní kopie":
· "Pokročilá kopie" dialog, který dovoluje vám měnit či přidat soubory zatímco v 1:1 (přímý) kopíruje mód.
· integrované kopírovací ochranné snímací zařízení.
Intelligent Copy Mechanism, včetně DPM Mode?, rychlé skákání poškozených sektorů, EFM optimalizace k tomu, aby kopírovala ' slabé sektory a RAW Copy Mode?.
· HideATIP, který zabraňuje hře z odhalování , které disk je kopie.
· obraz štěpení
· jeden zahrnul virtuální pohon, se širokou podporou pro alternativní odjinud pocházející pohon místo toho.
· vícenásobná obraz archivace: Od největších disků jen opravdu jsou užívány během instalace, hodně prostoru je zbytečný v uskladnění je na pevném disku. S tímto rysem, vy můžete skladovat několik her na jednotlivý DVD stejně jako jiné soubory, jako aktualizace/záplaty a seriály, bez námahy. Vy můžete dokonce spustit či instalovat přímo z archivů!
