Aktuálny čas je Štv 22. Okt 2026 11:00:55
 FindOnClick v2.0.4.4
 Predmet príspevku: FindOnClick v2.0.4.4
PoslaťNapísal: Sob 18. Apr 2009 20:58:28
FindOnClick can search for files on any NTFS or FAT (FAT 12, 16, 32) partitions, including from hard drives (internal and external), floppy disks, flash cards, Smart Media (SM), SONY Memory Sticks, IBM Micro Drives, Multimedia Cards (MMC), Secure Digital Cards (SD), Zip disks, etc.
What FindOnClick can do
• Easy to use filters provide powerful ways that help reduce the number of search results.
• Can be powered from the command line or from an easy-to-use graphical interface.
• Choose whether FindOnClick minimizes to the tray or on close to reduce desktop clutter.
• Search results can be exported to .csv files for analysis in programs such as Microsoft Excel.
• View information about the version numbers of program files. Great for checking for updates.
• Quickly delete unwanted or duplicate files at the click of a button. No need for Explorer.
• Locate duplicate files quickly to better manage and organize your data.
• Advanced users make complex search quiries using regular expressions.
• Quickly integrate the program with the click of a button with Windows Explorer.
• Confirm the contents of your files are identical to source files by using hash referencing.
• Extensive options to search MP3 music files. Displays MP3s by Title, Artist, Album etc. (ID3v1).
• Limit your search to a particular folder. This significantly speeds the search process.
• Evaluation version available for testing.
Program Controls, Options, and Features
• Can search multiple drives/paths.
• Can search network drives.
• Filename and Path columns (hidden by default).
• Refresh button.
• Open With... menu item.
• Can search for files and/or folders.
• Can use wildcards in filename extensions filter.
• Copy filenames to clipboard.
• Extensive Search Parameters: by Size; Date; Extension; Attributes; Duplicate; and Contents.
• Shortcut creation button.
• Right Click menu for fast access to many of FindOnClick's features.
• Show statistics on the current search query.
• Set hotkey.
• Complete help file and free technical support.
FindOnClick může pátrat po souborech na nějaký /každý /žádný NTFS či FAT (FAT 12, 16, 32) úseky, včetně z pevné disků (vnitřní a externí), pružné disky, pomocné kartičky, chytrá média (SM), SONY Memory Sticks, IBM Micro Drives, multimediální karty (MMC), bezpečné digitální karty (SD), zipovací disky, a tak dále
Co FindOnClick může dělat
• Snadno použitelné filtry poskytují silné způsoby, jakou pomáhají redukovat počet výsledků hledání.
• Může být poháněný z příkazové řádky či ze snadno použitelného grafického rozhraní.
• Vyberte si zda FindOnClick minimalizuje do podnosu či na zavřít redukovat desktop změť.
• Výsledky hledání mohou být exportují do .csv soubory pro analýzu v programech jako Microsoft překoná se.
• Dívejte se na informaci o verzi množstvích programových souborů. Ohromný pro kontrolovat aktualizace.
• Rychle vymažte nechtěný či zdvojte soubory v kliknutí knoflíku. Není třeba pro průzkumníka.
• Lokalizujte zdvojené soubory rychle lepší řídit a organizovat vaše data.
• Pokročilí uživatelé udělají komplex hledat archy používání pravidelných výrazů.
• Rychle integrujte program s kliknutím knoflíku s windowsovský Explorer.
• Potvrďte obsah vašich souborů byly identický se zdrojovými soubory použitím rozemelete odkaz.
• Rozsáhlé volby k tomu, aby hledaly MP3 hudební soubory. Displeje MP3S titulem, umělcem, albem a tak dále (ID3V1).
• Omezte vaše hledání k specifické složce. Toto významně chvátá proces vyhledávání informací.
• Vyhodnocení verze dostupný pro testování.
Program kontroly, volby, a rysy
• Může hledat vícenásobné pohony/cesty.
• Může hledat síťové disky.
• Jméno souboru a Path sloupce (skrytý standardně).
• Občerstvte knoflík.
• Otevřete s... položka v menu.
• Může pátrat po souborech a/či složkách.
• Může užívat zástupné znaky v rozšiřujícím filtru jména souboru.
• Kopírujte jména souboru clipboardu.
• Rozsáhlé vyhledávací parametry: podle velikosti; Datum; Rozšíření; Atributy; Duplikát; a obsah.
• Zkratka knoflík vytvoření.
• Pravé Click menu pro rychlý přístup k mnoho z FindOnClick- ovo rysů.
• Ukažte statistiky na aktuálním vyhledávacím dotazu.
• Nastavte horkou klávesu.
• Kompletní soubor nápovědy a volná technická podpora.
