Aktuálny čas je Uto 27. Okt 2026 23:59:50
 Portable CardRecovery 5.10-Velice kvalitný soft
 Predmet príspevku: Portable CardRecovery 5.10-Velice kvalitný soft
PoslaťNapísal: Str 15. Apr 2009 15:06:41
CardRecovery is a popular SD Card Recovery software to recover deleted, formatted, corrupted or lost pictures, images, photos from Secure Digital Card. It has a wizard-style interface and allows you to easily recover files from SD memory card. It supports all brands including SanDisk, Kingston, PNY, Lexar, Transcent, PQI and more.
Professional Camera Card Data Recovery Software.
We are the experts in digital camera photo recovery. CardRecovery is specially designed to recover photos from digital camera cards. All memory card types and various image formats are supported. Besides common image formats JPG, JPEG, BMP, GIF, PNG, TIF, it even supports raw image formats including NEF, CRW, CR2, ORF, X3F, RAF, MRW, PEF and more. It helped thousands of customers save their valuable photos.
Finding More Recoverable Pictures with SmartScan Technology
CardRecovery uses a unique SmartScan technology from WinRecovery Software that quickly diagnoses the situation and scans every sector on the storage to ensure all recoverable pictures will be retrieved. It accesses your memory card at a low level and can even completes those impossible recovery tasks that other softwares cannot touch.
The Leading Recovery Speed
You don't need to wait hours for the recovery process. In our tests, CardRecovery takes less than 3 minutes to fully scan a 1 GB SanDisk SD card, and approx. 16 minutes for a 8 GB Transcend SDHC card with USB 2.0 connection. If your card reader or camera uses a low speed USB 1.x connection, the scan time may be longer.
Easy to Use User Interface
CardRecovery has a friendly user interface. A three-step wizard guides you through the whole recovery process, and it allows you to perform recovery tasks quite easily and smoothly. There was no easier way to salvage those once in a lifetime moments you thought were lost forever!
Powerful and Helpful Features
CardRecovery retrieves the EXIF information including shooting time, image size, camera model etc. from the picture files in real time while scanning. Additionally, it allows you to preview the recovered pictures in thumbnail before saving and helps you determine the needed pictures quickly.
Safe Data Protection
CardRecovery performs READ-ONLY operations on your memory card. It doesn't move, delete, and modify the data on the card to avoid causing further damage or overwriting. It recovers the photos from the card and saves them to the location you specify.
CardRecovery je populární SD Card Recovery software k tomu, aby obnovil vymazaný, formátovaný, zkažený či prohrály obrázky, obrazy, snímky ze Secure Digital Card. To má kouzelné-stylové rozhraní a dovoluje vám snadno obnovit soubor ze SD paměťové karty. To podporuje všechny značky včetně SanDisk, Kingston, PNY, Lexar, Transcent, PQI a více.
Profesionální kamerový datový obnovovací software karty.
My jsme experti v digitálním kamerovém fotografickém zotavení. CardRecovery je speciálně navržený k tomu, aby obnovil snímky z digitálních kamerových mikroštítků. Veškeré paměťové druhy štítku a různé obrazové formáty jsou podporované. Kromě běžného obrazu formáty JPG, JPEG, BMP, GIF, PNG, TIF, to dokonce podporuje syrové obrazové formáty včetně NEF, CRW, CR2, ORF, X3F, RAF, MRW, PEF a více. To pomohlo tisícům zákazníků chránit jejich cenné snímky.
Nález víc navratitelných obrázků se SmartScan Technology
CardRecovery užívá jedinečnou SmartScan technologii z WinRecovery Software která rychle diagnostikuje situaci a skenuje každý sektor na skladu k tomu, aby zajistil veškeré navratitelné obrázky bude získaná. To zpřístupňuje vaši paměťovou kartu v nízké úrovni a může dokonce dokončuje ty nemožné obnovovací úkoly že jiné softwéru nemohou dotýkat se.
Vedoucí zotavení chvátá
Vy nepotřebovat čekat hodiny pro obnovovací proces. V našich testech, CardRecovery vezme méně než 3 minuty k plně skenovat 1 GB SanDisk SD kartu, a approx. 16 minuty pro 8 GB překročí SDHC kartu s USB 2.0 spojení. Jestli váš snímač štítků či kamerová použití nízkého rychlostního USB 1.x spojení, snímání čas může být delší.
Snadno použitelné uživatelské rozhraní
CardRecovery má přátelské uživatelské rozhraní. Tři-přírůstkový mág provází vás skrz celý obnovovací proces, a to dovoluje vám vykonávat obnovovací úkoly docela snadno a hladce. Nebyl tam žádní snadnější způsob jak zachránit ti jednou v celém životě momentech si vy myslíte jste byli ztracený navždy!
Silné a užitečné rysy
CardRecovery znovu získá EXIF informaci včetně střílejícího času, rozměr obrazu, kamerového modelu a tak dále z obrazových souborů v reálném čase při skenování. Dodatečně, to dovoluje vám prohlédnout si regenerované obrázky v miniaturních zmenšeninách obrázků před šetřením a pomáhá Vám určit potřebné obrázky rychle.
Bezpečné zabezpečení dat
CardRecovery vykonává READ-ONLY operace na vaší paměťové kartě. To nepohybuje, vymazat, a modifikovat data na kartě k tomu, aby vyhnula se působící další poškození či přepis. To obnovuje snímky z karty a chrání je k umístění, které vy specifikujete.
