Aktuálny čas je Pon 28. Sep 2026 3:09:08
 Carry it Easy +Plus 3.0.0.0 MultiLanguage
 Predmet príspevku: Carry it Easy +Plus 3.0.0.0 MultiLanguage
PoslaťNapísal: Str 04. Feb 2009 12:26:02
Turn your portable storage device (e.g. USB flash drive, U3 smart drive, external HDD) into a powerful tool. Protect your data, backup or sync your Outlook, sync your files and Internet favorites and compress all data to save space. With Carry it Easy +Plus you have all tool that you might need ready on your storage device and you can use them on any PC. If you just go on vacation or permanently need to keep data on different PCs in sync.
Personal
Carry it Easy +Plus™ helps you take all your personal data wherever you want to go. Send and receive e-mails from any computer that has Outlook or Outlook Express installed. Have your internet bookmarks with you and access them from any computer, the regular way or with No Trace Browsing. Work anywhere you want and carry all your files with you with just a few clicks. All this, with an interface that's available in up to 17 languages.
Whenever you go, wherever you go, you can easily carry your data with you.
Private
Carry it Easy +Plus™ password-protects your data from unwanted access. Still, if you lose your Flash Drive the finder can see your contact details but can't see the password protected files. Carry it Easy +Plus™ also offers the No Trace Browsing function so all the data related to Internet surfing (Cookies, Cache, History) is stored on the Flash Drive and can be deleted afterwards.
Your drive, your data. Carry it Easy +Plus™ helps you keep your information private with password protection.
Easy to use
Everything is simple when using Carry it Easy +Plus™. The friendly and appealing interface and functions couldn't be easier to use; from the intuitive initial configuration process to the No Trace Browsing every step takes only a few clicks.
Outlook® synchronization
Keep your Outlook® profiles synchronized between different PCs. Always have your Outlook® at home and at work up to date. When you are traveling, the convenient Portable Outlook functionality allows you to access all your Outlook data on the remote PC just like it would be your own PC
Portable Microsoft Outlook®
Have all your e-mails and contacts with you and use them on computers that have Microsoft Outlook® installed
Data Protection with 128 bit AES Encryption
Protect your data. Simple and safe
Portable Outlook Express / Windows Mail
Have all your e-mails and contacts with you and use them on computers that have Outlook® Express or Windows Mail installed
Favorites synchronization (Internet Explorer & Firefox)
Carry all your links and access them from any computer
No Trace Browsing with Internet Explorer & Firefox
No need to let everyone know where you have been on the Internet
Desktop, Folder to Folder and My Documents synchronization
A few clicks and take with you all the files you need
Data Compression
Save valuable space on your portable device
USB Drive partitioning
Public or Private. Or both (Hardware based data protection by partitioning is available only for special USB Flash Drives)
USB Drive Lost & Found™
Let the finder know who you are but don't let him see what's on your Flash Drive
USB Drive information
All that you might want to know about your Flash Drive
Multilingual user interface
Get Carry it Easy™ in 17 different languages (English, German, French, Spanish, Portuguese, Italian, Japanese, Russian, Traditional Chinese, Simplified Chinese, Dutch, Danish, Polish, Romanian, Czech, Thai and Korean)
Czech - !!!
Točte vaši přenosnou paměť (e.g. USB křiklavý pohon, U3 chytrý pohon, externí HDD) do silného nástroje. Chraňte vaše data, zálohování či synchronizaci vaši Outlook, synchronizace vaši soubory a internetový favority a stlačit všechna data ušetřete místo. S Carry to Easy +plus vy máte veškerý nástroj který možná, že bys mohl potřebovat připravený na vaší paměti a vy můžete použít je na nějakém /každém /žádném PC. Jestli vy jen jedete na dovolenou či permanentně potřebovat držet data na jiný PCS v synchronizaci.
Osobní
Neste to snadné +Plus™ pomoci, které Vám vezmete veškerá vaše osobní data kdekoli vy chce jít. Pošlete a přijměte e - maily z nějakého /každého /žádného počítače který mějte Outlook či Outlook Express nainstalovaný. Mít vaše internetové záložky s vámi a zpřístupnit je z nějakého /každého /žádného počítače, normální postup či s No Trací Browsingem. Pracujte kdekoli vy chcete a nést veškeré vaše soubory s vámi s jen několik kliknutí. Všechno toto, s rozhraním které je k dispozici v až do 17 jazyků.
Kdykoli vy jdete, kdekoli vy jdete, vy můžete snadno nést vaše data s vámi.
Privátní
Neste to Easy +Plus™ heslo-ochrany vaše data z nechtěného přístupu. Ještě, jestli vy ztratíte váš Flash řídí vyhledávače může vidět vaše kontaktní detaily ale nemůže vidět heslo chráněné soubory. Neste to Easy +Plus™ také nabízí No Traci Browsing funkci tak celého data příbuzného s Internetem surfováním (koláčky, cache, historie) je uložená na Flash Drive a může být zrušený později.
Váš pohon, vaše data. Neste to snadné +Plus™ pomoci, které Vám držíte vaši informaci privátní s ochranou heslem.
Snadno použitelný
Všechno je jednoduché při používání nést to Easy +Plus™. Přátelské a přitažlivé rozhraní a funkce nemohlo být snadno použitelný; z intuitivního počátečního konfigurace procesu k No Traci Browsingu každému kroku bere pouze několik málo kliknutí.
Outlook® synchronizace
Držte vaše Outlook® profily synchronizované mezi jinými PCS. Vždy mějte váš Outlook® doma a v práci moderní. Kdy vy cestujete, vhodná Portable Outlook funkčnost dovoluje vám zpřístupnit veškerá vaše Outlook data na vzdáleném PC právě jako to by byl váš vlastní PC
Přenosný Microsoft Outlook®
Mít veškeré vaše e - maily a kontakty s vámi a užíváte je na počítačích které měly Microsoft Outlook® nainstalované
Zabezpečení dat s 128 kousalo AES šifrování
Chraňte vaše data. Jednoduchý a sejf
Přenosný expres výhledu / Windows pošty
Mít veškeré vaše e - maily a kontakty s vámi a užíváte je na počítačích které měly Outlook® Express či windowsovské Mail nainstalované
Favority synchronizace (Internet Explorer & Firefox)
Neste veškerá vaše spojení a zpřístupněte je z nějakého /každého /žádného počítače
Žádné stopa prohledávání s Internetem Explorer & Firefox
Není třeba nechat každý člověk vědět kde vy jste byli na Internetu
Desktop, složka k Folder a My Documents synchronizaci
Několik kliknutí a vezmou s vámi všechny soubory, které vy potřebujete
Komprese dat
Chraňte cenný prostor na vašem přenosném zařízení
USB Drive rozdělování
Veřejnost či privátní. Či oba (hardware založené zabezpečení dat rozdělováním je k dispozici jen pro zvláštní USB Flash Drives)
USB pohon ztracený & Found™
Dejte vědění vyhledávače kdo jste ale nenechávejte ho vidět co je na programu váš Flash Drive
USB Drive informace
Všechno co možná, že bys mohlo chtít vědět o váš Flash Drive
Mnohojazyčné uživatelské rozhraní
Dostaňte Carry to Easy™ v 17 jiných jazycích (anglický, německý, francouzský, španělský, portugalský, italský, japonský, ruský, tradiční čínský, zjednodušení čínský, nizozemský, dánský, polský, rumunský, český, thajština a Korejec)
