Aktuálny čas je Sob 24. Okt 2026 17:23:50
 Portable Ashampoo Internet Accelerator v3.00 Multilingual
 Predmet príspevku: Portable Ashampoo Internet Accelerator v3.00 Multilingual
PoslaťNapísal: Uto 14. Apr 2009 13:03:01
We all take the Internet for granted nowadays but what your computer has to do to allow you to surf is actually amazingly complicated. Windows has a long list of settings for tuning the performance of your Internet connection. That’s fine if you’re a computer expert, the rest of us will generally make things worse rather than better – if we can find all the well-hidden settings in the first place. Ashampoo Internet Accelerator analyzes your computer and optimizes all the relevant settings with a single click. You don’t need to know anything, just select the automatic optimizer and you’re done. The new version also includes an Internet connection speed test tool so you can test your performance directly. In addition to automatic optimization advanced users can still access all the individual settings and adjust them manually.
Easier to use, plus new tools and settings:
We’ve redesigned the layout, making the program even easier to use. Everything is explained directly, you’ll probably never have to refer to the help. In addition to this we’ve also added a set of new tools and features for managing your Internet connection.
Boost and configure Internet Explorer and Firefox
Internet Explorer and Firefox are the two most popular browsers and you can now configure them and boost their performance right from internet Accelerator. In addition to performance-enhancing settings you also get direct access to a large number of useful browser settings, all in one place.
Internet Cleaner tool
Your browser saves a record of everything you do and every page you visit. The new Internet Cleaner tool lets you quickly delete your complete surfing trail, with separate settings for Internet Explorer, Firefox and Opera.
Hosts File Checker
Your computer’s “Hosts” file lists the location of known Internet sites and is always checked first for the address when you access a site. Spyware and other malicious programs can use it to redirect you to fake and dangerous sites – the new Hosts
File Checker makes sure this isn’t happening.
Interactive checking for key parameters
In addition to optimizing your access speed Internet Accelerator can also interactively check some advanced parameters on your live connection to work out the best settings. You don’t have to use this feature, but it’s there if you want it.
New features:
• Intuitive new layout – everything explains itself
• Boost and configure Internet Explorer and Firefox
• Internet Cleaner – quickly erase your surfing trail
• Hosts File Checker – stop spyware redirecting you
• Interactive auto-check for key Internet access settings
Included Languages:
German (Ashampoo )
English (Ashampoo )
Dutch (Roger Defevere)
French (Jean-Yves elle)
Hungarian (Laszlo Koncz)
Polish (Jacek Milecki)
Spanish (Miguel Blasco)
Chinese (simplified) (Smilefly )
Japanese (yamato_takeru )
Slovakian (Milan Slovák)
Operating Systems: XP/Vista 32
My všichni vezmou Internet pro udělený v nynější době ale co váš počítač musí udělat aby vám dovolil surfovat je ve skutečnosti úžasně komplikuje. Windows mají dlouhý seznam nastavení pro ladění výkon vašeho internetového spojení. To je v pořádku jestli vy jste počítačový odborník, my ostatní obecně udělají věci horší spíše než lepší – jestli my můžeme najít všechno pramen-skrytá nastavení v první řadě. Ashampoo Internet Accelerator analyzuje váš počítač a optimalizuje celá významná nastavení s jednotlivým kliknutím. Vy nemusíte vědět cokoli, jen vybrat automatický optimizátor a vy jste udělaní. Nová verze také zahrnuje internetový rychlostní zkušební nástroj spojení tak vy můžete testovat váš výkon přímo. Navíc k automatickým optimalizaci pokročilým uživatelům mohou ještě zpřístupnit celá individuální nastavení a nastavit je ručně.
Snadno použitelná, plus nová nástroje a nastavení:
My jsme přepracovali konstrukci rozvržení, dělání programu dokonce snadno použitelného. Všechno je vysvětlené přímo, pravděpodobně nikdy nebudete budete muset se odvolávat na pomoc. V dodatku k tomuto my jsme také přidali sadu nových nástrojů a rysů pro ovládání vašeho internetového spojení.
Podporujte a konfigurujte Internet Explorer a Firefox
Internet Explorer a Firefox jsou dva nejpopulárnější prohlížeč a vy můžete nyní konfigurovat je a podporovat jejich výkon přímo z internetový Accelerator. Navíc k výkonu zvyšujícím nastavením vy také dostanete přímý přístup k velkému množství užitečných prohlížečových nastavení, všechno na jednom místě.
Internet čistější nástroj
Váš prohlížeč chrání záznam všechno, co vy děláte a každou stránku vy navštívíte. Nový internetový Cleaner nástroj nechá vás rychle vymazat vaši kompletní surfovací cestu, se separátními nastaveními pro Internet Explorer, Firefox a Opera.
Hostitelé registrují dohlížitele
Vaše počítačové "hostitelé" seznamy souborů umístění známých internetových stránek a vždy je kontrolované nejprve pro adresu kdy vy zpřístupníte místo. Spyware a jiné záludné programy mohou použít to přesměrovat , že vás falšovat a nebezpečné místa – nové hostitele
Souborový Checker se ujistí toto není událost.
Interaktivní kontrolování pro klíčové parametry
Navíc k optimalizaci váš přístupový rychlostní internetový Accelerator může také interaktivní kontrolovat nějaké pokročilé parametry na vašem živém spojení s vypracovat nejlepší nastavení. Nemusíte užívat tento rys, ale to je tam chcete - li to.
Nové rysy:
• Intuitivní nové rozvržení – všechno vysvětluje sám
• Podporujte a konfigurujte Internet Explorer a Firefox
• Internetový Cleaner – rychle vymaže vaši surfovací cestu
• Hostitelé File Checker – zastaví spyware přesměruje vy
• Interaktivní automobil-šek na klíčová nastavení přístupu na Internet
Zahrnuté jazyky:
Němec (Ashampoo )
Angličtina (Ashampoo )
Nizozemský (Roger Defevere)
Francouzi (Jean - Yves loket)
Maďarský (Laszlo Koncz)
Polština (Jacek Milecki)
Španělský (Miguel Blasco)
Číňané (zjednodušený) (Smilefly )
Japonský (yamato_takeru )
Slovák (Milan Slovák)
Operační systémy: XP/Vista 32
 Predmet príspevku: Re: Portable Ashampoo Internet Accelerator v3.00 Multilingual
PoslaťNapísal: Uto 14. Apr 2009 15:01:49
Instant Clickfix for Your Internet Connection! We all take the Internet for granted nowadays but what your computer has to do to allow you to surf is actually amazingly complicated. Windows has a long list of settings for tuning the performance of your Internet connection. That’s fine if you’re a computer expert, the rest of us will generally make things worse rather than better – if we can find all the well-hidden settings in the first place.
• Easier to use, plus new tools and settings:
• Internet Cleaner tool
Your computer’s “Hosts” file lists the location of known Internet sites and is always checked first for the address when you access a site. Spyware and other malicious programs can use it to redirect you to fake and dangerous sites – the new Hosts File Checker makes sure this isn’t happening.
• Interactive checking for key parameters
New features:
* Intuitive new layout – everything explains itself
* Boost and configure Internet Explorer and Firefox
* Internet Cleaner – quickly erase your surfing trail
* Hosts File Checker – stop spyware redirecting you
* Interactive auto-check for key Internet access settings
Instantní Clickfix pro vaše internetové spojení! My všichni vezmou Internet pro udělený v nynější době ale co váš počítač musí udělat aby vám dovolil surfovat je ve skutečnosti úžasně komplikuje. Windows mají dlouhý seznam nastavení pro ladění výkon vašeho internetového spojení. To je v pořádku jestli vy jste počítačový odborník, my ostatní obecně udělají věci horší spíše než lepší – jestli my můžeme najít všechno pramen-skrytá nastavení v první řadě.
• Snadno použitelná, plus nové nástroje a nastavení:
Internet Explorer a Firefox jsou dva nejpopulárnější prohlížeč a vy můžete nyní konfigurovat je a podporovat jejich výkon přímo z internet Accelerator. Navíc k výkonu zvyšujícím nastavením vy také dostanete přímý přístup k velkému množství užitečných prohlížečových nastavení, všechno na jednom místě.
• Internet čistější nástroj
• Hostitelé registrují dohlížitele
Vaše počítačové "hostitelé" seznamy souborů umístění známých internetových stránek a vždy je kontrolované nejprve pro adresu kdy vy zpřístupníte místo. Spyware a jiné záludné programy mohou použít to přesměrovat , že vás falšovat a nebezpečná místa – noví hostitelé souborový dohlížitel se ujistí toto není událost.
• Interaktivní kontrolování pro klíčové parametry
Nové rysy:
* intuitivní nové rozvržení – všechno vysvětluje sám
* podpora a konfiguruje Internet Explorer a Firefox
* internetový Cleaner – rychle vymazat vaši surfovací cestu
* hostitelé souborový dohlížitel – zastaví spyware přesměruje vy
* interaktivní automobil-šek na klíčová nastavení přístupu na Internet
