Aktuálny čas je Str 21. Okt 2026 16:32:34
 Portable HDD Observer v2.6.9
 Predmet príspevku: Portable HDD Observer v2.6.9
PoslaťNapísal: Pon 06. Apr 2009 16:14:29
"HDD Observer is the absolute monitoring and repairing tool for your hard drives."
BSEditor: HDD Observer can detect a lot of hard drives troubles and give a solution for them:
- Monitor hard drives health, performance and temperature
- Monitor hard drives activity and show it in a system tray icon
- Check file system fragmentation and registry fragmentation
- Defragment file system and registry
- Automatically and real-time find and remove un-needed files and registry values
- Windows XP/2003/Vista compatible
- Native 64 bit support for best performance
- Low memory usage
HDD Observer is not only a high technologic product - it is one of the most intelligent soft for hard drives monitoring. And this is because it has some unique technologies implemented by us especially for this program. One of them is SmartBehavior - a unique behavior technology implemented in monitoring tools.
For example, if HDD temperature is near its critical value then HDD Observer begins to check it more frequently to exactly detect the time when the temperature will reach it's critical value. Evident - if critical value is reached, then HDD Observer will check HDDs with a lower frequency to release any system resources.
Another interesting feature is 'System Fragmentation Monitoring':
HDD Observer begins fragmentation check only when computer is idle, and all system resources are free.
In this case HDD Observer will check for fragmentation until will finish or the user will need any system resources. After check it informs the user about fragmentation level and can even defragment HD using its build-in defragmentation tools.
These and many other features make HDD Observer the most advanced HDD troubles monitoring and repairing program
"HDD Observer je absolutní monitorovací a opravující nástroj pro vaše pevné disky."
BSEDITOR: HDD Observer může zjistit hodně útrap pevných disků a dát řešení pro ně:
- monitor zdraví pevných disků, výkon a teplota
- monitor aktivita pevných disků a ukáže to v systémovém podnosu ikoně
- kontrolním souborovém systémovém rozdělení a registračním rozdělení
- defragmentovat systém souborů a registr
- automaticky a reálný čas najde a odstranit ne-potřebné soubory a registr hodnoty
- windowsovská XP/2003/Vista kompatibilní
- nativní 64 kousek podporuje pro nejlepší výkon
- nízké použití paměti
HDD Observer není jen vysoký technologický produkt - to je jedním z nejvíce inteligentní měkký pro monitorování pevných disků. A toto je protože to má nějaké jedinečné technologie implementované od nás zvláště pro tento program. Jeden z nich je SmartBehavior - jedinečný technologie chování implementovaného v monitorovacích nástrojích.
Například, jestli HDD teplota blízko je jeho kritická hodnota pak HDD Observer začíná kontrolovat to častěji k přesně zjistit čas kdy teplotu dosáhne to je kritická hodnota. Očividný - jestli kritická hodnota je dosažená, pak HDD Observer zkontroluje HDDS s nižší četností uvolnit nějaké /každé /žádné systémové prostředky.
Další zajímavý rys je ' systémový monitorování rozdělení ' :
HDD Observer začíná šek rozdělení jen když počítače zahálet, a všechny systémové prostředky jsou volné.
V tomto případě HDD Observer zkontroluje na rozdělení až do skončí či uživatele bude potřebovat nějaké /každé /žádné systémové prostředky. Po šeku, který to informuje uživatele o rozdělení úrovni a může dokonce defragmentovat HD používání jeho stavební-v defragmentaci nástrojích.
Tyto a mnoho jiných rysů udělá HDD Observer nejpokročilejší HDD problémy monitorovací a opravující program
