Aktuálny čas je Pia 23. Okt 2026 23:53:42
 WMWifiRouter v1.25
 Predmet príspevku: WMWifiRouter v1.25
PoslaťNapísal: Uto 31. Mar 2009 16:07:54
WMWifiRouter instantly turns your Windows Mobile device into a wireless internet hotspot. Now you can use your laptop and any other device with wifi to get online and surf, email, instant message, and anything else you normally use the internet for!
Main Features:
# Share your cellular data/internet connection over wifi
# Connect any wifi-enabled device with ad-hoc mode support
# Supports multiple devices at the same time
# Easy to use: for most users, getting up and running is a matter of a single click
# Power saving: works even when the device is suspended!
# IP, wifi and cellular configuration built-in 'ai
# 64- and 128-bit WEP encryption support
# Automatic reconnect on connection loss
# Compatible with almost all recent Windows Mobile devicesPower Features:
# Ability to feed internet to your normal wireless router, with WPA encryption
# Live traffic statistics
# Live DHCP statistics
# Port mapping support
# DMZ support
# AppToDate automatic update supportWhat's new in WMWifiRouter 1.25:· This new version of WMWifiRouter contains several bug-fixes and enhancements, though it does not contain any completely new features. One important fix is the temperature read-out for CDMA-based HTC Diamond and HTC Touch Pro devices. These two devices report temperature in different units than most other Windows Mobile devices, which could cause WMWifiRouter to shutdown automatically to prevent your battery from overheating. Other changes include several minor bugfixes, more multithreading, optimized statistics gathering, and power management adjustments. The latter two resulting in less power consumption and CPU use, especially when running with the screen turned off.
Odpoved s citáciou Editovat príspevok Ohlásit tento príspevok Vymazat príspevok
WMWIFIROUTER okamžitě mění vaše windowsovský Mobile zařízení na bezdrátový internetový aktivní bod. Teď vy můžete použít vaše laptop a jiné zařízení s wifi dostat online a surfovat, email, instantní zpráva, a něco jiného, co vy normální používání internet pro!
Hlavní rysy:
# podíl vaše celulární datové/internetové spojení přes wifi
# propojovat nějaké /každé /žádné wifi-umožněné zařízení s reklamním-hoc módem podporuje
# podpory vícenásobná zařízení zároveň
# snadno použitelný: pro většinu uživatelů, vstávání a běh je věcí jednotlivého kliknutí
# síla šetření: práce dokonce kdy zařízení je pozastavené!
# IP, wifi a celulární konfigurace zabudovaný ai
# 64 - a 128 - bitová WEP šifrovací podpora
# automat opětovně se spojí na ztrátě spojení
# slučitelný s téměř veškerý nedávnými windowsovský Mobile devicesPower Features:
# schopnost k tomu, aby krmila internet váš normální bezdrátový horní frézka, s WPA šifrováním
# živé přepravní statistiky
# živé DHCP statistiky
# přístav mapující podpora
# DMZ podpora
# AppToDate automatická aktualizace supportWhat- ovo nový ve WMWIFIROUTER 1.25:· tato nová verze WMWIFIROUTER obsahuje několik štěnice-oprav a zvětšení, ačkoli to neobsahují nějaké /každé /žádné úplně nové rysy. Jeden důležitá oprava je teplota výběr pro CDMA-BASED HTC Diamond a HTC Touch Pro zařízení. Tato dvě zařízení oznámí teplotu v jiných jednotkách než většinách jiných windowsovských Mobile zařízení, která může způsobit WMWIFIROUTER přerušení práci automaticky zabránit vaší baterii z přehřívání. Jiné změny zahrnují několik menší bugfixes, více multithreading, optimalizované statistiky shromáždění, a výkonových manažerských upravení. Pozdější dva mající za následek menší spotřebu energii a CPU užívá, zvlášť když běh s obrazovkou vypnula.
