Aktuálny čas je Pia 30. Okt 2026 12:34:09
 MultiTranse 5.3.1
 Predmet príspevku: MultiTranse 5.3.1
PoslaťNapísal: Ned 29. Mar 2009 16:24:49
MultiTranse provides an effective solution for dealing with different foreign languages.
If you need to know the meaning of a foreign text or get your words translated into some language, both quickly and without a dictionary, then MultiTranse is the right choice for you. The program translates words, phrases, as well as texts, containing up to 6000 symbols at a time. The tool uses internet connection to process a given text and provide you with a translation into the selected language. It takes advantage of free Web resources to make the optimal translation. With MultiTranse, you will be able to understand foreign texts and convey your ideas into other languages in a blink of an eye, just by using your connection to the Web. The reasonable advantage of MultiTranse is that it replaces a whole bookcase filled with dictionaries and grammar books. It translates from the following languages: English, Chinese (both traditional and simplified), Arabic, Dutch, French, Greek, German, Spanish, Italian, Portuguese, Russian, Korean, Japanese. Using MultiTranse, you'll become a polyglot that has a good command of languages from all over the world. As for the program's interface, it supports English, Catalan, Dutch, Russian and Spanish. MutiTranse will smoothly render your words even into non-Latin languages, such as Chinese, Korean or Japanese, provided you have their fonts installed.
In case you don't have the fonts, required to display some language, the program can download the necessary fonts from the Microsoft's website, so you won't need to look for the fonts on your own. MultiTranse comes with full support of Unicode and allows saving texts to any ANSI format as well as back to Unicode. Also, you can send the received translation directly to print. If you are looking for a convenient way of rendering your words into a number of languages or understanding foreign texts, then MultiTranse is the only tool you need.
MultiTranse poskytuje efektivní řešení pro práci s různými cizími jazyky. Pokud potřebujete vědět, ve smyslu cizí text nebo získat vaše slova přeložena do několika jazyků, jak rychle a bez slovníku, pak MultiTranse je pro vás tou pravou volbou. Program překládá slova, věty, stejně jako texty, které obsahují až 6000 symbolů najednou. Tento nástroj využívá připojení k internetu pro zpracování textu a poskytne vám překlad do vybraný jazyk. Je využívá volného webového zdroje, aby optimálně překladu. S MultiTranse, budete schopni porozumět cizí texty a tlumočit své myšlenky do jiných jazyků v mrknutí oka, jen pomocí svého připojení k internetu. Přiměřený MultiTranse Výhodou je, že nahradí celou knihovnu naplněný slovníků a gramatických knih. Překládá z těchto jazyků: angličtina, čínština (tradiční a zjednodušené),Arabština, holandština, francouzština, řečtina, němčina, španělština, italština, portugalština, ruština, korejština, japonština. Použití MultiTranse se vám stane vícejazyčný, že má dobrou znalost jazyků z celého světa. Pokud jde o program rozhraní, podporuje anglicky, Katalánština, holandsky, rusky a španělsky. MutiTranse hladce vydá vaše slova i do non-latinské jazyky, jako je čínština, korejština a japonština, že jste jejich písma. V případě, že nemáte písem, potřebné k zobrazení některých jazyk, program můžete stáhnout potřebné fonty z webových stránek společnosti Microsoft, takže nebudete muset hledat písma na vaší vlastní. MultiTranse přichází s plnou podporou Unicode a umožňuje ukládání textů na každém formátu ANSI, jakož i zpět na Unicode. Také nám můžete zaslat na obdržených překladatelskou přímo vytisknout. Pokud hledáte pohodlný způsob zobrazování vašich slov do mnoha jazyků a pochopochopení cizích textů, pak MultiTranse je jediný nástroj, který potřebujete.
:one: :one: :one: :one: :one: :one: :one: :one: :one: :one: :one: :one: :one: :one: :one: :one: :one: :one: :one: :one: :one: :one: :one: :one: :one: :one: :one:
